Go to primary content
Oracle® Pulse Getting Started Guide
Release 17.1.2
E79199-05
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
2 Accessing Oracle Pulse
You can access Oracle Pulse on your iPad or on your desktop or mobile device using any Web browser. See Supported Web Browser Versions and Supported Apple iOS Versions for more information about supported releases.
The following topics are covered in this chapter:
Accessing Oracle Pulse on Your iPad
To access Oracle Pulse on your iPad:
  1. Search for Oracle Pulse in the Apple iStore, then tap Install.
  2. Tap the Oracle Pulse icon to start the app.
  3. When the sign-on page appears, enter your single sign-on (SSO) user name and password.
    If you would like to use Oracle Pulse with demo data, select the Use Sample Data check box.
  4. Tap Sign In.
    If your user name is associated with more than one customer organization, select the organization you would like to review from the list presented.
    This populates Oracle Pulse with service information for all your organization's services or with sample data if you selected the Use Sample Data check box.
Accessing Oracle Pulse on Your Mobile Device or Desktop
To access Oracle Pulse on your mobile device or desktop:
  1. Open the following Web page in any Web browser:
    https://cloudservices.oracle.com/pulse
  2. Click Sign In.
    If you would like to populate Oracle Pulse with sample data, select the Use Sample Data check box.
  3. When the sign-on page appears, enter your SSO user name and password.
    If this is your first time to sign in to Oracle Pulse, the End User License Agreement for Oracle Pulse is displayed before the single sign-on page.
    Read the agreement, then select Accept if you accept the terms and conditions for using the application.
    This populates Oracle Pulse with service information for all your organization's services, or with sample data if you selected the Use Sample Data check box.
