Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the String Consolidation Utility > Splitting Consolidation Export Files into Smaller FilesWhen an export file is generated, you can split up into smaller, more manageable files. This is beneficial if you have exported a large number of symbolic strings and wish to import them in parallel running applications. To split the consolidation export files into smaller files
Using Siebel Tools |
