This chapter contains the following topics:
Section 3.1, "Understanding Case Management Setup Requirements"
Section 3.2, "Setting Up Case Management User Defined Codes (UDCs)"
Section 3.4, "Setting Up Processing Options for Case Management"
Section 3.8, "Setting Up Advanced Pricing Information for Cases"
Before you can use any of the features of the JD Edwards EnterpriseOne Case Management programs, you need to define information that the system uses for controlling and processing cases. You also need to specify information that is used when you enter data into the system, such as when you enter a case, and the method used to escalate cases. The escalation method is defined through the system constants. When you enter cases, you can also assign tasks to cases.
This section provides an overview of case management UDCs.
Before you can use any of the features of the support applications, such as JD Edwards EnterpriseOne Case Management, you need to define information that the system uses for processing. You also need to specify the data that is used when you enter cases in the system.
You can access most of these UDCs from the Case User Defined Codes menu (G17431). You can access all other UDC tables by entering UDC in the fast path field.
This table describes the information that you must set up for cases:
UDC | Type of Data |
17/PR | Case Priority |
17/CR | Case Reason |
17/SC | Case Source |
17/ST | Case Status |
17/CT | Case Type |
17/EN | Environment |
17/GR | Geographic Region |
H91/TZ | Time Zones |
17/WT | Work Type |
17/CB | Call Back |
17/TN | Task Name |
17/01 through 17/10 | Case Category Codes 1 through 10 |
00/RR | Object In Use Application ID.
Use this UDC table to check when objects are in use in specific applications and to limit access to a record to only one user at a time. Set this UDC to check access in the Case Revisions program (P90CG501). To activate record locking, enter 1 as the first character in the Special Handling Code field. If you do not want to activate record locking, enter 0 as the first character in the Special Handling Code field. |
01/ST | Address Book Search Type.
Set up a search type in the Address Book to define provider groups. |
To define default information for the entire system, you set up system constants. Constants control the types of information that you track and the rules that the system uses to perform calculations.
This section discusses how to set up Case Management constants. You must also set up the Customer Relationship Management (CRM) constants to activate the implicit save for case records.
Form Name | FormID | Navigation | Usage |
S/WM System Constants Revisions | W17001C | Case Setup (G90CG), Service and Warranty Constants | Set up case constants. |
Access the S/WM System Constants Revisions form.
Select the General tab.
Figure 3-1 S/WM System Constants Revision form: General tab
Select this option to check for any previous cases and work orders for the current customer number when you enter cases or work orders.
Select this option to check for any previous cases and work orders for the current product (inventory number) when you enter cases or work orders.
Select the Case tab.
Figure 3-2 S/WM System Constants Revision form: Case tab
Enter the value from UDC 01/ST that specifies the Address Book search type for provider groups. When you add a provider group through the Provider Group Revisions program (P17506), the record is added to the F1797 table and the F0101 table with this search type.
Enter a code which determines which table the system uses to retrieve the responsible business unit for billing cases. Values are:
1: Inventory table (F4117/F41171).
2: Product Family/Model table (F1791).
3: Equipment table (F1201).
4: Customer Number table (F0101).
5: S&WM Line Type (Service and Warranty Management line type) table (F1793).
6: S&WM Customer Number (Service and Warranty Management customer number) table (F1797).
Enter a value from UDC 00/TY to indicate the classification type of request that is used for an entitlement check. The default value is W (case).
Enter value from UDC 02/MB to define the location to hold messages for escalation.
Enter a value from UDC 17/ET to specify which field activates entitlement checking when you enter a case.
Select the escalation method. Values are:
0: Do not use an escalation method.
1: Escalate using notification.
Escalations are processed using the work center notification and by email.
2: Escalate using skill-levels.
See Setting Up Case Priorities Using Notification Escalation Method.
and
See Setting Up Priorities Using Skill-Level Escalation Method.
Select this check box to create a message for the case and the task records. You can view the message in the Work Center.
Reserved for future use.
