61 Item Branch Master
This chapter includes these topics:
61.1 Item Branch Master Overview
This chapter provides detailed information about the business interfaces that are available for the Item Branch Master business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Business Services The InventoryManager web service (JP410000) manages the processing of these inventory-related web service operations:
  • processSupplierCatalogPrice (J4100002)
  • processSupplierCatalogPriceV2 (J4100002)
  • processInventoryItem (J4100003)
  • processInventoryItemV2 (J4100003)
  • getBranchPlantItem (J4100004)
  • getBranchPlantItemV2 (J4100004)
  • getSupplierCatalogPrice (J4100005)
  • getSupplierCatalogPriceV2 (J4100005)
  • getItemAvailability (J4100001)
  • insertInventoryItemStaging (J4100006)
Batch Import Programs This list includes the batch import programs for the Item Branch Master business object:
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
61.2 Item Branch Master Business Services - InventoryManager
The InventoryManager web service (JP410000) manages the processing of inventory-related web service operations. This table includes a description of the inventory web service operations:
Operation Description
processSupplierCatalogPrice (J4100002) Use this operation to add and change supplier catalog prices within the JD Edwards EnterpriseOne Inventory Management system.
processSupplierCatalogPriceV2 (J4100002) Use this operation to add and update supplier catalog prices, including global locator number (GLN) within the JD Edwards EnterpriseOne Inventory Management system.
processInventoryItem (J4100003) Use this operation to add and change inventory item master records within the JD Edwards EnterpriseOne Inventory Management system.
processInventoryItemV2 (J4100003) Use this operation to add and change inventory item master records, including the country of origin required indicator, within the JD Edwards EnterpriseOne Inventory Management system.
getBranchPlantItem (J4100004) Use this operation to query the JD Edwards EnterpriseOne database for existing item branch/plant records.
getBranchPlantItemV2 (J4100004) Use this operation to query the JD Edwards EnterpriseOne database for existing item branch/plant records including the country of origin required indicator.
getSupplierCatalogPrice (J4100005) Use this operation to query the JD Edwards EnterpriseOne database for existing supplier catalog prices.
getSupplierCatalogPriceV2 (J4100005) Use this operation to query the JD Edwards EnterpriseOne database for existing supplier catalog prices along with GLN.
getItemAvailability (J4100001) Use this operation to query the JD Edwards EnterpriseOne database for existing item availability.
insertInventoryItemStaging (J4100006) Use this operation to insert inventory item staging records within the JD Edwards EnterpriseOne database.
insertInventoryItemStagingV2 (J4100006) Use this operation to insert inventory item staging records, including country of origin required indicator, within the JD Edwards EnterpriseOne database.
Additional Methods for Mobile Sales Functionality Additional methods were created for use specifically with the Mobile Sales features. For additional information about those methods, seeSection 6.3, "Mobile Applications."
61.2.1 Accessing Javadoc for the Inventory Manager Web Service Operations
To access Javadoc for the Inventory Manager web service and its related operations, review these Javadoc packages:
  • JP410000 (InventoryManager)
  • J4100002 (processSupplierCatalogPrice)
  • J4100002 (processSupplierCatalogPriceV2)
  • J4100003 (processInventoryItem)
  • J4100003 (processInventoryItemV2)
  • J4100004 (getBranchPlantItem)
  • J4100004 (getBranchPlantItemV2)
  • J4100005 (getSupplierCatalogPrice)
  • J4100005 (getSupplierCatalogPriceV2)
  • J4100001 (getItemAvailability)
  • J4100006 (insertInventoryItemStaging)
  • J4100006 (insertInventoryItemStagingV2)
61.2.2 Prerequisite
Before using the Inventory Manager web service, or any of the related web service operations, you must install and configure the JD Edwards EnterpriseOne Inventory Management system.
See JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
61.2.3 processSupplierCatalogPrice
The processSupplierCatalogPrice web service operation is an inbound transaction operation that enables consumers to process supplier catalog price information within the JD Edwards EnterpriseOne system. The consumer can add and change supplier catalog price records in the JD Edwards EnterpriseOne Inventory Management system. The system updates the Supplier Price/Catalog File table (F41061).
If the operation is successful, the system returns a confirmation message to the consumer which includes supplier catalog data.
If the operation fails, the system returns an error message to the consumer. When an error is encountered during processing of the processSupplierCatalogPrice web service operation, any changes to the F41061 that occurred as a result of the web service operation being run are rolled back.
