| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Plug-In Manager is a feature of Enterprise Manager Cloud Control, that serves as a single window solution for performing all plug-in deployment-related activities, through GUI as well as CLI. Using Plug-In Manager, you can:
View plug-ins available for download; plug-ins that have been downloaded; and plug-ins that have been deployed to Cloud Control.
View certification and critical information about plug-ins such as the name of the plug-in, the vendor who supplied it, the plug-in ID and version, and a short description.
Deploy plug-ins on OMS.
Deploy and re-deploy plug-in on Management Agent.
Create custom plug-in update.
Undeploy plug-ins from OMS and Management Agent.
View the status of a plug-in deployment operations.
To access the Plug-In Manager console, from the Setup menu, select Extensibility, and then select Plug-ins.
Figure 23-5 illustrates how you can access Plug-in Manager.
Figure 23-5 Navigating to Plug-In Manager
Using Plug-in Manager, you can deploy, upgrade, redeploy, and undeploy plug-ins.
Figure 23-6 shows the operations you can perform using the Plug-In Manager.
Figure 23-6 Plug-In Manager Operations