Select this check box to specify whether the caller name for a case is required and must reside in the Address Book - Who's Who records. If this check box is selected, you cannot add the case unless the caller name is selected from the visual assist and resides in the F0111 table.
Select this check box to specify whether the system records call status changes to the text that is associated with a case. If you select this check box, the system generates a line of text that includes the original status, the new status, the user, and a date and time stamp.
Select this check box to specify whether the system uses base price for calculating case price. Select this field if you are using base pricing. If you are using advanced pricing, do not select this field; you need to set up additional fields for advanced pricing, which is discussed later in this chapter.
Select this field to specify whether to use the Solution Advisor application. If you do not select this field, the system will use failure analysis.
See Setting Up Solution Advisor.
and
Processing options enable you to specify the default processing for programs and reports.
This section discusses how to set processing options for:
The Case MBF Processing Option program (P90CG002).
See Setting Processing Options for the Case MBF Processing Options Program (P90CG002).
The Case Entry program (P90CG504).
See Setting Processing Options for the Case Entry Program (P90CG504).
The Case Update program (P90CG501).
See Setting Processing Options for the Case Update Program (P90CG501).
The Case CSS Inquiry and Add program (P90CG900).
See Setting Processing Options for the Case CSS Inquiry and Add Program (P90CG900).
The CSS Case Update program (P90CG910).
See Setting Processing Options for the CSS Case Update Program(P90CG910).
The Tasks program (P17504).
See Setting Up Processing Options for the Tasks Program (P17504).
The Work With Case program (P17500).
See Setting Up Processing Options for the Work With Case Program (P17500).
The Speed Case Entry program (P90CG601).
See Setting Processing Options for Speed Case Entry (P90CG601) (Release 9.1 Update).
The Time Entry program (P17505).
CRM Case Related Actions (P90CG503).
See Setting Up Processing Options for CRM Case Related Actions (P90CG503).
Before you can process case information, you must set the processing options for several programs. These programs define and control how information is processed when you enter and revise cases. If you are using Customer Self Service, you must also define the processing options for CSS Inquiry and Add and CSS Case Update programs.
Note: This section includes only those processing options that are required to be set up during implementation and are used to define system-wide processes. To access these processing options, enter IV in the fast path, and then enter the program ID in the Interactive Application field. |
Use these processing options to define the basis for the JD Edwards EnterpriseOne Case Management system.
Access the Default tab.
Use this processing option to specify the document type for the case. Enter a value from UDC 00/DT (Document Type).
Use this processing option to specify whether the symptoms information is automatically filled in using the first line of the media object text. Values are:
Blank: Do not use the first line of the media object text.
1: Use the first line of the media object text as the symptom.
Use this processing option to indicate whether the system uses the Customer Name as the Caller Name. Values are:
Blank: Do not use the customer's name as the caller name.
1: Use the customer name as the caller name.
Use this processing option to determine whether the system uses the user ID as the default assignee. Values are:
Blank: Do not use the user ID as the default for the assignee.
1: Use the user ID as the default for the assignee.
Use this processing option to specify whether the system uses the reporting codes of the assignee from the S/WM Address Book Information table (F1797). Values are:
Blank: Do not use reporting codes from the S/WM Address Book Information table.
1: Use reporting codes from the S/WM Address Book Information table.
Use this processing option to define the phone number type for fax number. This is user defined code (01/PH) that indicates the use of the phone number.
Use this processing option to specify the default status when the system assigns the case. Enter a value from UDC 17/ST.
Use this processing option to indicate the default Provider Group number. The Provider Group number that you enter in this processing option overrides the Provider Group from routing rules.
Use this processing option to specify the case type that the system uses as a default for the Work With Case program (P17500). Enter a value from UDC 17/CT. If you leave this processing option blank, the system uses the default value from the data dictionary.
If you are billing for calls and the pricing method is flat rate, use this processing option to specify the default cost type. Typically, enter B1 (Direct Labor) as the default, or you can enter another value from UDC 30/CA (Cost Component Add-Ons).