The processSupplierCatalogPrice web service operation verifies that values are provided for both the start and end effective dates. If no value is provided for the start date then today's date is assigned to the start date. If no value is provided for the end date then December 31st of the current year is assigned to the end date. The processSupplierCatalogPrice web service operation retrieves the currency code from the specified supplier or, if the supplier does not exist, the specified business unit's company. If a currency code is specified, the currency code lookup is bypassed. The processSupplierCatalogPrice web service operation retrieves the cost level for a specified item and the appropriate unit of measure (purchasing or primary) from the Item Master table (F4101) as specified in the distribution constants. If a unit of measure is specified, the unit of measure lookup is bypassed.
The table illustrates the supported action codes for the processSupplierCatalogPrice web service operation:
Action Type Action Code
Add 1, A, I
Update 2, U, C
61.2.3.1 Supported Functionality
This section discusses the functionality that the processSupplierCatalogPrice operation supports.
If functionality is not explicitly documented as supported functionality, it is to be understood that the functionality is not supported by the integration solution.
The operation supports adding new supplier catalog prices and updating existing supplier catalog prices.
This web service operation does not support deleting supplier catalog prices. The operation also does not support adding or modifying supplier catalog prices for items with a cost level of 3.
61.2.3.2 Implementation Details
The following table includes information that can help determine whether the processSupplierCatalogPrice operation is functioning correctly:
Question Answer
How can I tell if the operation completes successfully? If the operation completes successfully, the system returns a confirmation message to the consumer. The return message includes all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
At a minimum, the system returns non-zero values for these fields:
  • supplier
  • item
  • currencyCode
  • unitOfMeasureCode
  • dateEffectiveStart
  • dateEffectiveEnd
The web service operation always returns an exception in the response if the operation fails to complete successfully.
If I encounter errors while processing a transaction, do I need to reverse the transaction? This operation uses standard transaction processing. Therefore, if you encounter errors during processing, the system does not update any information in the JD Edwards EnterpriseOne system. If the supplier catalog price action encounters errors, the transaction stops processing and the system rolls back the information in the tables. No manual update is necessary.
Does this operation use record reservation? No. This operation does not reserve records.
61.2.4 processSupplierCatalogPriceV2
Review the information in the processSupplierCatalog section of this chapter before using the processSupplierCatalogPriceV2 web service operation. All of the information in the processSupplierCatalogPrice section also applies to the processSupplierCatalogPriceV2 operation.
The processSupplierCatalogPriceV2 operation is a version of the processSupplierCatalogPrice web service operation. This web service operation is used to add and update supplier catalog prices and associated GLNs. This version executes the processSupplierCatalog (J4100002) web service operation.
61.2.5 processInventoryItem
The processInventoryItem web service operation is an inbound transaction operation that enables consumers to process inventory item information within the JD Edwards EnterpriseOne system. The consumer can add and change inventory item master records in the JD Edwards EnterpriseOne Inventory Management system.
The data provided for item master insertion must be in the JD Edwards EnterpriseOne format as no formatting is performed before item master insertion in JD Edwards EnterpriseOne begins. Also, codes must be values in the JD Edwards EnterpriseOne system.
If the operation is successful, the system returns a confirmation message to the consumer. The messages includes inventory item data.
61.2.5.1 Prerequisites
Before using the processInventoryItem operation, you must set the processing options for the Item Master program (P4101).
See "Setting Processing Options for Item Master (P4101)" in the JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
61.2.5.2 Supported Functionality
This section discusses the functionality that the processInventoryItem operation supports.
The processInventoryItem web service operation does not support the cancellation of inventory items.
61.2.5.3 Setup Considerations
Before you use this operation, you can set business service properties to specify how the system processes inventory item information. This table includes information about the business service properties that the processInventoryItem web service operation uses:
Group Key Description Default Value
J4100003 J4100003_ITEM_MBF_VERSION Use this business service property to specify which version of the Item Master program (P4101) the operation uses.
ZJDE0001
J4100003 J4100003_ITEM_STOCKING_TYPE_CODE Use this business service property to specify the stocking type code that the operation uses for an add request if the code is not provided. S
61.2.5.4 Implementation Details
The following table includes information that can help determine whether the processInventoryItem operation is functioning correctly:
Question Answer
At a minimum, the system returns non-zero values in the itemId field.
If I encounter errors while processing a transaction, do I need to reverse the transaction? This operation uses standard transaction processing. Therefore, if you encounter errors during processing, the system does not update any information in the JD Edwards EnterpriseOne system. No manual update is necessary.
