Siebel Hospitality Guide > Setting Up Properties > Setting Up Property Clusters > Assigning Clusters to a UserBefore a user can have access a cluster of properties, the cluster must be assigned to that user. Users can have as many clusters as necessary assigned to them, and clusters can be assigned to many different users. Before you carry out this procedure, you must create a cluster as described in Setting Up Property Clusters. This task is a step in Setting Up Property Clusters.
Siebel Hospitality Guide |
