Enter the Oracle RightNow Cloud source response values for your integration.
You can configure the operation and business object that comprise the response type for Oracle RightNow Cloud.
Select the business object for the integration to send as a response document to the Oracle RightNow Cloud application.
The following types of responses are available.
Immediate: A synchronous response is required (See Table 9-1 for instructions)
None: No response is required (See Table 9-2 for instructions)
The following table describes the fields available if an immediate (synchronous) response is required.
Table 9-1 Response Type — Immediate (Synchronous) Response is Required
| Element | Description |
Immediate Response |
Select Immediate for the Oracle RightNow Cloud application to wait until a response is received from the integration. This is also known as the request and response message exchange pattern. This is the default selection. |
Also Send faults |
Select this checkbox if you want to send fault information to the Oracle RightNow Cloud application if any errors are encountered by the integration while processing the request. This is an optional checkbox only available with the Immediate response type. |
Object Filter Name |
Enter the initial letters to filter the display of business objects. You can also select a filter type:
Select Business Object |
Select the business object for the integration to send as a response document to the Oracle RightNow Cloud application. |
The following table describes the fields available if no response is required.
Table 9-2 Response Type — No Response is Required
Send |
Deselect if a response is not required. This option disables the selection of business objects because none are required. |
Response Type |
If you deselect the Send checkbox, this section is disabled. |
