This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Account Ledger business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Real-Time Events | This list includes the real-time events for the Account Ledger business object: |
| Batch Import Programs | This list includes the batch import programs for the Account Ledger business object: |
| Additional Interfaces | The Account Ledger business object also uses the following business interfaces:
See Setting Processing Options for the Journal Entry Master Business Function (P0900049). |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Account Ledger, business object which includes:
RTPOSTOUT is used by the JD Edwards EnterpriseOne system to notify third-party systems when a batch has been successfully posted to the Account Balances table (F0902).
| Event Name | Event Description | Event Type | Event Category | Product Code | Data Structure |
| RTPOSTOUT | Fixed Asset GL Post | RTE | Single | 00 | D0900220B: a Journal Entry Post RTE Notification Message |
This event delivers a real time event notification when a batch has been successfully posted to the Account Balances table (F0902) using the General Ledger Post program (R09801). The status indicates only that the batch of journal entries has been successfully posted. If the batch fails to post, this event is not generated.
R09801 - General Ledger Post
RTBJESOUT is used by the JD Edwards EnterpriseOne system to notify third-party systems of the status of batch journal entries being processed through the Journal Entry Batch Processor (R09110Z).
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure |
| RTBJESOUT | Journal Entry | RTE | Single | 00 | D0900210B: Batch Journal Entry Status RTE Notification Message |
This event delivers a real time event notification of the status of batch journal entries being processed through the Journal Entry Batch Processor (R09110Z). The status indicates whether the journal entry document was created successfully. The reason for the failure is not included. The notification also includes the journal entry document number and general ledger date if the document is successfully added to the Account Ledger table (F0911).
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Account Ledger business object:
