Enter the Oracle RightNow Cloud source request values for your integration. The values you specify start the integration.
You can configure the following request value for Oracle RightNow Cloud.
The Oracle RightNow application has a limit of 20 subscriptions for every available event subscription. For example, you can build a maximum of 20 integrations, with all subscribing to the Customer Created Event integration and 20 integrations subscribing to the Contact Destroy Event integration. If you create a 21st integration for the same event subscription, this may lead to errors during integration activation.The following table describes the key information on the Oracle RightNow Cloud source Request page.
| Element | Description |
Configure a Request |
Select the endpoint configuration option by choosing a business object or event subscription.
Select a Business Object (is displayed if With Business Objects is selected) |
Select the business object from the Oracle RightNow Cloud application to receive as a request that starts the integration. |
Filter by object name (is displayed if With Business Objects is selected) |
Enter the initial letters to filter the display of business objects. You can also select a filter type:
Select Event (is displayed if Event Subscription is selected) |
Select the event subscription from the Oracle RightNow Cloud application. This event is received as a request that starts the integration. Note: Only the Organization and Contact business objects are supported for event subscriptions in this release. |
Event Name Filter (is displayed if Event Subscription is selected) |
Enter the initial letters to filter the display of business events. |