Use this processing option to specify the default pricing units on cases if you are billing for case and the pricing method is flat rate. Pricing units are quantities that the system uses to retrieve advanced pricing information, such as for price break levels based on quantities. Enter a number or use the default, which is 0 (zero).
Use this processing option to specify the default unit of measure used by the system to retrieve advanced pricing information. This option is used for billing for maintenance requests in which the pricing method is flat rate. Enter a value from UDC 00/UM (unit of measure). If you leave this processing option blank, the system uses EA (each).
Use this processing option to indicate the default Call Reason.
Use this processing option to indicate the default Responsible Business Unit.
Access the Display tab.
Use this processing option to determine whether the system displays the routing information after pressing the OK button. Values are:
Blank: Hide routing information.
1: Display routing information.
Use this processing option to determine whether the system displays the equipment information when the Customer Number is entered. Values are:
Blank: Do not display equipment information.
1: Display equipment information.
Use this processing option to determine whether the Who's Who Search and Select appears when you move past the Customer Number field and the Caller Name field is blank. Values are:
Blank: Do not display the Who's Who Search and Select form.
1: Display the Who's Who Search and Select form.
Access the Versions tab.
Use these processing options to specify the default version of each program. These processing options do not apply to the Case application (P17501E). The default version of each program is listed here:
Work With Previous Customer Case (P17500) Version.
Default version = ZJDE0002.
Work With Previous Product Case (P17500) Version.
Default version = ZJDE0003.
Case History (P17500) Version.
Default version = ZJDE0004.
Work With Tasks (P17504) Version.
Default version = ZJDE0001.
Time Entry (P17505) Version.
Quick Customer/Contact Add (P01015) Version.
Address Book Revisions (P90CA080) Version.
Customer Master (P90CA080) Version.
Customer Ledger Inquiry (P03B2022) Version.
Vendor Master (P04012) Version.
A/P Standard Voucher Entry (P0411) Version.
Payment Inquiry (P0413M) Version.
Eligibility (P08334) Version.
Employee DBA Instructions (P050181) Version.
Employee Profile (P060116) Version.
Work With Employee (P0801) Version.
Sales Order Entry (P42101) Version.
Default version = ZJDE0006.
Supply and Demand Inquiry (P4021) Version.
Inquiry by Equipment (P48201) Version.
Work Order Revisions (P17714) Version.
Supplemental Data - Customer (P00092) Version
Supplemental Data - Item (P00092) Version.
Supplemental Data - Work Order (P00092) Version.
Default version = ZJDE0007.
Supplemental Data - Sales Order (P00092) Version.
Default version = ZJDE0018.
Equipment Master Inquiry (P1701) Version.
Equipment Master Revisions (P90CD0001) Version.
Contracts (P1720) Version.
Print Case (R17674) Version.
Case Workfile Generation (R17675) Version.
Service Billing Inquiry (P4812) Version.
Failure Analysis Tree Search and Select (P17763S) Version.
Work with Failure Analysis (P17766) Version.
Failure Analysis (P17767) Version.
Failure Analysis Search and Select (P17768) Version.
Access the Edits tab.
Use this processing option to specify how the system performs the entitlement check. Values are:
Blank: Do not perform entitlement checking.
1: Check the entitlement with the date table (F1791).
2: Check the entitlement without the date table (F1791).
Use this processing option to specify the maximum number of days that you can reopen a closed case. If you leave this processing option blank, you cannot reopen a closed case.
Use this processing option to specify whether the system uses the current date and time as the beginning date and time when you reopen a case. Values are:
Blank: The original date and time that the case was opened remain on the case.
1: The system uses the current date and time as the beginning date and time for the case.
Use this processing option to specify whether to clear the date and time when a case is reopened. Values are:
Blank: Leave the original date and time in the case.
1: Clear the date and time in the case.
Use this processing option to specify whether the system requires you to enter the area code and phone number when you enter a case. Values are:
Blank: Require the area code and phone number.
