This chapter contains the following topics:
To pay employees correctly for exception pay such as overtime, retroactive pay, holiday pay, or special allowance pay, many organizations require complex calculations. Though many of these complex overtime calculations are included in the software, you might need to create functions and formulas for more complex earnings calculations.
This section includes an overview of functions and discusses how to register functions.
The Fields and Functions program (P186101) enables programmers and consultants to access field and function definitions that are used throughout the Timecard Automation module. A field is an area in which the system displays a specific piece of information. A field can be either an input-capable field or a display field, for which the system retrieves the information from another part of the system. For example, the TIN (taxpayer identification) field displays taxpayer identification numbers. A function is a calculation with variables that the system uses to perform specific actions. For example, you can use the timecard rate function on its own or in a formula to find employees' timecard rates.
To use different fields and functions in the Timecard Automation module, you must first register the field or the function in the Fields and Functions program. The fields in the F060116, F06116, and F0618 tables are preregistered in the system. Several additional functions have also been registered in the Fields and Functions program.
The system includes several functions for calculating common methods of determining hourly rates and hours worked. When you create a timecard template, overtime rule set, or retroactive pay rule, you can use one or more of these functions. Because each function is specific to a field in a specific program, the system limits the available functions to those that are applicable to the calling program. For example, the function that is available for calculating the hourly rate for a timecard template is different from the function that is available for calculating the hourly rate for a retroactive pay rule.
You can use a function alone, or you can create a formula that includes one or more functions. Use the Fields and Functions program (P186101) to create custom formulas. You can also use this program to validate and test a formula before you begin using it.
Occasionally, you might need a function that is not included with the system. In this case, you can customize the system by adding a new function. Typically, you create custom functions using named event rules through the Business Function Design Aid tool, which you access from the Object Management Workbench (OMW). You can also create custom business functions using C programming. Programmers or consultants typically create custom business functions. Oracle recommends that you contact the system administrator for assistance with creating custom functions. After you create a custom function, you must register it for use in the applicable Timecard Automation program. Registering the function enables you to access it from the applicable program.
To simplify the process of creating formulas for calculating hourly rates and hours worked, the Timecard Automation module includes several predefined functions. You can use these functions alone or include them in formulas. These functions include:
Hours worked function for timecard templates.
Hours worked function for retroactive pay rules.
Hourly rate function for timecard templates.
Hourly rate functions for retroactive pay rules.
Hourly rate functions for overtime accumulator rules.
To meet the specific needs of the organization, you can also create custom functions. Each function uses a data structure, which lists the data item name, the input or output status, and a description of the data item.
The hours worked function for timecard templates is included in the Template Hours Worked Functions module (N1861312). This function uses data structure D186132. You also use this data structure when you create a custom hours worked function for timecard templates. This table illustrates input and output information about the data items in this data structure:
Data Item | Additional Information |
LRSTTID | Input: Timecard Template ID |
AN8 | Input: Address Number (Employee Number) |
PHRW | Output: Hours Worked |
The predefined hours worked function for timecard templates is THWF_8HoursIf8OnPrevWorkDate.
The 8 Hours if Employee Worked 8 or More Hours on a Previous Day function returns eight hours worked if the employee worked eight or more hours, not including sick pay, on the previous work date. Saturdays and Sundays are not considered work dates. If the employee did not work at least eight hours, the returned value is zero. The work date is identified on the timecard template in the Work Date Schedule. For example, you might use this function if you want the timecard template to use eight hours for the amount of work an employee is paid each day, based on the criteria specified.
