This chapter contains the following topics:
Section 8.2, "Reviewing and Revising Timecards Created by Timecard Automation"
Section 8.4, "Viewing the Timecard Batch File Audit History"
You can use the Reviewing and Approving program (P186601) to manage batches of timecards that are created or changed by the Timecard Templates program (P186301), the Retroactive Pay Rules program (P186701), or the Overtime Rules program (P186401). For example, after you use a timecard template to create a batch of timecards with which to pay the sales staff, you can review the batch of timecards to ensure that they are accurate. When you are satisfied, you can approve the batch of timecards and continue with pre-payroll processing.
After you submit a timecard template, overtime rule set, or retroactive pay rule for processing, the system assigns a number and an initial status of Pending Approval to the resulting batch of timecards. As long as the batch of timecards is pending approval, you can review and revise it in the Reviewing and Approving program. When you finish working with the batch of timecards, you can change its status by either approving or canceling the batch.
For example, before you pay the sales staff, you review the accuracy of the batch of timecards that was created using a timecard template. After reviewing the batch, you realize that it does not cover the correct dates. You cancel the batch, thereby deleting the timecards. You then return to the Timecard Templates program, update the timecard template, and resubmit the batch. You then note that the batch of timecards is acceptable, at which point you approve it and continue with pre-payroll processing.
The processes for reviewing, approving, and canceling timecards are the same regardless of the program from which a batch of timecards originated. For example, you can approve a batch of timecards that was created with an overtime rule set to pay overtime to the warehouse staff. You can use the same process to approve a batch of timecards that was created with a timecard template to pay consultants a bonus.
You can review new or changed timecards that are pending approval. The system determines how you can review batches of timecards in the Reviewing and Approving program based on the program in which the timecards originated. However, when you access batches of timecards directly through the Timecard Templates program, the Retroactive Pay Rules program, or the Overtime Rules program, the system displays only those batches that originated in the particular program.
As long as a batch of timecards is pending approval, you can revise individual timecards by selecting the batch of timecards and the appropriate timecard. You can revise the status of batches of timecards by approving or canceling those that are pending approval. You can also run reports that display the timecards in a specific batch.
Create timecards using the timecard automation process.
See Setting Up Timecard AutomationSetting Up Functions and Formulas for Timecard Automation.
This section provides an overview of timecard review and revision and discusses the forms used to review and revise timecards that are created by timecard automation.
When a batch of timecards is pending approval, you can use the Reviewing and Approving program (P186601) to review, approve, or cancel the batch. Within the Timecard Automation module, when timecards are created in F06116, they are marked as pending. You cannot process pending timecards in a payroll cycle.
When you approve a batch of timecards, the system removes the pending marker, which enables the timecards to be included in a payroll cycle. When you cancel a batch of timecards, the system removes the timecards that were created by the Timecard Automation module from the F06116 table and returns to their original state any timecards that were changed. For example, when you use a timecard template to pay quarterly bonuses to the consulting staff, you might want to verify the accuracy of the timecards. You must approve the batch before you can process the timecards in a payroll cycle.
The Timecard Templates program (P186301), the Retroactive Pay Rules program (P186701), and the Overtime Rules program (P186401) each manage timecards differently. The view that you use to review batches of timecards might differ depending on which process created the timecards. Timecard templates create new timecards, retroactive pay rules create new timecards based on existing timecards, and overtime rule sets can create new timecards and change existing timecards.
A view is the manner in which the Reviewing and Approving Timecards program displays the header information, relationships between timecards, and information that is specific to the originating program for a batch of timecards. A relationship shows the connections between originating timecards and new or changed timecards.
The views that are available for each program include:
Timecard Templates: Basic.
Retroactive Pay Rules: Before, After, Both.
Overtime Rule Sets: Before, After.
The Timecard Templates program uses a timecard template to create new timecards. You can review new timecards using a basic view. The term basic refers to the batch of timecards that the system creates. No relationships exist among these timecards.
The Retroactive Pay Rules program uses a retroactive pay rule and original timecards to create new timecards. You can review original and new timecards using before, after, or both views:
View | Description |
Before | The batch of original timecards that the system uses. These timecards provide information for creating timecards. No relationship exists among these timecards. |
After | The batch of new timecards that the system creates. These timecards are based on the original timecards that are displayed in the Before view. No original timecards are displayed, and all timecards displayed are new. |
Both | The batch of timecards, including original timecards and timecards that the system creates. These timecards include the original timecards that are displayed in the Before view, and on which they are based. Original timecards are displayed in bold text; new timecards are displayed in plain text. |
The Overtime Rule Sets program uses an overtime rule set and original timecards to create new timecards and change the original timecards. You can review new and changed timecards in Before or After view:
Before | The batch of original and unchanged timecards that the system uses. These timecards provide information for creating or changing other timecards. No relationships exist among these timecards. |
After | The batch of new and changed timecards that the system creates or changes. These timecards are based on the original timecards that are displayed in the Before view. Original timecards are displayed in bold text; new timecards are displayed in plain text. |
The Reviewing and Approving Timecards program (P186601) enables you to access the Speed Time Entry program (P051121) to revise batches of timecards. You can revise timecards from the Reviewing and Approving Timecards program only after the system processes the batch of timecards and before you approve or cancel it. For example, after you review a batch of timecards and discover that it uses an incorrect value for paying overtime to employees in the warehouse, you can revise the batch of timecards. You can revise timecards by employee or by batch number. You can also revise the status of a batch of timecards.
