man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
pci_plist_lookup_string_array(9F)
Name
pci_plist_lookup, pci_plist_lookup_int8, pci_plist_lookup_uint8, pci_plist_lookup_int16, pci_plist_lookup_uint16, pci_plist_lookup_int32, pci_plist_lookup_uint32, pci_plist_lookup_int64, pci_plist_lookup_uint64, pci_plist_lookup_string, pci_plist_lookup_plist, pci_plist_lookup_int8_array, pci_plist_lookup_uint8_array, pci_plist_lookup_int16_array, pci_plist_lookup_uint16_array, pci_plist_lookup_int32_array, pci_plist_lookup_uint32_array, pci_plist_lookup_int64_array, pci_plist_lookup_uint64_array, pci_plist_lookup_string_array - name-value pair lookup functions
Synopsis
#include <sys/sunddi.h>
int pci_plist_lookup_int8(pci_plist_t plist, const char *name,
     int8_t *val);
int pci_plist_lookup_uint8(pci_plist_t plist, const char *name,
     uint8_t *val);
int pci_plist_lookup_int16(pci_plist_t plist, const char *name,
     int16_t *val);
int pci_plist_lookup_uint16(pci_plist_t plist, const char *name,
     uint16_t *val);
int pci_plist_lookup_int32(pci_plist_t plist, const char *name,
     int32_t *val);
int pci_plist_lookup_uint32(pci_plist_t plist, const char *name,
     uint32_t *val);
int pci_plist_lookup_int64(pci_plist_t plist, const char *name,
     int64_t *val);
int pci_plist_lookup_uint64(pci_plist_t plist, const char *name,
     uint64_t *val);
int pci_plist_lookup_string(pci_plist_t plist, const char *name,
     char **val);
int pci_plist_lookup_plist(pci_plist_t plist, const char *name,
     pci_plist_t **val);
int pci_plist_lookup_int8_array(pci_plist_t plist, const char *name,
     int8_t *val, uint_t *nelem);
int pci_plist_lookup_uint8_array(pci_plist_t plist, const char *name,
     uint8_t *val, uint_t *nelem);
int pci_plist_lookup_int16_array(pci_plist_t plist, const char *name,
     int16_t *val, uint_t *nelem);
int pci_plist_lookup_uint16_array(pci_plist_t plist, const char *name,
     uint16_t *val, uint_t *nelem);
int pci_plist_lookup_int32_array(pci_plist_t plist, const char *name,
     int32_t *val, uint_t *nelem);
int pci_plist_lookup_uint32_array(pci_plist_t plist, const char *name,
     uint32_t *val, uint_t *nelem);
int pci_plist_lookup_int64_array(pci_plist_t plist, const char *name,
     int64_t *val, uint_t *nelem);
int pci_plist_lookup_uint64_array(pci_plist_t plist, const char *name,
     uint64_t *val, uint_t *nelem);
int pci_plist_lookup_string_array(pci_plist_t plist, const char *name,
     char **val, uint_t *nelem);
Parameters
plist
A handle obtained from pci_plist_get(9F) or pci_plist_getvf(9F).
name
Name of the name-value pair to search
nelem
Address to store the number of elements in value
val
Address to store the starting address of the value
Description
These functions find the nvpair (name-value pair) that matches the name and type as indicated by the interface name. If one is found, nelem and val are modified to contain the number of elements in value and the starting address of data, respectively.
Return Values
These functions return 0 on success and an error value on failure.
Errors
These functions will fail if:
DDI_EINVAL
There is an invalid argument.
ENOENT
No matching name-value pair is found
ENOTSUP
An encode/decode method is not supported.
Context
These functions can be called from kernel non-interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Uncommitted
See also
attributes(5), pci_plist_get(9F), pci_plist_getvf(9F), pciv_vf_config(9F), pci_param_get_ioctl(9F)
