This chapter includes the following sections:
The features for developing applications in JDeveloper include:
Different types of window for managing and working with different object types and resources associated with applications, projects, and files.
Several visual and code editing tools to facilitate the task of creating different types of source documents. The editors are integrated with other windows in the IDE, thus drag and drop operations and simultaneous, automatic updates among the various integrated tools are supported.
Tools to simplify the task of testing and analyzing source code, processes, and application modules or packages.
The application is the highest level in the control structure. It is a view of all the objects you need while you are working. An application keeps track of all your projects while you develop programs. A project is a logical container for a set that defines a JDeveloper program or portion of a program. A project might contain files representing different tiers of a multi-tier application, for instance, or different subsystems of a complex application. These files can reside in any directory and still be contained within a single project.
All of the projects within an application are displayed below that application. If you filter a project using the working set, the project is not displayed under the application. Closing an application or project closes all open editors or viewers for files in that application or project and unloads the files from memory.
You can remove application and project control files from the IDE without deleting them from the disk. (This is not true for other types of file, which will be deleted from the disk at the time that they are removed from the IDE.) JDeveloper can recognize many different file types, displaying each in its appropriate viewer or editor when you double-click the file.
When adding a project to an application, you can choose to:
Create a new project, with specific objects and attributes you define.
Create a new empty project, which inherits default project properties.
Open an existing set of files from outside JDeveloper into a new project.
Projects control their files lists directly through the directory. Applications and packages also define where and how the files within a project are stored.
The same object (physical file) can appear in more than one project. This means that any actions carried out on the object in one project will show up in the other project (although some effects will become apparent only after the project is compiled). For packages, two or more projects should not share a package unless, first, they also share a source path used to generate the package and, secondly, the package is already compiled and will never be changed.
The application is the highest level in the control structure. It is a view of all the objects you need while you are working. An application keeps track of all your projects while you develop programs..
To create a new application with a specific feature scope:
You can either create an application with a specific feature scope, or create a custom application that contains a single project that can be customized to include any features.
To create a new custom application:
A project is a logical container for a set of files that defines a JDeveloper program or portion of a program. You can create a project that is preconfigured with a specific set of features.
To create a new project with a specific feature scope:
The new project appears in the Applications window. It inherits whatever default properties you have already set. To alter project properties for this project, either double-click the filename or right-click and choose Project Properties.
You can effectively manage your applications and projects using the Applications window. The Applications window organizes your projects in terms of higher-level logical components that gives you a logical view of your application and the data it contains. It provides an infrastructure that the different extensions can plug into and use to organize their data and menus in a consistent, abstract manner. While the Applications window can contain individual files (such as Java source files), it is designed to consolidate complex data. Complex data types such as entity objects, UML diagrams, EJB, or web services appear in this Applications window as single nodes. The raw files that make up these abstract nodes appear in the Structure window.
Applications displayed in the Applications window contain one or more projects. Within the projects are the root folders for the paths in that project. You can choose to view project contents as a directory tree or file list, and packages by tree or list. And you can sort the nodes within packages and directories by type.
You have the option of creating new applications from scratch or opening existing ones. As soon as you create or import the application, it is added to the Applications node in the Applications window.
To open an existing application and add it to the Applications window:
As soon as you create or import a project, it is added to the selected application.
To open an existing project and add it to an application:
After you have created your project, you can directly create components related to the project's features using the project context menu.
To add items using the project context menu:
You can create new files of various types from scratch or open existing ones. When opening existing files, you can import them, along with their file structure, into an existing project or build a completely new project around them.
Alternatively, you can add source files to projects you already have.
You can import existing files of any type into JDeveloper, creating a new project as you do so.
To open existing files and import them into a new JDeveloper project:
You can fine tune your project directories structure, for example to point to resource directories, in the Project Properties dialog.
You can import a WAR file into JDeveloper, creating at the same time a new project to contain its extracted contents.
To open a WAR file and import it into a new JDeveloper project:
The wizard analyzes the WAR file and extracts its contents.
The new project appears under the selected application node, populated with the imported files.
When you import an EAR file, JDeveloper will always create a new application and populate it with projects based on the EAR modules extracted. You cannot add the contents of an EAR file to an existing application or project.
You should not use this procedure to import an EAR file that you simply wish to deploy using JDeveloper. To do this, create a new application and project, then copy your EAR file into the project directory (or add its location to the project's content). The EAR file will then appear in the Applications window under the project's Application Sources node. From here, you can deploy the file by right-clicking it and choosing Deploy to.
To open an EAR file and import it into a new JDeveloper application:
You can also create new projects from existing source.