1: Do not require the area code and phone number.
Use this processing option to specify whether to require a reason code when you close a case. Values are:
Blank: Do not require a reason code.
1: Require a reason code.
Access the Process tab.
Use this processing option to specify whether the system copies media object text when you copy a case. Values are:
Blank: Do not copy media object text.
1: Copy media object text.
Use this processing option to determine where the Date/Time Stamp is printed in the comments area. You can choose to have the date/time stamp precede the comments (at the top) or after the comments (at the bottom). Values are:
Blank: Print the date/time stamp on top of comments.
1: Print the date/time stamp at the bottom of comments.
Use this processing option to indicate whether the queue number can be changed. Values are:
Blank: Allow changes to the queue number.
2: Do not allow changes to the queue number.
Use this processing option to specify whether the system prevents changes to the pricing method when you create a maintenance request. Values are:
Blank: Allow changes to the pricing method.
1: Prevent changes to the pricing method.
Note: If you allow changes to the pricing method, you can choose the flat rate pricing method, or the time and materials pricing method. |
Use this processing option to specify whether the system verifies that the customer number on the case matches the customer number on the equipment master. If the customer numbers are different, you can specify whether the system updates the equipment master. Values are:
Blank: Do not compare the customer numbers.
1: Display a prompt to update the customer number on the equipment master to match the customer number on the case.
2: Automatically update the customer number on the equipment master to match the case customer number.
Use this processing option to specify whether the system verifies that the site number for the case matches the equipment master site number. If the site numbers are different, you can specify whether the system updates the equipment master. Values are:
Blank: Do not compare the site numbers.
1: Display a prompt to update the site number to the equipment master to match the case site number.
2: Automatically update the site number to the equipment master to match the case site number.
Use this processing option to determine when the assignee that is entered is set up in the queue. Values are:
Blank: Do not check whether assignee is in queue.
1: Display error when assignee is in queue.
2: Display warning when assignee is in queue.
Use this processing option to specify whether the system verifies that there is information in the required fields. You define which fields are required in the Required Fields Setup (P1759) program or Status Rules Setup. Values are:
Blank: Do not check the required fields.
1: Check the required fields.
Use this processing option to specify whether to bill for maintenance requests. You must activate this processing option if you need to enter billing information for maintenance requests. Values are:
Blank: Do not bill for maintenance requests.
1: Bill for maintenance requests.
Use this processing option to specify whether the system captures next numbers that are temporarily assigned, but not used on permanent records. Values are:
Blank: Do not capture burned next numbers.
1: Save burned next numbers as status 3.
Access the Vertex tab.
Use this processing option to specify the default transaction type for flat rate billing. If you leave this option blank, the system uses SERVIC.
This processing option only pertains if Vertex's Quantum Sales and Use Tax Software (third-party tax software) has been implemented.
Use these processing options to set up default processing for the Case Entry Program (P90CG504).
Use these processing options to define the default version of the P90CG002 and P90CG501 programs. If you leave these options blank, the system uses version ZJDE0001.
Use these processing options to define default processing for the Case Update program (P90CG501).
Access the Version tab.
Use this processing option to define the default version of the P90CG002 program. If you leave this option blank, the system uses version ZJDE0001.
Use these processing options to define default processing for the Case CSS Inquiry and Add program (P90CG900).
Use these processing options to define the default versions of the P90CG904 and P90CG910 programs. If you leave these options blank, the system uses version ZJDE0001.
Use these processing options to define default processing for the CSS Case Update program (P90CG910).
You can configure the work space by setting processing options to include only the information with which you work directly. Some of the available options include case sequencing, sorting cases by priority or status, and preloading information to the work space to limit the information that appears. You can also lock tasks so that only one user at a time can review and change case information.
The processing options on this tab define the defaults that the system uses when you run inquiries on tasks. Although you can override these values to search for tasks, you can specify defaults that are standard to most tasks on which you run inquiries in this version of Work With Tasks.
