This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Item Master business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Business Services | The Item Master business object uses these business service methods, which are documented under the InventoryManager web service (JP410000) documentation:
See Section 61.2, "Item Branch Master Business Services - InventoryManager." |
Real-Time Events | This list includes the real-time events for the Item Master business object: |
Batch Import Programs | This list includes the batch import programs for the Item Master business object: |
Batch Export Programs | This list includes the batch export programs for the Item Master business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Item Master business object, which include:
RTIMOUT is used by the JD Edwards EnterpriseOne system to notify third-party systems of item additions, changes, or deletions in order to keep the two systems synchronized.
Event Type | Event Description | Event Category | Event Aggregate | Product Code |
RTIMOUT | Item Master | RTE | Container
Container event for RTIMOUTA (D4102150B). |
H41 |
Conceptual Approach
A new item master or item branch added in the JD Edwards EnterpriseOne system creates a new record in the Item Master (F4101) table or the Item Branch (F4102) table. A real-time notification event is triggered in the maintenance application after item master or item branch information is added to either table.
Objects that Can Initiate the Event
These objects can initiate the RTIMOUT event, and the single event contained within the event:
B4102151 - Item Master Real Time Event Notify 2
N4101070 - Update Item Process Data
N4101130 - Workflow Update Approved Item Master Change
P4101N - Non Stock Item Master
R4101P - Item Master Purge (F4101)
P4690 - Warehouse Speed Group Maintenance
R4690 - Update Process and Item Dimens
BCW75 - Style Item Purge
RTIMOUTA is used by the JD Edwards EnterpriseOne system to notify third-party systems of item additions, changes, or deletions in order to keep the two systems synchronized.
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
RTIMOUTA | Item Master Details | RTE | Single | H41 | D4102150B: Item Master Real Time Event Notify Load Data | Included in container event RTIMOUT. |
Conceptual Approach
The JD Edwards EnterpriseOne system uses RTIMOUT2 to notify third-party systems of item additions, changes, or deletions in order to keep the two systems synchronized.
Oracle designed this version to support information related to country of origin and global location number.
RTIMOUT2 | Item Master Version 2 | RTE | Container
Container event for RTIMOUTB (D4102152B). |
H41 |
Conceptual Approach
These objects can initiate the RTIMOUT2 event, and the single event contained within the event:
RTIMOUTB is used by the JD Edwards EnterpriseOne system to notify third-party systems of item additions, changes, or deletions in order to keep the two systems synchronized.
RTIMOUTB | Item Master Details Version 2 | RTE | Single | H41 | D4102152B: Item Master Real Time Event Notify Load Data | Included in container event RTIMOUT. |
Conceptual Approach
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Item Master business object:
You use batch export programs to extract data from the JD Edwards EnterpriseOne system so that it can be consumed by an external software system.
This table lists and describes the available batch export programs that are associated with the Item Master business object:
Program and Program Type | Description | Available Documentation |
Item Batch Outbound (R4101ZO)
This is an outbound batch program. |
You run the Item Batch Outbound program to create an XML output file that contains information from the Item Master table (F4101) for specified items. | Access this program from menu G41313. |
