| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Starting with Oracle Enterprise Manager Cloud Control 12c Release 2 (12.1.0.2), command line utility has been introduced for Software Library users in Oracle Enterprise Manager Cloud Control that enables you to perform some of the console-based Software Library operations using the text-based consoles.
The following table describes both approaches to perform some of the Software Library tasks:
Enterprise Manager Command Line Interface (EM CLI)
Enterprise Manager Graphical User Interface (EM GUI)
For more information about the syntax and usage of the EM CLI verbs described in Table 22-3,along with workflow examples, refer to the Oracle Enterprise Manager Lifecycle Management Administrator’s Guide.
Table 22-3 Software Library EMCLI Verbs
| Description | Approach A: Using EM CLI Verb | Approach B: Using Enterprise Manager Cloud Control Console |
Adding a Software Library storage location |
Configuring an OMS Shared File system Location |
Creating a Software Library entity |
Creating a Software Library folder |
Listing the Software Library entities |
Listing Software Library entity types |
NA |
Listing Software Library entity subtypes |
NA |
Listing Software Library folders |
NA |
Listing Software Library storage locations |
Referring files from a Software Library entity |
Re-Importing Software Library metadata |
Removing a Software Library storage location |
Modifying a Software Library entity |
Uploading files to a Software Library entity |
Modifying a Software Library OMS Agent storage location to change the associated OMS Host and the credential for accessing the location. |
NA |
Verifying the files uploaded to software library, and reporting the missing files in the storage locations. This action is typically initiated when some provisioning/patching/deployment activity fails due to missing file in the associated storage location. |
NA |
Staging one or more files associated with an entity revision available in the Software Library to a file system location on a host target. |
Staging one or more files associated with an entity revision in the Software Library to the local file system of a host not monitored by an EM Agent. |
Creating an entity of the |
Modifying an entity of the |
Listing all the details of an entity revision. |
Exporting files of Software Library entities to be imported on a cache node as cached files. |
Importing Software Library entity files from a compressed file to a cache node. |
Invoking resynchronize for one or all cache nodes. |