Specify the From status or the To status. The system displays only those tasks that are within the status specified in the From status and To status processing options.
Specify the document type for the system to use when you add a task directly through the Work With Tasks program. Document type CL (call) is the default. Enter document type if the case document type is different.
Define the case status code from UDC 17/ST to use when a task is assigned.
Specify the user as the default for the assignee. The system displays task that are assigned to the user. Values are:
Blank: Do not specify.
1: Specify.
Specify the document type for the system to use when you add a task directly through the Case Update program. The document type CL (call) is the default. Enter the document type if the case document type is different.
The processing option on this tab defines what information the system verifies when you enter a task.
Specify the maximum number of days that a task can be closed and reopened. This processing option specifies the number of days that a closed task is eligible to be reopened. If you leave this processing option blank, the program does not check the number of days. Otherwise, enter a number to specify the number of days in which a user can reopen a task after it is closed.
The processing options on this tab define the processing that the system performs for this version of Work With Tasks.
Specify whether the system verifies that there is information in the required fields. You define which fields are required in the Required Fields Setup program (P1759). Values are:
Blank: Do not check.
1: Check.
Specify whether the system sends notification when a task is entered or closed. Values are:
Blank: Do not send.
1: Send notification to provider group when task is entered and to originator when task is closed.
Specify whether the system sends notification to the assignee. Values are:
Blank: Do not notify.
1: Notify.
Specify if the system notifies the provider group. Values are:
1: Notify.
Use this processing option to specify whether to bill for maintenance requests. You must activate this processing option if you need to enter billing information for maintenance requests. Values are: Blank Do not bill for maintenance requests. 1 Bill for maintenance requests.
These processing options control the version that the system uses when it calls these programs:
Use these processing options to specify the default version. If you leave these processing options blank, the system uses the ZJDE0001 default version.
You can customize the work space by setting processing options to include only the information with which you work directly. Some of the available options include case sequencing, sorting cases by priority or status, and preloading information to the work space to limit the information that appears. You can also lock cases so that only one user at a time can review and change case information.
The processing options on this tab indicate the information that the system displays when you run inquiries on cases using this version of Work With Case. For example, you can set up these processing options so that the system only displays those cases within a status range based on a time zone, call back time, country code, and language.
Specify whether the system verifies the time zone of the customer. The system displays cases based on time zones. Values are:
Blank: Bypass time zone filter.
1: Check time zone filter.
If you select the option to check the time zone and then set the processing option to verify a call back time, the system verifies whether the time at the customer's location in the customer's time zone is within business hours. If the customer time is earlier or later than the business hours, the system does not display the calls.
Specify the call-back time to filter calls. If the time at the customer location is earlier than this time and time zone filter check box on the Work With Case form is selected, the system does not display the calls. When you enter a call-back time, you must enter military time and include the hour, minutes, and seconds. For example, 130000 for 13:00:00.
If you set this processing option to verify a call back time and select the option to check the time zone filter, the system verifies whether the time at the customer's location is earlier than that current time. If the customer time is earlier than the current time, the system does not display the calls.
Specify whether the system displays the Country Code field for you to use as selection criteria. Values are:
Blank: Hide.
1: Display.
If you display the country codes, you can indicate selection criteria that the system uses to display calls. To specify which country code the system uses as a default, set the Default Country Code processing option.
Specify whether to display the Language field. Values are:
Blank: Hide.
1: Display.
If you select to display languages, you can indicate selection criteria that the system uses to display calls. To specify which language the system uses as a default language, set the Default Language processing option.
Specify the From status or the To status. The system only displays those cases that are within the status specified in the From status and To status processing options.
Specify a number of days with which the system uses to calculate the Date Entered From/Thru fields. The system displays only cases within this date range.
If you leave this processing option blank, the system does not calculate filter dates.
Specify whether the system displays priority with color. The color setup is defined in UDC 17/PR in the Special Handling column. Values are:
Blank: Without color.