The hours worked function for retroactive pay rules is included in the Retropay Hours Worked Functions module (N1861712). This function uses data structure D186172. You also use this data structure when you create a custom hours worked function for retroactive pay rules. This table lists examples of input and output information about the data items in this data structure:
LRSRRID | Input: Retroactive Pay Rule ID |
PRTR | Input: Payroll Transaction No |
LRSCHF | Input: Current/History option. This option indicates whether the payroll transaction number refers to a current timecard in the F06116 table or a historical timecard in the F0618 table. |
AN8 | Input: Address Number |
DWK | Input: Date - Worked |
PDBA | Input: PayDeductBenAccType |
The predefined hours worked function for retroactive pay rules is RHRF_TimecardHours.
The hours worked on timecard function returns the hours worked from the Rate Hourly field on a timecard currently being processed by a retroactive pay rule for one of the pay types that you identify. For example, you might use this function when you pay employees retroactive pay for the hours worked, based on their original timecards.
The hourly rate functions for timecard templates are included in the Template Hourly Rate Functions module (N1861311). These functions use data structure D186131. You also use this data structure when you create a custom hourly rate function for timecard templates. This table lists examples of input and output information about the data items in this data structure:
SHRT | Output: Hourly Rate |
TCTD | Output: TimecardThruDate |
EV01 | Input: EverestEventPoint01 |
The predefined hourly rate function for timecard templates is THRF_EmployeeMasterRate.
The Employee Master Rate function returns the rate from the Rate-Hourly field in the F060116 table for the employee records that are processed using the timecard template. For example, you might want to pay an employee based on the established master pay rate.
The hourly rate functions for retroactive pay rules are included in the Retropay Hourly Rate Functions module (N1861711). These functions use data structure D186171. You also use this data structure when you create a custom hourly rate function for retroactive pay rules. This table lists examples of input and output information about the data items in this data structure:
LRSCHF | Input: Current/History option. This option indicates whether the payroll transaction number refers to a current timecard in F06116 or a historical timecard in F0618. |
The predefined hourly rate functions for retroactive pay rules are:
RHRF_EmployeeMasterRate
The Employee Master Rate function returns the rate from the Rate-Hourly field in the F060116 table for the employee on the current timecard that the system is processing using the retroactive pay rule. For example, you might want to pay employees retroactive pay based on the master hourly pay rate.
RHRF_MaxRate
The Maximum Rate from Timecard vs. Employee Master function returns the greater rate of the timecard hourly rate from the Hourly Rate field or the employee master hourly rate from the Rate-Hourly field. For example, you might want to pay employees retroactive pay based on either the master hourly pay rate or the timecard hourly rate. This function provides the larger of these two hourly rates.
RHRF_PayRateMultiplier
The Pay Rate Multiplier function returns the pay rate multiplier from the Multiplier-Pay Type Multiplier field on the current timecard that the system is processing using the retroactive pay rule.
RHRF_TimecardRate
The Timecard Rate function returns the hourly rate from the Hourly Rate field on the current timecard that the system is processing using the retroactive pay rule. For example, you might want to pay employees retroactive pay based on the rate on the timecard instead of another rate.
RHRF_UnionRateX where X is A, B, C, D, or R
The Union Rate X function returns the rate for a chosen employee from a particular column of the F069126 table. You identify the appropriate column. This function returns the union rate by calling the Retrieve Union Rates function (N0500015) and using fields on the current timecard that the system is processing in the retroactive pay rule. For example, you might want to pay employees retroactive pay based on a particular union rate. This function provides you with the appropriate union rate.
RHRF_WeightedAverageHourlyRate
The Weighted Average of Employees' Timecards in Retroactive Pay Period function returns an hourly rate weighted by hours worked. The function uses all timecards in the overtime period for one of the pay types that you identify. For example, you might want to pay employees retroactive pay based on an average of the hourly pay rates received in the past.
