man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
nvlist_xunpack(9F)
Name
nvlist_alloc, nvlist_free, nvlist_size, nvlist_pack, nvlist_unpack, nvlist_dup, nv_alloc_init, nv_alloc_fini, nvlist_xalloc, nvlist_xpack, nvlist_xunpack, nvlist_xdup, nvlist_merge - Manage a name-value pair list
Synopsis
#include <sys/nvpair.h>
List Manipulation:
int nvlist_alloc(nvlist_t **nvlp, uint_t nvflag,
     int kmflag);
int nvlist_xalloc(nvlist_t **nvlp, uint_t nvflag, nv_alloc_t *nva);
void nvlist_free(nvlist_t *nvl);
int nvlist_size(nvlist_t *nvl, size_t *size, int encoding);
int nvlist_pack(nvlist_t *nvl, char **bufp, size_t *buflen, int encoding,
     int flag);
int nvlist_xpack(nvlist_t *nvl, char **bufp, size_t *buflen, int encoding,
     nv_alloc_t *nva);
int nvlist_unpack(char *buf, size_t buflen, nvlist_t **nvlp, int flag);
int nvlist_xunpack(char *buf, size_t buflen, nvlist_t **nvlp,
     nv_alloc_t *nva);
int nvlist_dup(nvlist_t *nvl, nvlist_t **nvlp, int flag);
int nvlist_xdup(nvlist_t *nvl, nvlist_t **nvlp, nv_alloc_t *nva);
int nvlist_merge(nvlist_t *dst, nvlist_t *nvl, int flag);
Pluggable Allocator Configuration:
nv_alloc_t *nvlist_lookup_nv_alloc(nvlist_t *);
int nv_alloc_init(nv_alloc_t *nva,
     const nv_alloc_ops_t * nvo,/* args */ ...);
void  nv_alloc_reset(nv_alloc_t  *nva);
void  nv_alloc_fini(nv_alloc_t *nva);
Pluggable Allocation Initialization with Fixed Allocator:
     nv_fixed_ops, void * bufptr,  size_t sz);
Interface Level
Solaris DDI specific (Solaris DDI)
Parameters
nvlp
Address of a pointer to list of name-value pairs (nvlist_t).
nvflag
Specify bit fields defining nvlist_t properties:
NV_UNIQUE_NAME
nvpair names are unique.
NV_UNIQUE_NAME_TYPE
Name-data type combination is unique
kmflag
Kernel memory allocation policy, either KM_SLEEP or KM_NOSLEEP.
nvl
nvlist_t to be processed.
dst
Destination nvlist_t.
size
Pointer to buffer to contain the encoded size.
bufp
Address of buffer to pack nvlist into. Must be 8-byte aligned. If NULL, library will allocate memory.
buf
Buffer containing packed nvlist_t.
buflen
Size of buffer bufp or buf points to.
encoding
Encoding method for packing.
nvo
Pluggable allocator operations pointer (nv_alloc_ops_t).
nva
Points to a nv_alloc_t structure to be used for the specified nvlist_t.
Description
List Manipulation:
The nvlist_alloc() function allocates a new name-value pair list and updates nvlp to point to the handle. The argument nvflag specifies nvlist_t properties to remain persistent across packing, unpacking, and duplication.
If NV_UNIQUE_NAME is specified for nvflag, existing nvpairs with matching names are removed before the new nvpair is added. If NV_UNIQUE_NAME_TYPE is specified for nvflag, existing nvpairs with matching names and data types are removed before the new nvpair is added. See nvlist_add_byte(9F) for more details.
The nvlist_xalloc() function differs from nvlist_alloc() in that nvlist_xalloc() can use a different allocator, as described in the Pluggable Allocators section.
The nvlist_free() function frees a name-value pair list.
The nvlist_size() function returns the minimum size of a contiguous buffer large enough to pack nvl. The encoding parameter specifies the method of encoding when packing nvl. Supported encoding methods are:
NV_ENCODE_NATIVE
Straight bcopy() as described in bcopy(9F).
NV_ENCODE_XDR
Use XDR encoding, suitable for sending to another host.
The nvlist_pack() function packs nvl into contiguous memory starting at *bufp. The encoding parameter specifies the method of encoding (see above).
  • If *bufp is not NULL, *bufp is expected to be a caller-allocated buffer of size *buflen. The kmflag argument is ignored.
  • If *bufp is NULL, the library allocates memory and updates *bufp to point to the memory and updates *buflen to contain the size of the allocated memory. The value of kmflag indicates the memory allocation policy
The nvlist_xpack() function differs from nvlist_pack() in that nvlist_xpack() can use a different allocator.
The nvlist_unpack() function takes a buffer with a packed nvlist_t and unpacks it into a searchable nvlist_t. The library allocates memory for nvlist_t. The caller is responsible for freeing the memory by calling nvlist_free().
The nvlist_xunpack() function differs from nvlist_unpack() in that nvlist_xunpack() can use a different allocator.
The nvlist_dup() function makes a copy of nvl and updates nvlp to point to the copy.
The nvlist_xdup() function differs from nvlist_dup() in that nvlist_xdup() can use a different allocator.
The nvlist_merge() function adds copies of all name-value pairs from nvlist_t nvl to nvlist_t dst. Name-value pairs in dst are replaced with name-value pairs from nvl which have identical names (if dst has the type NV_UNIQUE_NAME), or identical names and types (if dst has the type NV_UNIQUE_NAME_TYPE).
The nvlist_lookup_nv_alloc() function retrieves the pointer to the allocator used when manipulating a name-value pair list.
PLUGGABLE ALLOCATORS
Using Pluggable Allocators:
The nv_alloc_init(), nv_alloc_reset() and nv_alloc_fini() functions provide an interface that specifies the allocator to be used when manipulating a name-value pair list.