You can use the Import Existing Sources wizard to add.zip or.jar files to projects. You cannot use it to add.war or.ear files. A .war file requires the Import WAR File wizard to property extract its contents into the project. An EAR file requires the Import EAR File wizard, which extracts its contents into a new application.
To open an existing file and add it to a project using the Import Existing Sources wizard:
JDeveloper enables you to create custom folders or Java packages within your project to better organize your project files.
To create a folder or Java package:
To delete a folder or Java package:
Working sets allow you to configure the Applications window to show you a subset of files from your project. This is particularly useful when working with large projects. Until you create a working set, there are no default working sets. After you create a working set, the option All Files lets you to get back to the default view.
You can run and debug a working set in just the same way as you run and debug a project. This allows you to work on just a subset of a large application, for example a Java EE application, without affecting the entire application or incurring a performance hit.
To group objects in the Applications window into a working set:
You can define a working set by selecting from files or containers in the Applications window, or by providing include and exclude filter patterns through the Manage Working Sets dialog.
To create a working set by defining file and directory filters:
You can create one or more sets of files for working on within a project. Based on the scope of your search, the action to save the search results as a working set is available.
To create a working set from the results of a search in the Log window:
A tooltip in JDeveloper identifies the working set you are currently using:
In the Applications window, hover the mouse over the Working Sets icon. The name of the current working set is displayed as a tooltip. Alternatively, click the Working Sets icon to bring up a menu in which the active working set is checked.
To change the active working set:
In the Applications window, click the Working Sets icon and select the working set you want to open.
Files not belonging to the working set are removed from the Applications window but no editors are closed.
To edit files and projects in a working set:
To restore the view in the Applications window to show all files:
In the Applications window, click the Working Sets icon and select (All Files).
Before you begin, ensure that you are using the working set you want to run or debug. This should include the projects that represent the Java EE modules (Web applications, EJB modules) that you are working on and any dependencies.
Be aware that any projects that are explicit dependencies (in the Dependencies page of the Project Properties dialog) will be included even if they are excluded from the working set.
To run and debug a working set:
Sometimes, you may not want to add files directly to a project, but yet have them handy for browsing. You can bring files into the JDeveloper IDE, without adding them to a project.
To browse files in JDeveloper without adding them to a project:
You can easily inspect the contents of any archive, after first opening the archived file in JDeveloper. You can add the contents of an archive to an existing or new JDeveloper project.
To open an archive in JDeveloper and view its contents:
You can easily view any.gif, .jpg, .jpeg, or .png file from within JDeveloper.
To open and view an image in JDeveloper:
From the main menu, choose File > Open.
As you are only going to view the image, it doesn't matter which node in the Applications window is currently selected.
Navigate to the image or images to be opened. Be sure that the file type field either specifies all file types or the image types.
Select the image.
With your selection made, click Open.
The image is displayed in the main working area of JDeveloper.
To view an image already imported into JDeveloper:
The project properties you specify in the Default Project Properties dialog apply to all subsequent projects you create across applications. Those you specify in the Project Properties dialog apply only to the current project. You can also set custom properties to override the properties set in a current project. This is particularly useful in a multiuser development environment. Custom properties are not stored in the .jpr file.
When you set project properties for an individual project, you override the default values for that project alone.
The procedures you follow for setting default project properties are identical to those for setting properties for individual projects — with the exception that, as you are in default properties, you do not need to first select an individual project. Note that some project properties cannot be set from the Default Project Properties dialog.
To view or change the default settings for a project:
You can set the project properties for all subsequent projects, or fine-tune the properties for any individual project.
Additional project properties are also available, based upon specific tasks such as compiling, or debugging.
To view or change the current output path for an individual project:
Setting the target Java SE specifies which Java SE JDeveloper will use when compiling and running your project.
To view or change the current Java SE for an individual project:
Complex applications generally comprise multiple projects, which may be related though dependencies. That is, project A must depend on project B when project A uses classes or resources from project B. When this dependency is set, compiling project A will automatically compile project B.
Deployment profile dependencies are created and edited in the Project Properties dialog available from the Tools menu.
To manage the project dependencies for an individual project:
When you create a project from a template, the project will inherit all the features available in the template. More features are added dynamically to the project as you create content in your project. Go to Project Properties > Features > Reconcile to filter the list of features that are actually in use in the project.
To associate features with a project via its project template:
This procedure is applicable only for new projects created from a template.
When features are associated with a project, JDeveloper's design time filters the choices you see based upon what you are most likely to need for a project of this type.