The hourly rate functions for overtime accumulator rules are included in the Overtime Hourly Rate Functions module (N1861411). These functions use data structure D186141. You also use this data structure when you create a custom hourly rate function for overtime accumulator rules. This table lists examples of input and output information about the data items in this data structure:
LRSORSID | Input: Overtime Rule Set ID |
LRSORID | Input: Overtime Rule ID |
GENLNG | Input: GenericLong |
The predefined hourly rate functions for overtime accumulator rules are:
OHRF_EmployeeMasterRate
The Employee Master Rate function returns the hourly rate from the Rate-Hourly field (PHRT) in the F060116 table for the employee that the system is processing using the overtime rule set. For example, you might want to pay employees overtime pay based on the master hourly pay rate.
OHRF_HoursWorked
The Hours Worked on Timecard function returns the hours worked from the PHRW field on the current timecard that the system is processing using the overtime rule set. For example, you might want to pay employees overtime pay based on the hours worked on the current timecards.
OHRF_MaxRate
The Maximum Rate from Timecard vs. Employee Master function returns the greater rate of the timecard hourly rate from the Hourly Rate field (SHRT) or the hourly rate in the Rate-Hourly field (PHRT) in the Employee Master table. For example, you might want to pay employees overtime pay based on either the master hourly pay rate or the timecard hourly rate. This function provides the higher of these two hourly rates.
OHRF_PayFrequency
The Employee Master Pay Frequency function returns an employee's numeric pay frequency (which is derived from the Description 2 field in UDC 07/PF) based on the value in the PFRQ field (Pay Frequency) on an employee record. For example, this function would convert a value of W (Weekly) in the PFRQ field to the numeric value of 52, which can then be used in payroll calculations.
OHRF_PayRateMultiplier
The Pay Rate Multiplier function returns the pay rate multiplier from the Multiplier-Pay Type Multiplier field (PAYM) on the current timecard that the system is processing using the overtime rule set.
OHRF_Salary
The Employee Master Salary function returns the employee's salary from Rate-Salary, Annual field (SAL) on an employee record for the employee being processed by the overtime rule. For example, you might want to pay employees overtime pay based on the master salary.
OHRF_TimecardRate
The Timecard Rate function returns the hourly rate from the Hourly Rate field on the current timecard that the system is processing using the overtime rule set. For example, you might want to pay employees overtime pay based on the rate on the timecard instead of another rate.
OHRF_TotHoursWorked
The Total Hours Worked function returns the total hours worked by a given employee within the overtime period for a pay type of one of the pay types that you identify. For example, you might want to pay employees overtime pay based on the total hours that each employee worked.
OHRF_UnionRateX where X is A, B, C, D, or R
The Union Rate X function returns the rate for a chosen employee from a particular column of the Union Rates File table (F069126), where you identify the appropriate column. This function returns the union rate by calling the Retrieve Union Rates function (N0500015) using fields on the current timecard that the system is processing using the overtime rule set. For example, you might want to pay employees overtime pay based on a particular union rate. This function provides you with the appropriate union rate.
OHRF_WeightedAverageHourlyRate
The Weighted Average of Employees' Regular Timecards in Overtime Period function returns an hourly rate weighted by hours worked. The function uses all timecards in the overtime period for a pay type of one of the pay types that you identify. For example, you might want to pay employees overtime pay based on an average of the hourly pay rates received in the past.
The predefined functions for custom overtime rules are included in the Custom Overtime Rules module (N186405). These functions use data structure D186405A. You also use this data structure when you create a custom hourly rate function for overtime accumulator rules. This table lists examples of input and output information about the data items in this data structure:
LRSBAT | Input: LRS Batch Number |
GNUM0 | Output: Timecards Processed |
GNUM1 | Output: Timecards Created |
GNUM2 | Output: Timecards Changed |
GNUM3 | Output: Errors |
GNUM4 | Output: Warnings |
The predefined hourly rate functions for custom overtime rules are:
OCR_MealAllowance
The Meal Allowance custom rule pays a meal allowance of 8.00 USD for days on which employees work 9.5 or more hours of regular time (pay type of 1). The system creates a gross pay timecard with a pay type of 999 for 8.00 USD for that day. For example, you might want to pay consultants a meal allowance when they have worked a certain number of hours within a specific period.