You can revise current timecards that were created or changed for an employee regardless of batch number. For example, assume that you pay a quarterly bonus to employees who meet certain criteria on a project, such as being employed in the quarters before and after the current quarter. After reviewing the batch of timecards, you discover that one employee was not employed during the preceding quarter. The system enables you to remove the employee instead of reprocessing the entire batch.
You can revise new timecards that are created in a specific batch of timecards. For example, assume that the organization has a division that contains several departments. If some of the employees in a department entered their time incorrectly on their timecards, you can correct the specific timecards that require changes instead of canceling the entire batch. However, when you review batches of timecards that were created by the Overtime Rules Sets program, the system displays only newly created timecards. Changed timecards are part of an original batch and are not included when you review timecards by batch. To change original timecards, you can review the timecards by employee. Doing so shows you all of the current timecards for each employee, regardless of batch number.
Note: You cannot revise historical timecards. |
This table describes the batch approval statuses:
Status | Description |
Pending Approval | Batches of timecards arrive in the Reviewing and Approving Timecards program that are marked Pending Approval. Pending timecards cannot be included in a payroll cycle. You can revise and approve, or cancel batches of timecards or individual timecards. |
Approved | After you approve a batch of timecards, the system changes the status to Approved and removes the Pending status from F06116. When you approve a batch of timecards, the system marks as approved all changes that were made after the timecards were generated, such as changed timecards and any new timecards that have been created. After changing the status to Approved, the system creates an Approval or Cancellation report and enables you to continue the pre-payroll process. As long as a batch of timecards is approved or canceled, you can delete the header record for the batch. |
Canceled | When you cancel a batch of timecards, you reject the changes that were made to existing timecards and you reject the new timecards that were created. The system removes newly created timecards from F06116 and restores changed timecards to their original status. After changing the status of the batch to Canceled, the system creates an Approval or Cancellation report and, as appropriate, reverses the changes and deletes the new timecards. As long as a batch of timecards is approved or canceled, you can delete the header record for the batch. |
Form Name | FormID | Navigation | Usage |
Work With Timecard Automation Batches | W186601A | Daily Processing (G18610), Reviewing and Approving
Select the template, rule, or rule set to review after submitting a timecard template, retropay rule, or overtime rule set for processing. |
Select a batch of timecards for review or revision. |
Timecard Automation Batch | W186601B | Select the batch of timecards with which you want to work, and then click Select on Work With Timecard Automation Batches. | Review or revise timecards created by timecard automation. |
This section provides an overview of timecard batches and lists the forms used to revise the status of a batch of timecards.
When you review the timecards that the system created from a timecard template, a retroactive pay rule, or an overtime rule set, you might need to correct errors before you approve the batch. You can access the Speed Time Entry program (P051121) from the Timecard Automation module to revise batches of timecards or individual timecards. You can revise timecards for only those batches that have not been approved or canceled. You cannot revise historical timecards.
After reviewing the batch of timecards and before continuing with pre-payroll processing, you can approve the batch to accept the changes and newly created timecards, or you can cancel the batch of timecards if it is incorrect, thereby rejecting the changes and the newly created timecards.
After you change the status of the batch of timecards to Approved or Canceled, you can no longer revise it or change its status.
You cannot delete the header record from the Reviewing and Approving Timecards program for a batch of timecards pending approval. You can, however, delete the header record for a batch of timecards after you have approved or canceled it.
When you approve or cancel a batch of timecards, the system generates the Labor Rules Batch Approval/Cancellation report (R186602). Use this report to review detailed information about the timecards in the batch. The report includes:
Header information, such as batch number, employee group name, start date, and end date.
Individual timecard information, such as transaction number, batch number, address name and number of each employee, PDBA code, work date, hours worked, hourly rate, and gross pay.
Confirmation | W186601E | Select the batch that you want to approve, and then select Approve Batch from the Form menu on Timecard Automation Batch.
Select the batch that you want to cancel, and then select Cancel Batch from the Form menu on Timecard Automation Batch. |
Approve or cancel a batch of timecards. |
This section provides an overview of timecard batch file audit history and discusses how to view a timecard batch file audit history.
You use the Timecard Audit Details program (P05116Z2) to view the detailed history information of the timecard batch files. The Timecard Audit Details program displays the audit history records for each timecard selected in the sequential order. The timecards that were last saved are displayed first. You can search for the timecards based on employee number.
Timecard Audit Details | W05116Z2A | Time Entry (G05BT1), Timecard Audit Details | Review a timecard batch file audit history. |
Access the Timecard Audit Details form.
Enter the employee number of the employee for whom you want to view the timecard audit details.
Enter the last day of the pay period, as defined in the master pay cycles.
Enter the last day of the labor distribution period.
Review the correction status of the timecard history records. Values are:
Blank: The timecard or historical timecard has not been corrected.
1: The timecard has been corrected.
2: The historical timecard has been corrected.
Review the transaction number of the corresponding timecard in the F06116Z1, F06116, or F0618 table.
Review the number that an EDI transmitter assigns to a transaction.