1: With color.
Specify whether the system displays the cases that are currently in use by a user. Cases that are in use are locked in the system so that only one user at a time can access case information. Values are:
Blank: Display locked cases.
1: Do not display locked cases.
The processing options on this tab define the defaults that the system uses when you run inquiries on cases. Although you can override these values to search for cases, you can specify defaults that are standard to most cases on which you run inquiries in this version of Work With Case, such as country code, language code, assignee, and provider group.
Specify the country code that the system uses when the Country Code field appears. The system displays cases that have this country code.
If you leave this processing option blank, the system does not use a specific country code in the selection criteria.
You must also set the Display Country Code processing option on the Display tab to display country codes.
Specify which language to retrieve as the default language when the Language field is displayed. The system displays only cases that indicate this particular language preference.
If you leave this processing option blank, the system does not retrieve a default language.
You must also set the Display Language processing option on the Display tab to display languages.
Specify the user as the default for the assignee. The system displays cases that are assigned to the user. Values are:
1: Specify.
Specify the default provider group in the selection criteria. The system displays only cases that are assigned to this provider group. Values are:
0: Do not specify.
Specific queue: Specify.
Use this processing option to specify the default document type.
Use this processing option to specify the default case reason.
Use this processing option to specify the default responsible business unit.
The processing options on this tab defines the versions that the system uses when it calls these programs:
Use this processing option to specify the default version of the program. If you leave this processing option blank, the system uses the ZJDE0001 default version.
Use this processing option to specify the default version of the program. If you leave this processing option blank, the system uses the ZJDE0005 default version.
The processing options on this tab define the processing that the system performs for this version of Work With Case.
Specify whether the system deletes records from the F17500 table. Values are:
Blank: Delete.
1: Do not delete, but change its status to 4.
Specify whether you want to use the Case Add program (P90CG504) or the Speed Case Entry program (P90CG601) to add new case records. Values are:
Blank: Do not use the Speed Case Entry program to add new case records.
1: Use the Speed Case Entry program to add new case records.
Specify whether you want to use the Case Update program (P90CG501) or the Speed Case Entry program (P90CG601) to update existing case records. Values are:
Blank: Do not use the Speed Case Entry program to update existing case records.
1: Use the Speed Case Entry program to update existing case records.
Specify whether the Customer groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Blank: Section closed in both add mode and update mode.
1: Section open in both add mode and update mode.
2: Section closed in add mode and open in update mode.
3: Section open in add mode and closed in update mode.
Specify whether the Issue Description groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the Attachments groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the Case Detail groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the Product Information groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the Category Codes groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the Additional Information groupbox is open or closed when you open the Speed Case Entry form and the Case Revisions form. Values are:
Specify whether the User Reserved Fields groupbox is open, closed, or hidden when you open the Speed Case Entry form and the Case Revisions form. Values are:
4: Section hidden in both add mode and update mode.
Specify the value that you want to use for cancelled status of a case. The system uses this value in the Cancel Case button. If you leave this processing option blank, the system uses 997 as the default value.
Specify the default version of the Case Master Business Function program (P90CG002). You use this processing option to control the versions of the programs that you access from the Row menu. If you leave this processing option blank, the system uses the ZJDE0001 default version.
Specify whether the system validates the problem code against failure codes. If you set this processing option to validate problem codes against failure codes, the Problem field is disabled in the Case Revisions form and the system uses the failure description as the default problem description. If you do not set this processing option to validate problem codes against failure codes, you can edit the value in the Problem field to override the failure description. Values are:
Blank: Do not validate.
1: Validate.
When you resolve a case, you need to enter time in order to accurately capture the amount of time spent on the issue for billing purposes. If you have contract and warranty agreements with customers that do not require billing by the hour, you still might need to report the time for accounting purposes. You can set the processing options to create either payroll batch transactions or general ledger transactions.
Setup options determine which stages of a case require time entry. You can set up the system to display the time entry form at any status change or only when the case is closed.