OCR_SpreadOvertime
The Spread Employee's Salary custom rule spreads a salaried employee's salary over all hours worked and does not generate overtime. For example, you might want to pay salaried employees the same amount regardless of overtime worked. With this function, you can spread employee overtime across all hours worked, which in essence reduces the hourly rate, but pays employees the same amount.
OCR_SevenDaysWorked
The Seven Days Worked custom overtime rule applies to overtime worked in California. An organization must first determine whether an employee worked more than 30 hours in a week or over six hours in any day of the week. This calculation determines whether the employee is entitled to overtime on the seventh consecutive day. If an employee works seven consecutive days and has worked at least 30 hours in the week, or six hours in a day, the employee is entitled to overtime. The first eight hours of the seventh day are paid at 1.5 of the regular rate of pay. Any hours over eight worked on the seventh day are paid at 2.0 of the regular rate.
New timecards are created with pay type 999.
OCR_MinWageAdjustment_1
The Minimum Wage Adjustment custom overtime rule checks to determine whether an employee is being paid at least minimum wage based on the total pay and hours worked on the timecards being processed. If not, this rule adds a timecard for the employee to bring his or her hourly rate up to minimum wage.
You must register functions to access them when you build a formula for the hourly rate or hours worked fields in the Timecard Automation programs. Functions are registered specifically for use with timecard templates, retroactive pay rules, or overtime rule sets. The functions that are included with the Timecard Automation module are already registered. Occasionally, you might need to use a function that is not registered, such as any custom functions that you create. You can use functions alone or in formulas.
When you register a function, you can define it as active or inactive. An active field or function is one that other users can access from a Timecard Automation program. You can use inactive mode to verify whether the function works properly before you make it active for other users.
Before registering a function, you should identify the usage code that the system uses to determine the program in which the function is used. Usage codes include:
THRF - Identifies a timecard template hourly rate function.
THWF - Identifies a timecard template hours worked function.
RHRF - Identifies a retroactive pay rule hourly rate function.
RHWF - Identifies a retroactive pay rule hours worked function.
OHRF - Identifies an overtime rule hourly rate function.
OCRI - Identifies an overtime change rules IF statement.
OCRT - Identifies an overtime change rules THEN statement.
OCR - Identifies a custom overtime rule that is created using a custom business function.
In addition to specifying the usage codes for a function, you should also identify this information for each function:
The source module, which is the object name to which the function belongs.
Object names that are associated with named event rule business functions begin with N. For example, N1861411 is the object name (or source module) that contains the various overtime hourly rate functions.
The function name within the source module.
Event rule logic and data structures are attached to individual functions within a source module.
The status of the field availability (either active or inactive).
Note: You can use the Field/Function Definition form to revise information about a function, such as its active status. The changes that you make to functions affect all batches of timecards that use changed fields and functions and that are processed after the change. Changes do not affect timecards that have already been processed.You can delete a function from the Fields and Functions program, thereby making it unregistered in the Timecard Automation module. Deleting a function removes it from the search list for the appropriate Hourly Rate or Hours Worked field, but does not remove it from the system. |
Access the Field/Function Definition form.
Enter a usage code that represents the purpose of the function. For example, if you are registering a function that calculates a custom overtime rule, enter usage code OCR (custom overtime rule). The value that you enter in this field determines whether you can use the function in specific areas of the Timecard Automation module. For example, if you enter OCR, the function is available for use in the call custom rule area of overtime rule sets only.
Enter the name of the object that contains the function that you are registering. Multiple functions can be grouped within a single source module. For example, the source module N1861411 - Overtime Hourly Rate Formulas might contain all of the functions that retrieve various hourly rates to be used within overtime accumulator rules.
Enter the actual name of the function. It must follow standard ANSI C naming conventions. For example, don't include spaces between words.