The nv_alloc_init() determines allocator properties and puts them into the nva argument. You need to specify the nv_arg argument, the nvo argument and an optional variable argument list. The optional arguments are passed to the (*nv_ao_init()) function.
The nva argument must be passed to nvlist_xalloc(), nvlist_xpack(), nvlist_xunpack() and nvlist_xdup().
The nv_alloc_reset() function resets the allocator properties to the data specified by nv_alloc_init(). When no (*nv_ao_reset()) function is specified, nv_alloc_reset() is without effect.
The nv_alloc_fini() destroys the allocator properties determined by nv_alloc_init(). When a (*nv_ao_fini()) routine is specified, it is called from nv_alloc_fini().
The disposition of the allocated objects and the memory used to store them is left to the allocator implementation.
The `nv_alloc_sleep' and `nv_alloc_nosleep' nv_alloc_t pointers may be used with nvlist_xalloc to mimic the behavior of nvlist_alloc with KM_SLEEP and KM_NOSLEEP, respectively.
o  nv_alloc_nosleep
o  nv_alloc_sleep
The nvpair framework provides a fixed-buffer allocator, accessible via nv_fixed_ops.
o  nv_fixed_ops
Given a buffer size and address, the fixed-buffer allocator allows for the creation of nvlists in contexts where malloc or kmem_alloc services may not be available. The fixed-buffer allocator is designed primarily to support the creation of nvlists.
Memory freed using nvlist_free(), pair-removal, or similar routines is not reclaimed.
When used to initialize the fixed-buffer allocator, nv_alloc_init should be called as follows:
int nv_alloc_init(nv_alloc_t *nva, const nv_alloc_ops_t *nvo,
    void *bufptr, size_t sz);
When invoked on a fixed-buffer, the nv_alloc_reset() function resets the fixed buffer and prepares it for re-use. The framework consumer is responsible for freeing the buffer passed to nv_alloc_init().
CREATING PLUGGABLE ALLOCATORS
Any producer of name-value pairs may possibily specify his own allocator routines. You must provide the following pluggable allocator operations in the allocator implementation.
int (*nv_ao_init)(nv_alloc_t *nva, va_list nv_valist);
void (*nv_ao_fini)(nv_alloc_t *nva);
void *(*nv_ao_alloc)(nv_alloc_t *nva, size_t sz);
void (*nv_ao_reset)(nv_alloc_t *nva);
void (*nv_ao_free)(nv_alloc_t *nva, void *buf, size_t sz);
The nva argument of the allocator implementation is always the first argument.
The optional (*nv_ao_init() ) function is responsible for filling the data specified by nv_alloc_init() into the nva_arg() argument. The (*nv_ao_init()) function is called only when nv_alloc_init() is executed.
The optional (*nv_ao_fini()) function is responsible for the cleanup of the allocator implementation. It is called by nv_alloc_fini().
The required (*nv_ao_alloc()) function is used in the nvpair allocation framework for memory allocation. The sz argument specifies the size of the requested buffer.
The optional (*nv_ao_reset()) function is responsible for resetting the nva_arg argument to the data specified by nv_alloc_init().
The required (*nv_ao_free()) function is used in the nvpair allocator framework for memory de-allocation. The argument buf is a pointer to a block previously allocated by (*nv_ao_alloc()) function. The size argument sz must exactly match the original allocation.
Return Values
For nvlist_alloc(), nvlist_dup(), nvlist_xalloc(), and nvlist_xdup():
0
success
EINVAL
invalid argument
ENOMEM
insufficient memory
For nvlist_pack(), nvlist_unpack(), nvlist_xpack(), and nvlist_xunpack():
0
success
EINVAL
invalid argument
ENOMEM
insufficient memory
EFAULT
encode/decode error
ENOTSUP
encode/decode method not supported
For nvlist_size():
0
success
EINVAL
invalid argument
For nvlist_lookup_nv_alloc():
Usage
The fixed-buffer allocator is very simple allocator. It uses a pre-allocated buffer for memory allocations and it can be used in interrupt context. You are responsible for allocation and de-allocation for the pre-allocated buffer.
Examples
   * using the fixed-buffer allocator.
  /* initialize the nvpair allocator framework */
  static nv_alloc_t *
  init(char *buf, size_t size)
       nv_alloc_t *nvap;
       if ((nvap = kmem_alloc(sizeof(nv_alloc_t), KM_SLEEP)) == NULL)
           return (NULL);
       if (nv_alloc_init(nvap, nv_fixed_ops, buf, size) == 0)
           return (nvap);
       return (NULL);
   static void
   fini(nv_alloc_t *nvap)
         nv_alloc_fini(nvap);
         kmem_free(nvap, sizeof(nv_alloc_t));
    static int
    interrupt_context(nv_alloc_t *nva)
       nvlist_t *nvl;
       int error;
       if ((error = nvlist_xalloc(&nvl, NV_UNIQUE_NAME, nva)) != 0)
            return (-1);
       if ((error = nvlist_add_int32(nvl, "name", 1234)) == 0)
            error = send_nvl(nvl);
       nvlist_free(nvl);
       return (error);
Context
The nvlist_alloc(), nvlist_pack(), nvlist_unpack(), and nvlist_dup() functions can be called from interrupt context only if the KM_NOSLEEP flag is set. They can be called from user context with any valid flag.
The nvlist_xalloc(), nvlist_xpack(), nvlist_xunpack(), and nvlist_xdup() functions can be called from interrupt context only if (1) the default allocator is used and the KM_NOSLEEP flag is set or (2) the specified allocator did not sleep for free memory (for example, it uses a pre-allocated buffer for memory allocations).
These functions can be called from user or kernel context with any valid flag.
