This chapter contains the following topics:
Section 13.2, "Reviewing Sales Order Information for Argentina"
Section 13.6, "Working with Prenumbered Documents for Argentina"
This section provides an overview of entering sales orders for Argentina, lists prerequisites, and discusses how to set processing options for PO Sales Order Entry (P76A4210).
In some situations, you might need to enter a credit order or another sales order that corresponds to a previous sales order which has already been associated with an invoice. For example, you might need to create an invoice for something that was missing from the original sales order, or you might need to create an invoice for a larger amount. In this situation, you can enter a new sales order and associate it with an existing invoice by using either the internal number or the legal number of the invoice, which enables the system to consider the tax calculations from the previous invoice.
Note: Any changes made to the order affect the whole order. All documents that are associated with the order are affected by the change. You are responsible for any changes made. |
Before you complete the tasks in this section:
Review the steps for entering a standard sales order.
Set up corresponding versions of the Sales Order Entry (R4210) program and the PO Sales Order Entry (P76A4210) program.
Form Name | Form ID | Navigation | Usage |
Work With Sales Order Headers | W4210H | Sales Order Processing (G4211), Enter Orders Header | Review and select sales order header records. |
Sales Order Header | W4210G | Click Add on Work With Sales Order Headers. | Add and revise sales order header information. |
Sales Order Detail Revisions | W4210A | Click OK on Sales Order Header. | Add and revise item information in the detail portion of the form.
Enter line default information in addition to item information when you do not enter sales order headers. |
Order Acceptance | W42232A | Click OK on Sales Order Detail Revisions. | Click the appropriate button to place the order or to revise the order. |
NC/ND Related to Invoice | W76A0180A | Click Place Order on Order Acceptance. | Assign the sales order to the original invoice by using either the internal number or the legal number of the invoice. |
Processing options enable you to specify the default processing for programs and reports.
Enter 1 to enter an invoice related to a credit note or debit note.
This section discusses how to review sales order information.
Customer Service Inquiry | W4210E | Sales Order Inquiries (G42112), Customer Service | Review sales order, customer, and item information in the Sales Order Detail File (F4211) or Sales Order History File (F42119) tables.
For Argentinian sales orders, the system displays the legal number in the Customer PO field (VR01). |
Sales Orders Inquiry by Legal Number | W76A8240A | Select a record and then select Regional Info (information) from the Form menu on the Customer Service Inquiry form.
Or select a record and then select Regional Info (information) from the Form menu on Work With Sales Ledger Inquiry. |
Review and select Argentinian sales orders based on the invoice or shipment note's legal number. |
Access the Sales Orders Inquiry by Legal Number form.
Note: The system displays this form only if you have set up the user preferences with a Localization Country code of AR (Argentina). |
Enter a 15 position code that is reserved for the user.
Record reference numbers, such as the supplier's bid document number, quote document, sales order, work order, or job number.
This section lists a prerequisite and discusses how to review tax calculations.
For the tax calculations to appear, the Sales Order Taxes at Order Level option on the Tax Rules Revisions form must be turned on.
Work With Online Invoice | W42230A | Sales Order Inquiries (G42112), Online Invoice | Review invoice information about an order that has not been invoiced or that has been only partially invoiced. |
Legal Tax Amount Detail | W76A230B | Select Regional Info from the Form menu on Work With Online Invoice. | Review the tax calculations that are based on the fiscal setup for Argentina.
Review detailed tax calculations by tax code and order line. |
Access the Legal Tax Amount Detail form.
Important: For the tax calculations to appear, the Sales Order Taxes at Order Level option on the Tax Rules Revisions form must be turned on. |
This section provides an overview of the Invoice Print program, lists prerequisites, and discusses how to set processing options for PO Invoice/Shipment Note Print (R76A565).
In the JD Edwards EnterpriseOne Sales Order Management system, the process of printing invoices has been modified to comply with Argentine legal requirements.
You can use the Invoice Print program (R42565) to print invoices that comply with the legal requirements for printing, numbering, and taxes as stipulated on General Resolution 1415.
Table F76A09 controls the reprinting process.
The invoice format shows the taxes in the body of the document, one below the other and in accordance with tax code definitions. The description of the invoice taxes is obtained from the Description 01 field of UDC 76A/B3.
During invoice printing, the system prints an error report if it detects that mandatory parameters, such as legal numbering, are missing.
Note: Do not select invoice summarization. |
Printing pro forma invoices enables you to print invoices in proof mode so that you can see a printed copy of all the invoices that are generated before the current billing without updating tables or legal numbers.
Printing pro form invoices differs from the standard invoice print process in these ways:
No legal number is generated.
Next numbers for accounts receivable are not updated.
No records are generated in the F76A09 table or the F76A18 table.
To print pro forma invoices, set the first processing option on the PO Invoice/Shipment Note Print program to run in proof mode, and set the processing options on the Invoice Print program to prevent next status update and accounts receivable number assignment.
Set up identically named versions of the Print Invoices program and the PO Invoice/Shipment Note Print program, and set up the processing options for these programs.
Verify that the XJDE0001 version of the Print Invoice/Shipment Note - ARG - 42 program (R76A566) exists. Do not modify the data selection of this version.
Verify that the ZJDE0001 version of the Generate Invoice/Shipment Note WF - ARG - 42 program (R76A567) exists. Do not modify the data selection of this version.
Verify that the sales orders have a status code for invoice printing.
Verify the next legal number setup for companies and issue places in the Legal Next Numbers program (P76001A).
Verify the configuration of RG100.
See Setting Up Print Authorization Codes for Argentine Suppliers.
Verify the tax setup.
These processing options control whether the system prints shipment notes and invoice location, runs in final mode, prints lot numbers, and defines the maximum print lines per page.
Specify whether the system prints shipment notes. Values are:
Y: Print shipment notes.
N: Do not print shipment notes.
Specify whether the system runs in proof or final mode. Values are:
Blank: Run in final mode.
Y: Run in proof mode.
Enter the place where the invoice or the shipment note is printed.
Specify whether the system prints the lot number in domestic items. Values are:
Blank: Do not print the lot number.
1: Print the lot number in domestic items.
Enter a line printer parameter that specifies the number of lines per page. For example, 60 or 66.
These processing options specify the status codes used for invoices and shipment notes when an error is detected.
Enter the next status code to be used for invoices when an error is detected. If you leave this processing option blank, the system uses the default value of 831.
Enter the next status code to be used for shipment notes when an error is detected. If you leave this processing option blank, the system uses the default value of 832.
These processing options control global print messages in the invoice receipt footer.
Enter the first global print message to be printed in each invoice receipt footer. This is a code identifying the Text Message you want the system to print next to this order line on selected documents.
Enter the second global print message to be printed in each invoice receipt footer. This is a user defined code that you assign to each print message. Examples of text used in messages are engineering specifications, hours of operation during holiday periods, and special delivery instructions.
These processing options control the conversion units of measure for weight and volume.
Enter the weight unit of measure to convert all the items. This is the unit of measure that indicates the weight of an individual item. Typical weight units of measure are: GM for gram, OZ for ounce, LB for pound, KG for kilogram, and so forth.
Enter the volume unit of measure to convert all the items. This is the unit of measure for the cubic space occupied by an inventory item. Typical volume unit of measures are: ML for milliliter, OZ for fluid ounce, PT for pint, and so forth.
This processing option controls whether the you are entering a voucher corresponding to RG 100.
Specify whether you are entering a voucher corresponding to RG 100. Values are:
Blank: Vouchers are not included in RG 100.
1: You are entering a voucher corresponding to RG 100.
These processing options control whether to print the report and which version to use.
Specify whether the system prints the report. Values are:
N: Do not print the report.
Y: Print the report.
Enter the version for R76A8050. If you leave this processing option blank, the system uses version ZJDE0001.
These processing options control whether to use transportation and if you want to print Seals.
Specify whether the system should use transportation. Values are:
N: Do not use transportation.
Y: Use transportation.
Specify whether the system prints seals. Values are:
N: Do not print seals.
Y: Print seals.
This processing options controls the type of temperature information printed on the shipment note.
Specify whether the system print temperature and density information on the shipment note or print this information only if the invoice is in standard temperature. Values are:
Blank: Print temperature and density information in the shipment note.
1: Print this information only if the invoice is in standard temperature.
2: Prevent the system from printing this information.
This processing options controls whether the Autoprinter information in the shipment note corresponding to RG 889.
Specify whether you want the system to print the Autoprinter information in the shipment note, corresponding to RG 889. Values are:
Blank or N: Do not print.
Y: Print the Autoprinter information in the shipment note, corresponding to RG 889.
This processing option controls whether to print carrier information.
Specify whether the system prints the information carrier. Values are:
N: Do not print information carrier.
Y: Print the information carrier.
These processing options control whether credit invoices are generated and the number of copies to print.
Specify whether the system generate credit invoices. Values are:
Blank: Do not generate credit invoices.
1: Generate credit invoices.
Enter the number of copies required by the customer. The system prints the number of invoices specified in this field. The system always prints at least one invoice.
This section provides overviews of printing shipment notes and printing shipment notes according to RG 889; and lists prerequisites.,
In the JD Edwards EnterpriseOne Sales Order Management system, the process of printing shipment notes has been modified to comply with Argentine legal requirements.
You can use the Invoice Print program to print shipment notes that include legal numbering and printing formats that comply with General Resolution 1415.
Note: The F4211 table contains the date of the shipment note in the User Reserved Date field (URDT). The F76A4211 table contains the legal number of shipment note in the Shipment Note Legal Number field (SNLN). |
You can reprint shipment notes.
The total weight and volume of items to be shipped is printed on the shipment note. The units are converted to the units of measurement that are specified in the processing options, which requires that all possible and required conversions be set in the general units of measurement table (UDC 00/UM).
If some of these conversions have not been included in the table, the affected item is printed on the shipment note with asterisks in the weight and volume fields, and the item is not added to the shipment note's total.
During shipment note printing, the system prints an error report if it detects that mandatory parameters, such as legal numbering, are missing.
General Resolution 889/00 implements changes to the way shipment notes are printed by the responsible registered parties. The letter X that is used to identify the shipment note is replaced by the letter R, and the legal document type 39 changes to 91. The Print Authorization Code (CAI) must also appear on shipment notes.
According to Art. 3, those shipment notes, equivalent documents, or both, that were printed on or before September 30th, 2000, and issued by the registered parties on the VAT can be used until the 28thof February, 2001, or until none is left, whichever happens sooner. After this time, unused shipment notes must be clearly marked with VOID to discontinue their use.
To set up RG 889, complete these tasks:
Add these values to UDC 76/B1:
R: Remito
X: Shipping Note
Add these values to UDC 76A/B8:
R: Remito
X: Shipment Group
Add this value to UDC 76/AF:
091: Remito
Relate the desired document type with legal document type 91 and the letter R.
Define the numbering for legal document type 91 for the issue place and company.
Enter the CAI for legal document type 91 for the desired company and issue place.
Assign the letter R for shipment groups to the tax groups.
Complete the processing option on the RG 889 tab for the PO - Invoice/Shipment Note Print - ARG - 42 program to specify that the shipment note being generated falls under RG 889 and that the CAI number should be printed.
Verify that the processing options for the PO Invoice/Shipment Note Print program are set to print shipment notes.
Verify that the processing options for the Print Invoices program are set so that status is not updated and accounts receivable numbers are not generated.
Set up the XJDE0001 version of the Print Invoice/Shipment Note - ARG - 42 program. Do not modify the data selection of this version.
Set up the ZJDE0001 version of the Generate Invoice/Shipment Note WF - ARG - 42 program. Do not modify the data selection of this version.
Verify that the sales orders have a status code for shipment note printing.
This section provides an overview prenumbered documents and discusses how to:
Set processing options for Invoice Print (P76A715).
Set processing options for Invoice Void (P76A725).
Verify legal numbers.
Void printed invoices.
Unlock legal numbering.
Void a shipment note.
Reprint documents.
The JD Edwards EnterpriseOne Sales Order Management system enables companies that are not autoprinters to work with prenumbered invoices and shipment notes.
When prenumbered documents are required, you can:
Hide data that already exists in the preprinted form.
Generate voided legal numbers for pages other than the first page.
Void a printed invoice (new billing) for open orders.
You can use the Invoice Print program to verify that the legal number which the system assigns to the invoice and shipment notes matches the preprinted form.
Note: If the printing company is an autoprinter, do not run the process twice at the same time for the same company, issue place, and document type. |
The system uses the next legal number of an invoice (for the same company, issue place, and document type) when the invoice program detects a page break. This situation ensures that the legal numbers that are assigned by the system and the preprinted forms match.
You can also hide some of the fields, such as company information, invoice letter, and other data that are already included in the preprinted invoice.
The system creates a record in the F76A09 that contains the invoice internal number and type of document for each invoice, as well as a record for each legal number that is void. The Processed (Y/N) field (PRCS) of these records has a value of Y (for reclassified). A legal number is used for shipment notes; no records are created in the table.
The S.O. Detail Ledger File table (F42199) also saves the legal numbers of shipment notes as a backup.
You can void invoices if they are still open and are not records of voids. You can query the F76A09 table to determine which invoices can be voided.
When you void an invoice, the system makes these table changes for each of the voided records:
In the F4211 table, the system clears these fields:
Document (Voucher, Invoice, and so forth) (DOC).
Document Type (DCT).
Document Company (KCO).
Reference 2 (VR02).
Date - Invoice (IVD).
In table F4211, the value from Status Code - Next field (NXTR) is moved to the Status Code - Last (LTTR), and the Status Code - Next field (NXTR) is populated with the value from the Status Code - Next - Invoice processing option from the Invoice Void program.
In table F76A09, the invoice has a void status and the amounts are zero. The value in the Document Type field (DCT) is changed to # and the Date - For G/L and Voucher - Julian field (DGJ) is populated with the date on which the invoice was voided. The Processed (Y/N) field (PRCS) is changed to Y.
The corresponding tax records are cleared from the F76A18 table.
After you void an invoice, you can print the invoice for the sales order again on a preprinted form.
You unlock the invoicing process whenever a failure occurs in the system, or when you want to invoice a company or issue place more than once.
You can use the Shipment Note Void program (P76A725) to void shipment notes that have been previously generated.
After you void a shipment note, you can print the shipment note for the sales order again on a preprinted form and re-issue it.
When you void a shipment note, the system makes these table changes for each of the voided records:
In the F4211 table, the system clears User Reserved Date field (URDT).
In the F4211 table, the Status Code - Next field (NXTR) is populated with the value from the Status Code - Next - Shipment processing option from the Shipment Note Void program (P76A725).
In the F76A4211 table, the system clears the Shipment Note Legal Number field (SNLN).
You can reprint invoices, shipment notes, and perception certificates.
The word Reprint appears at the bottom of the reprinted invoices and the shipment notes. The reprinted documents are exact copies of the original documents.
Prenumbered Invoice/Shipment Note Print | W76A715A | Prenumbered Setup (G76A101), Invoice Print | Verify that the legal number on the preprinted form matches the value in the Next Legal Number field. |
Work With Invoice Reprint | W76A725A | Prenumbered Setup (G76A101), Invoice Void | Locate the invoice to void and select Reprint from the Form menu. |
Work With Prenumbered Invoice/Shipment Note Print | W76A715BA | Prenumbered Setup (G76A101), Unlock Prenumbered Invoice/Shipment | Locate and select the invoice to unlock, and then select Unlock from the Row menu. |
Work With Shipment Note Reprint | W76A725D | Prenumbered Setup (G76A101), Shipment Note Void | Locate and select the shipment note record to void, and then select Reprint from the Form menu. |
Reprint Invoice Print WF - ARG | W76A0209A | Processes (G76A421), Invoice Reprint | Locate and select the documents to reprint. When you select the document, the text of the selected line changes to the color red.
After selecting all of the documents to reprint, select Reprint from the Form menu. |
For programs, you can specify options such as the default values for specific transactions, whether fields appear on a form, and the version of the program that you want to run.
These processing options control default information used for transaction entries, the DGI (Direccion General Impositiv) transaction document type, whether you are printing a shipment note, and whether legal numbers can be changed before printing.
Specify the company that you use for transaction entries. The company name must identify a reporting entity that has a complete balance sheet.
Specify the issue place that you use for the transaction entries.
Specify the type of legal document given by DGI (Direccion General Impositiv) for documents.
Specify whether the shipment note you are printing is a shipment note or other document such as an invoice. Values are:
Y: This is a shipment note.
N: This is not a shipment note.
Specify whether to allow a legal number change prior to printing the invoice or shipment note. Values are:
Blank: Do not allow a legal number change.
1: Allow a legal number change.
This processing option controls the version of the Invoice Print program used by the system.
Specify the version of the Invoice Print program to use. If you leave this processing option blank, the system uses the version of the Invoice Print program that has the same name as the current version of the Prenumbered Invoice/Shipment Note Print - ARG - 42 program.
These processing options control the next step in the order process for the invoice and shipment.
Enter a UDC (40/AT) to specify the next step in the order process. You must enter a code (UDC 40/AT) that has been set up in the order activity rules based on the order type and the line type that you are using.
Enter a UDC (40/AT) to specify the next step in the order process. You must enter a UDC (40/AT) that has been set up in the order activity rules based on the order type and the line type that you are using.
Access the Prenumbered Invoice/Shipment Note Print form.
Displays the number that the system will assign next. The system can use next numbers for voucher numbers, invoice numbers, journal entry numbers, employee numbers, address numbers, contract numbers, and sequential W-2s. You must use the next number types already established unless you provide custom programming.
Access the Work With Invoice Reprint form.
Displays the date that either you or the system assigns to an invoice or voucher. This can be either the date of the supplier's invoice to you or the date of the invoice to the customer.
Displays the legal document type given by DGI for documents.
Access the Work With Prenumberd Invoice/Shipment Note Print form.
Access the Work With Shipment Note Reprint form.
Access the Reprint Invoice Print WF - ARG form.
This section provides an overview of updating customer sales and discusses how to update customer sales.
You run Update Customer Sales as the last step in sales order processing to update, verify, and post daily sales information. When you run this program, the system transfers the legal numbers of the invoices and the taxes that are generated during the billing process in the JD Edwards EnterpriseOne Sales Order Management system to the JD Edwards EnterpriseOne Accounts Receivable system.
The Update Customer Sales program updates the Taxes - Tax Amount by Invoice Suffix table (F76A19). The accounts receivable invoice taxes are saved in the Taxes - Tax Amounts by Sales Order Line (F76A18) table.
Note: Detailed end of day processing is not supported. Verify that the processing options are set to summarize entries. |
This data selection prevents the system from processing any unbilled lines and ensures that all of the lines of the invoice are included, regardless of their status:
Operator | Left Operand | Comparison | Right Operand |
Where | BC Company (F4201) (CO) | is equal to | "00028" |
And | BC Document (Voucher, Invoice, and so forth) (F4211) (DOC) | is not equal to | <Blank> |
And | BC Document Type (F4211) (DCT) | is not equal to | <Blank> |
Select End of Day Processing (G4213), Update Customer Sales.
This section provides an overview of the purge process for Argentinean sales orders and discusses how to run the Invoice Total Purge - Argentine program.
The Invoice Total Purge -Argentine program (R76A09P) purges the localized tables and saves their information in new tables. The program first verifies that the records in the Invoice Total table (F76A09) correspond to records with a next status of 999 in the F4211 table. The program then purges the records from these tables:
Invoice Total (F76A09).
Taxes - Tax Amounts by Sales Order Line (F76A18).
Credit Invoice Header (F76A21).
Credit Invoice Detail (F76A22).
Credit Invoice Withholding (F76A23).
Header & Footer Invoice/Shipment Note History WF (F76A0209).
Detail Lines Invoice/Shipment Note History WF (F76A0219).
The program saves the purged information to these tables:
Invoice Total Purge (F76A09P).
Taxes - Tax Amounts Sales Order Line Purge (F76A18P).
Credit Invoice Header Purge (F76A21P).
Credit Invoice Detail Purge (F76A22P).
Credit Invoice Withholding Purge (F76A23P).
Header/Footer Inv./Shipment Note History WF Purge (F76A020P).
Detail Lines Inv./Shipment Note History WF Purge (F76A021P).
Note: If the program does not find records in the F4211 table that correspond to records in the F76A09 table, the program assumes that these records have been moved to the Sales Order History File table and eliminates the records. |
After you run the Invoice Total Purge -Argentine program (R76A09P), run these purge programs:
Sales Header Purge (F4201) (R4201P).
Sales Order Detail (F4211) (R4211P).
Note: The purge processes always run in final mode. |
Select Processes (G76A03B1), Invoice Total Purge - Argentine.