Select to indicate that other users can access the field or function from the applicable Timecard Automation program.
This section provides an overview of formulas, lists a prerequisite, and discusses how to:
Create a formula
Test a formula for a timecard template.
Test a formula for a retroactive pay rule.
Test a formula for an overtime rule set.
When you need to perform simple, complex, or unusual calculations to determine the appropriate hourly rate or number of hours worked for a particular situation, you can create a formula. The formula can use the standard functions that are included with the system, or you can use custom functions that you have created. You can also use a combination of both types of functions.
When you create a formula, you create it within a specific timecard template, retroactive pay rule, or overtime rule set. Based on the program that you select, the system provides you with a list of appropriate functions that are available for use in the formula. You then create mathematical statements that include one or more of these functions.
For example, assume that you need to average two different union rates to pay warehouse employees retroactive pay. To calculate the correct rate, you enclose within parentheses the multiple of the two union rates and divide the result by two. The formula for the new rate is:
New Rate = (RHRF_UnionRateA × RHRF_UnionRateB) ÷ 2
You cannot use a formula outside of the initial timecard template, overtime rule set, or retroactive pay rule for which it was created. You cannot save and reuse formulas; however, if you need to use a formula often, you might consider asking the system administrator to create a custom function. You can save and reuse the timecard template, retroactive pay rule, or overtime rule set that contains the formula that you created.
You use the Build Formula form to create custom formulas. You cannot access this form from a menu; instead, you access it using the search button in the hours worked and hourly rate fields in the Timecard Templates, Retroactive Pay Rules, and Overtime Rule Sets programs.
This table shows the forms and fields from which you can access the Build Formula form:
Form Name | Field |
Timecard Template form | Hours Worked field (Main tab) and Hourly Rate field (Rates tab) |
Timecard Accumulator Rule form (within Overtime Rule Sets) | New Hourly Rate field |
After you create the formula, but before you begin using it, test it to validate its mathematical logic and to ensure that it calculates the appropriate results.
Depending on government regulations, industry standards, union contracts, and company processes, different organizations calculate overtime rates using different methods. Review the examples of the formulas for these overtime hourly rate calculations. The functions that are used in these formulas are predefined in the system and are available for use in the overtime rule type specified in the formula description.
This formula averages the hourly rates of all of the regular timecards within the specified accumulation period and multiplies the average rate by 1.5 to determine the new hourly rate for overtime. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = 1.5 x OHRF_WeightedAverageHourlyRate
This formula calculates the new hourly rate for Chinese Overtime. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = OHRF_TimcardRate + 1/2 OHRF_Salary/OHRF_FrequencyOHRF_TotHoursWorked
This formula multiplies the employee's rate, as specified in the F060116 table, by 1.5 to determine the new hourly rate for overtime. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = 1.5 x OHRF_EmployeeMasterRate
This formula multiplies the union rate of a specified column in the F069126 by 1.5 to determine the new hourly rate for overtime.
OHRF_UnionRateA, OHRF_UnionRateB, OHRF_Union RateC, OHRF_UnionRateD, or OHRF_UnionRateR should be substituted for OHRF_UnionRateX in the formula. A, B, C, D, and R each specify particular columns in the F069126 from which to retrieve the rate. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = 1.5 x OHRF_UnionRateX
This formula uses the employee's rate, as specified in the F060116 table, to derive the regular portion of overtime. The system then multiplies the average hourly rate from the timecards by .5 to determine the premium portion and adds the two rates together to determine the new hourly rate for overtime. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = OHRF_EmployeeMasterRate + (0.5 x OHRF_WeightedAverageHourlyRate)
This function does not calculate an overtime rate; rather, it calculates a new hourly rate for salaried employees by spreading an employee's salary over all of the hours worked.
Spread Employee's Salary is a predefined function that is available for use in the custom rule set rule within an overtime rule set.