When you enter a case, the system calculates time entry information based on the time when you access the Case Entry form and the time when you exit the form. You can override the information, if necessary.
The processing options on this tab define the processes that the system performs during time entry.
Specify the tables to which the system writes the time entry records. Values are:
Blank: Only F17860 table.
1: F0911Z1 and F17860 tables.
2: F06116Z1 and F17860 tables.
Specify whether you can change the time entry line when you inquire on time entry information. Values are:
Blank: Do not protect.
1: Protect.
Specify how to display the actual hours worked. Values are:
Blank: Display actual hours.
1: Round to the quarter hour.
2: Round to a tenth of an hour.
3: Round to the half hour.
Specify whether to round the billable hours. Values are:
Blank: Do not round.
Specify whether to protect the information in the Minimum Hours and the Minimum Amount fields. Values are:
1: Protect.
(Future Use) Specify whether to use flex accounting. Values are:
Blank: Do not use.
1: Use.
The processing options on this tab define the defaults that the system uses during time entry.
Specify the default hour type description code from UDC 17/WT. If you leave this processing option blank, the system does not retrieve the description.
Specify the default cost type if you bill for cases and the pricing method is time and materials.
Typically, you enter B1 (direct labor) as the default, or you can enter another value from UDC 30/CA (cost component add-ons).
Specify the labor unit of measure for the Time Entry program.
Enter a value from UDC 00/UM. If you leave this processing option blank, the default for the Labor Unit of Measure field is HR (hours).
Specify the minimum hours on each time entry record. If you leave this option blank, the default for the Minimum Hours field is 0.
Specify the information that the system records in the Subledger field when you create time entry records for the F06116Z1 or the F0911Z1 table. Values are:
Blank: Leave the Subledger field blank.
1: Case number.
2: Customer number.
3: Site number.
4: Short item number.
5: Contract number.
6: Equipment number.
Specify the unit of time that the system uses for the Hour field, such as HR. The system uses this processing option for Labor Unit of Measure conversion.
You must specify a value for this processing option if you want the system to upload the time entry record to the F06116Z1 table.
Specify the default value for the PDBA code. The PDBA code defines the type of pay, deduction, benefit, or accrual. If you leave this processing option blank, the system leaves the PDBA code blank.
Pay types are numbered from 1 to 999. Deductions and benefits are numbered from 1000 to 9999.
The processing option on this tab defines the Vertex transaction type for labor billing.
Specify the Vertex transaction type that the system uses when calculating taxes for time entry billing. Use this transaction type only if you bill for cases and the pricing method is Time and Materials.
Enter a value from UDC 83/TY (Vertex Transaction Type). If you leave this processing option blank, the system uses the transaction type SERVIC.
From the Case Revisions form or the Case Entry form, you can create and review a list of actions related to the case. Through the Related Actions tab, you can access other programs to associate sales orders, quotes, work orders, returned material authorization (RMA), scripts, action plans, and leads to cases.
Use this processing option to specify the default version of the program. If you leave these processing options blank, the system uses the ZJDE0001 default version.
This sections provides an overview of business object reservations, lists a prerequisite, and discusses how to use business object reservations.
Use the Business Object Reservation program (P00095) to view records, such as cases, that are locked. This program is shared by other programs as well, such as the Employee Master program and the Work Order Entry program, to review and unlock records. You can use this program to unlock records that have been locked because of system issues.
You must define the program as a value in the Object in Use Application ID UDC (00/RR). For example, if you want to view cases that are locked, you must set up the Case Update program as a value in the Object in Use Application ID UDC.
Business Object Reservations | W00095A | Periodic Support Processing (G90CE02), Business Object Reservations | Search for records that are locked.
If you want to unlock a record, select the record and click theDelete button. |
Access the Business Object Reservations form.
Enter the name that identifies a system object in the header area or on the Query By Example (QBE) line. Examples of system objects include:
Batch applications (such as reports)
Interactive applications
Business views
Business functions
Business function data structures
Event rules
Media object data structures
Enter the batch or interactive program number in the QBE line.