To associate features with an individual project:
Every project you create carries the JDeveloper project defaults or those you have supplied yourself for all projects. You can also replace these defaults on a project-by-project basis. Setting these properties is the same in either case: only the location, and application, of the information differs.
To set Javadoc properties for an individual project:
There are two categories of library: internal and external. Internal library definitions are persisted within the project file itself (that is, within the .jpr file) and are thus always available to anyone opening that project. However, internal library definitions are not sharable among any other projects. You can add an internal library to a project by going to the Libraries and Classpath page of the Project Properties dialog, and clicking Add JAR/Directory.
External library definitions are persisted within their own stand-alone library definition file (that is, the .library file). As such, external libraries can be checked into source control, referenced by any number of projects, and can be shared among all users in a team environment in the same way that java source files are. Since external libraries have their own unique URL, adding an external library to a project adds that URL to the project.
Libraries are often required across many or all projects within an application. All libraries that you add at the application level are implicitly added to the libraries and classpaths of all projects within the application and are readily available at design and compile time.
Any library or classpath added at the application level for use during deployment are included in the packaged EAR lib directory and is selected for deployment by default.
To add an application-level library:
Libraries added at the application-level do not appear in the in the project properties Libraries and Classpath page by default. Check Show Application Libraries in the project properties Libraries and Classpath page to see all application-level libraries (this option is disabled if no application-level libraries exist). You can move the list of application-level libraries as a block to the top or bottom of the classpath entries using the Move to Top or Move to Bottom arrows. You cannot move an individual application-level library.
You can create and add an application-level library in the same way as described in How to Create a New Library and Add it to a New Project.
When you include libraries in a project, the source paths defined for those libraries automatically become part of the project's classpath.
To view the current libraries for an individual project:
You can add an existing library to a project.
To add an existing library to a project:
You can create a new library and add it to a new project.
To create a new library and add it to a project:
You can edit an existing library in a project.
To edit an existing library in a project:
When you remove libraries from a project, the source paths defined for those libraries no longer form part of the project's classpath.
To remove a library from a project:
You can work with libraries completely outside the JDeveloper project scope, setting them up to be either available to you for use in any of your projects or available to a group of users across an installation.
To work with libraries or Java SEs outside of the scope of a project:
To create libraries or Java SEs outside the scope of a project:
You can work with libraries completely outside the JDeveloper project structure, setting them up to be either available to you for use in any of your projects or available to a group of users across an installation.
To edit libraries or Java SEs outside the scope of a project:
To delete libraries or Java SEs outside the scope of a project:
Application and project templates provide you with a quick way to create the project structure for standard applications with the appropriate combination of features already specified. The new application created from template appears in the Applications window already partitioned into tiered projects, with the associated features set.
The application template you select determines the initial project structure, the named project folders within the application. The project templates define the associated features. You can then filter the work you do in JDeveloper such that the choices available are focused on the features you are working with.
An application template organizes one or more project templates which specify the project types expected in the application. Using such templates enables you to standardize the way you develop an application.
To define a new application template:
The application template appears in the New Gallery in the Applications category of the Business Tier.
Project templates specify the various types of projects expected in a given application. Project templates are contained within application templates.
To define a new project template:
The project template appears in the New Gallery in the Projects category.
You can create an application or project template in a shared location. Other users can read templates from the shared location and use the same templates for their application and projects.
To create a shared template:
The shared templates folder is listed under both the Application Templates and Project Templates node.
You can edit existing user-defined application or project templates.
To edit an existing application or project template:
JDeveloper allows you to create file templates with pre-populated custom data and use them in your application. For example, you can create a Java class file template that contains basic header tagging, then when you need to add a Java class file in your application, you would start from your created template and that would save you from manually entering basic header data in every single Java class.
You can create templates for all the files types supported in JDeveloper such as Java, html, xml, etc.
There are two workflows for managing file templates: you can edit an existing template and you can create a new template. The workflows are described below.
To edit an existing template:
Open your application in JDeveloper and navigate to Tools > Preferences > File Templates. JDeveloper provides an out-of-the-box Java class template.
In the File Templates dialog go to the folder directory and navigate to General > Java.
Click the provided template, Copyrighted Class. The template details and template content appears on the right pane.
By default the built-in templates are not editable. If you start typing to modify the content of the template, you will be prompted to confirm that you want to modify the built-in template.
Modify the template by adding a simple line of text above the @author line. For example,
* Enter a description of this class.
JDeveloper provides out of the box variables to use in your templates. To understand those variables see, Available File Template Variables.
You can use the Reset button on the top-right corner of the page to revert the template to its original text.