This function calculates the overtime rate by retrieving the hourly rate from the original timecard and multiplying it by the pay rate multiplier that is specified on the timecard. This method is typically used for employees in the United States who receive tips. You can use this formula in an overtime accumulator rule within an overtime rule set.
New Hourly Rate = OHRF_PayRateMultiplier x OHRF_TimecardRate
After you create a formula and before you process the timecard template, overtime rule set, or retroactive pay rule to which it is attached, test the formula to verify that it is mathematically valid and accurate. The system includes a feature that you can use to automatically validate the formula. However, you need to confirm whether the calculations produce the results that you expect. For example, for a formula that averages two union pay rates, you should verify that it calculates the correct rate.
Using the formula testing functionality, you can automatically calculate the formula for one record at a time. You can then review the results to determine whether they are correct.
You can also test the formula by submitting the timecard template, retroactive pay rule, or overtime rule set for processing, and then reviewing the new timecards to ensure that they are correct. If the timecards are incorrect, you can cancel the batch.
Create a timecard template, retroactive pay rule, or overtime rule set.
Form Name | FormID | Navigation | Usage |
Work With Timecard Templates | W186301B | Periodic Processing (G18620), Timecard Templates | Select the timecard template to which you want to add a formula. |
Work With Retroactive Pay Rules | W186701A | Periodic Processing (G18620), Retroactive Pay | Select the retroactive pay rule to which you want to add a formula. |
Work With Rule Sets | W186401A | Periodic Processing (G18620), Overtime | Select the rule set to which you want to add a formula. |
Build Formula | W186101D | On Work With Timecard Templates, select a record in the detail area, click Select, and then search for the Hours Worked field (Main tab) or the Hourly Rate field (Rates tab) on the Timecard Template form.
On Work With Retroactive Pay Rules, select a record in the detail area, click Select, and then search for the New Hourly Rate field on the Retroactive Pay Rule form. On Work With Rule Sets, select a record in the detail area, click Select, and then select Add Accum Rule from the Form menu on the Rule Set form. In the Overrides area, select the New Hourly Rate option to turn activate it, and then perform a search in the New Hourly Rate field. |
Create a formula. |
Formula Tester | W186101E | Select Test from the form menu on the Build Formula form. | Test a formula for a timecard template.
Test a formula for a retroactive pay rule. Test a formula for an overtime rule set. |
Access the Build Formula form.
To create a formula:
Select a record in the detail area, and then click the Insert Function button.
The system displays the function in the Rate Formula field.
Enter the appropriate characters in the Rate Formula field.
Select Validate from the Form menu.
If the formula is mathematically valid, the system displays a confirmation message. If the formula is not mathematically valid, the system highlights the Formula To Test area in red.
Revise the formula if it is not valid, and repeat step 3.
Click OK when the confirmation window appears.
Select Test from the Form menu to test the formula and ensure that the system creates accurate timecards.
Complete the steps for testing a formula.
Access the Formula Tester form.
Enter the employee number that you want to use to test the formula.
Enter a user-defined name for a timecard template.
Select to verify that the syntax of the formula is mathematically valid. If it is not mathematically valid, the system changes the Formula To Test area to a contrasting color.
Select to calculate the formula and display the results in the Output hourly rate box.
A number that the system assigns to each timecard to uniquely identify it. You can use this field in the Time Entry By Job program to retrieve a specific timecard for display. This field is also used to associate a timecard with each actual burden audit record that was created for the timecard during the Actual Burden Journaling process. If you do not know the transaction number, you can use the search button to select a timecard with which to test the formula.
Indicates whether an entry in the Timecard Tag file refers to a current timecard or a historical timecard. Select this option to test a formula using a timecard from F06116.
Indicates whether an entry in the Timecard Tag file refers to a current timecard or a historical timecard. Select this option to test a formula using a timecard F0618.
Select to calculate the formula and display the results in the output hourly rate box.