You can define the fields in which you are required to enter information before the system advances a case to the next status in the queue. Required fields can be based on specific request document types, request queues, and request types; or they can be set up to cover all document types, queues, and request types. For example, when a live request (call type 1) appears in the VIP queue and you advance it to the complete status (999), you can complete the reason field (CALLRN).
This section lists a prerequisite and discusses how to set up required fields for Case Management.
Set the Check Required Fields processing option to enable the system to verify that information exists in the required fields.
Work With Case Required Fields | W1759B | Case Setup (G90CG), Required Fields
On the Work With Case Required Fields form, enter the table number in the File Name field and click Find. |
Define required fields. |
Access the Work With Case Required Fields form.
Figure 3-3 Work With Case Required Fields form
Complete the form to set up required fields for cases.
Enter the table name. Enter F1755 to specify Case Master table, and F1757 to specify Task Master table.
Enter the alias. You cannot change the alias.
If you set up required fields for cases, you select data item fields from the F1755 table.
If you set up required fields for tasks, you select data item fields from the F1757 table.
Set up activity rules to define how the system processes cases.
This section provides an overview of case activity rules and discusses how to set up activity rules.
You can set up activity rules for cases to define the status flow for cases and to define the next step, based on the current status. To have the system proceed to the next step, you must enter the next status in the Last Status field. If you do not include the next status, the case is considered complete. If you enter an open status code in one of the other columns, you can reopen the case.
Case Provider Group Status Revisions | W17506D | Case Setup (G90CG), Provider Group Revisions
Select Provdr Group Status (provider group status) from the Form menu on the Work With Provider Groups form. |
Define activity rules for cases. |
This table is an example of how you might set up case statuses. The Last Status column shows the status of the case and the Status Description column provides a description of the status. The remaining columns in the table show the next statuses that are allowable for the case at the last status. For example, you can change an open case (100) to an active case (150). Then you might leave a message (250), or you might cancel the case (997). A case that has the last status of Complete (999) can be reopened (100).
Last Status | Status Description | Next Status | Other | Other |
100 | Open | 150 | 250 | 997 |
150 | Active | 999 | ||
250 | Left Message | 999 | ||
997 | Cancel | |||
999 | Complete | 100 |
Access the Case Provider Group Status Revisions form.
Figure 3-4 Case Provider Group Status Revisions form
Enter a code that specifies the status of a case.
Enter an active customer issue status. This is used as default status when a user activates a customer issue.
If you consider the last status that you enter to be a closed case, leave this field blank. If the Next Status field is blank, the system treats the case as closed. If you want to be able to reopen a closed case, enter the Open status in one of the Other status fields.
Enter a code that specifies whether you can change a case that has a particular status.
Enter a code that specifies whether the system can update a case that has a particular status.
Enter a code that specifies whether the system displays a time entry form for a particular status.
Enter a code that specifies whether the system displays a failure analysis form for a particular status.
This section provides an overview of Advanced Pricing for Case Management and lists a prerequisite.
You can attach an advanced pricing adjustment schedule to a case. Setting up advanced pricing for cases enables you to price items and services by using an advanced pricing structure, and it enables you to streamline pricing setup and maintenance.
A price and adjustment schedule contains one or more adjustment types for which a customer or an item might be eligible. The system applies the adjustments in the sequence that you specify in the schedule. You link customers to a price and adjustment schedule through the customer billing instructions.
When you enter a case, the system copies the schedule attached to the sold-to address into the order. You can override this schedule at the header level.
To set up advanced pricing for cases, you follow the same steps that you use to set up advanced pricing for Service Management.
Before you can attach an adjustment schedule to a case, you must complete these tasks:
Set up preference hierarchies.
Set up customer service detail groups.
Set up price adjustment definitions.
Set up adjustment schedules.
Set up adjustment details.
See Understanding Case Management Billing.
and
