| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
When you discover a network switch or network-enabled device, its networks are discovered. You can view the following information about a selected network:
Metric and Collection Settings
Metric Collection Errors
Status History
Incident Manager
Alert History
Blackouts and Brownouts
Create Blackout...
End Blackout...
All Metrics
Create Brownout...
End Brownout...
Job Activity
Information Publisher Reports
Last Collected
Comparison & Drift Management
Compare...
Search...
History
Save...
Saved
Topology
Compliance Results
Standard Associations
Real-time Observations
Monitoring Configuration
Administrator Access
Remove Target...
Add to Group...
Properties
Target Sitemap
Target Information
When you discover an operating system, you can view the following information about an OS target's network connectivity:
Network interfaces: MAC address, IP address, netmask and broadcast address
IPV4 and Ipv6
Routing tables
Open network ports
To see information about a network switch:
Select Targets and then All Targets.
Select Ethernet/InfiniBand Fabric.
Select one of the fabrics.
Select one of the network switches.
Use the tabs, such as the Performance tab, to view information about this target.
To see home page of Systems Infrastructure Switch :
A network is deleted automatically when all targets connected to the network are removed. To remove a network, use the Remove Target action to remove each target. After the last target is removed, the network is deleted.