Click OK to close the Preferences dialog.
To use the template in your application, navigate to New > Gallery > General > Java and you will see on the right pane the Copyrighted Class template.
Select the template and click OK.
After defining the File Name, the new class is created using the text in the created template.
Figure 4-1 Edit File Template
Line 28 shows the text that you added to the template on step 4.
To create a new template:
JDeveloper provides the following File Template Variables out-of-the-box:
name—the name, without extension, of the file that will be created
nameAndExt—the name, without extension, of the file that will be created
date—the current time, in this format: Feb 16, 2008 from DateFormat.getDateInstance() during template processing
package—the current package is specified
time—the current time, in this format: 7:37:58 PM from DateFormat.getTimeInstance() during template processing.
dateTime—the current date, from DateFormat.getDateTimeInstance() during template processing
user—the current user name, as returned from System.getProperty("user.name")
You can save an application or project in several ways.
To save all the components across applications, including all projects:
From the main menu, choose File > Save All or click the Save All icon.
Alternately, you can save components individually by using File > Save.
It is important to note that saving the application or project container (.jws, .jpr) file alone does not save the individual files governed by that application or project. Nor does saving individual contained files save the container node.
Each node is an independent entity and must be saved as such. Using Save All takes care of changes to these container files, as well as all content files.
Using Save or Save As on a selected application or project node saves or duplicates the .jws or .jpr file only: it does not save or duplicate the files contained within the node.
Note too that if you do a Save As on an application or a project container file, that container is replaced, but the files contained are not altered. If you do a Save As on an individual file, that file is duplicated. However, if you want to rename a file, you should use File > Rename.
Saving the application or project container (.jws, .jpr) file alone does not save the individual files governed by that application or project. Nor does saving individual contained files save the container node.
You can rename an individual file or component using File > Rename.
Note that if you do a Save As on an application or a project container file, that container is replaced, but the files contained are not altered. If you do a Save As on an individual file, that file is duplicated.
To save an individual component or file:
You can rename application control files, project control files, and individual files. The correct way of renaming Java classes is to use refactoring.
To rename an application or project container, or an individual source file:
Alternately, you can use File > Save As. Note that Rename always replaces the target file. Save As replaces application or project container (.jws, .jpr) files, but duplicates source files.
When you are saving files, remember that saving a container file alone does not save the contents of the entire application or project. For that, you need to use Save All.
The Applications window presents a visual representation of the logical structure of applications and projects. It is not a file directory. It does not necessarily represent the physical location of those files.
To change the physical location of individual files, you can work in JDeveloper. To change the physical location of a group of files, it is easier to work through your operating system's file manager.
To change the association of files with projects or projects with applications, you would work in the Applications window, adding or removing as appropriate.
The best practice for relocating Java classes is to use the options available on the Refactor menu.
To change the physical location of an individual file, whether within the project or a container (.jws or .jpr) file:
In the Applications window, select the file to be moved.
From the main menu, choose File > Rename. If you have chosen a Java file, the Rename File dialog will open. You will be able to relocate the file only if you choose the option Rename the file only, do not update references in this dialog.
In the Rename dialog, navigate to the new location for the file and change the file's name if you wish.
Click Save.
The file is now physically stored in the new directory. Its logical representation does not change in the Applications window unless you explicitly alter it.
To change the physical location of an entire application or directory:
In your operating system's file manager, navigate to the directory in which the files currently reside. Files stored in the JDeveloper default directory reside in the mywork folder.
Select the entire directory (application, project, or files within a project) to be moved and move it to the new location.
The files have now been moved, but JDeveloper no longer knows where they are.
When you return to JDeveloper, in the Applications window, and choose Open Application from the drop-down list.
Navigate to the new physical location of the application or project and click Open.
To change the physical location of a group of files from one project to another:
When you close an application, project, or file in the Applications window, that application or project is unloaded from memory. When an application or project is closed, it appears in its unexpanded form in the Applications window.
In addition, you can remove applications, projects, or files from the Applications window, which removes them only from the list, or you can delete them permanently, wherever they reside, from within JDeveloper.
To close an application or project:
You can close a file opened in a viewer or an editor by clicking on the close box of the corresponding document tab above the editor window.
You can remove files from a project, which removes them only from the Applications window list, or you can delete them permanently, wherever they reside, from within JDeveloper.
To remove a file from a project:
You can remove projects from the application by deleting the project control file (.jpr) from within JDeveloper.
To remove a project from an application:
You can close an application and remove it from the Applications window. If you want to delete the application
To remove an application from the IDE:
