This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Account Master business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Real-Time Events | This list includes the real-time events for the Account Master business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Account Master, business object which includes the RTAMOUT event.
RTAMOUT is used by the JD Edwards EnterpriseOne system to inform third-party systems of item additions, changes, or deletions of accounts in order to keep the two systems synchronized.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure |
| RTAMOUT | Account Master | RTE | Single | H09 | D0900170B: GL Account Real Time Event Notification Outbound Data |
A new general ledger account added in the JD Edwards EnterpriseOne system creates a new record in the Account Master (F0901) table. The user can create an alternate description for this account by language preference that is stored in the Account Master - Alternate Description (F0901D) table. If an account is added or modified in a system, the information is sent to a third-party system for add or update. If an account is deleted, the pertinent information is sent to the third-party, which will take the appropriate action. If applicable, the third-party integration must update the cross-reference table in the process in order to tie together the key values from both systems.
These objects can initiate the RTAMOUT event:
P0901 - Accounts
R0006QD - Update F0901 as Model Base on Table F0006
R09803 - Global Account Number Update
R09805 - Global Subsidiary Update
R09813 - Change Account Information
R09814 - Delete Account Master Records
R10861 - Delete Prior Consolidation
B0900053 - Duplicate Business Unit
B0900073 - Dynamic Account Creation
B0900075 - F0901D Update Account Translation
B0900077 - F0901D Edit Account Translation
B0900155 - Delete Account F0901/F0901D/F0902/F0911 Records
B1400009 - Global Budget Pattern Code Update
F0901/F0901D, F0902, F0911 Records
B5100017 - F5109 Copy Accounts
B5100140 - Update Project Account