Does this operation use record reservation? This operation reserves the inventory record immediately when an update is requested by the consumer.
61.2.6 processInventoryItemV2
Review the information in the processInventoryItem section of this chapter before using the processInventoryItemV2 web service operation. All of the information in the processInventoryItem section also applies to the processInventoryItemV2 operation.
The processInventoryItemV2 operation is a version of the processInventoryItem web service operation. This web service operation is used to add, update, and delete inventory item master records along with country of origin required indicator. This version executes the processInventoryItem (J4100003) web service operation.
61.2.7 getBranchPlantItem
The getBranchPlantItem web service operation is a database query operation that enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve existing branch/plant item records. The operation invokes a database operation to retrieve branch/plant item information from the F4101 and Item Branch File (F4102) tables in JD Edwards EnterpriseOne based on the selection criteria specified in the value object.
The data provided for selection must be in the JD Edwards EnterpriseOne format. No formatting is performed before the query is made. Also, codes must be values in the JD Edward EnterpriseOne system.
If the operation is successful, the system returns zero to many records to the consumer. You can specify the maximum number of records to return during a query using the Max Rows business service property. If the operation fails, the system returns an error message to the consumer.
The getBranchPlantItem web service operation enables source systems to query JD Edwards EnterpriseOne branch/plant item information in a real-time fashion. The query contains fields that can be used to filter the branch/plant item information retrieved by JD Edwards EnterpriseOne. ShowBranchPlant is returned during a successful query.
61.2.7.1 Supported Functionality
This section discusses the functionality that the getBranchPlantItem operation supports.
The getBranchPlantItem web service operation enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve existing branch/plant item records.
The getBranchPlantItem operation does not support the wildcard (asterisk (*)) for search criteria.
61.2.7.2 Setup Considerations
Before you use this operation, you can set business service properties to specify how the system processes inventory item information. This table includes information about the business service properties that the getBranchPlantItem web service operation uses:
J4100004 J4100004_V4102XPI2_MAX_GRID_ROWS_RETURNED Use this business service property to define the maximum number of rows that the operation returns when querying the JD Edwards EnterpriseOne database. 100
It is strongly recommended that you set this business service property to a value other than 0 (zero). If you leave this value set to 0, the system returns all matching records. Additionally, it is recommended that you specify selection criteria when you query the JD Edwards EnterpriseOne database. The system returns an error if you perform a query with no selection criteria and this business service property is set to 0.
61.2.7.3 Implementation Details
The following table includes information that can help determine whether the getBranchPlantItem operation is functioning correctly:
Question Answer
How can I tell if the operation completes successfully? If the operation completes successfully, the system returns records that match your search criteria. These records include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
At a minimum, if the query finds matching records, the system returns non-zero values for these fields:
  • branchPlant
  • supplier
  • buyer
  • itemId
If I encounter errors while processing a transaction, do I need to reverse the transaction? This is a database query operation that does not perform transactions.
If you encounter errors during processing, review your search criteria and business service property settings and try your query again. If the operation does not return any records, verify that records matching your query exist in the JD Edwards EnterpriseOne database.
Does this operation use record reservation? No. This operation does not reserve records that are returned in a query.
61.2.8 getBranchPlantItemV2
Review the information in the getBranchPlantItem section of this chapter before using the getBranchPlantItemV2 web service operation. All of the information in the getBranchPlantItem section also applies to the getBranchPlantItemV2 operation.
The getBranchPlantItemV2 operation is a version of the getBranchPlantItem web service operation. This web service operation is used to retrieve branch plant item records along with country of origin required indicator. This version executes the getBranchPlantItem (J4100004) web service operation.
61.2.9 getSupplierCatalogPrice
The getSupplierCatalogPrice web service operation is a database query operation that enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve existing supplier catalog price information. The operation retrieves supplier catalog price information from fields in the Supplier Price/Catalog File table (F41061).
If the operation is successful, the system returns zero to many records to the consumer. You can specify the maximum number of records to return during a query using the Max Grid Rows Returned business service property. If the operation fails, the system returns an error message to the consumer.
61.2.9.1 Supported Functionality
This section discusses the functionality that the getSupplierCatalogPrice operation supports.
The getSupplierCatalogPrice web service operation enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve existing supplier catalog price information.
The getSupplierCatalogPrice operation does not support the wildcard (asterisk (*)) for search criteria.
61.2.9.2 Setup Considerations
Before you use this operation, you can set business service properties to specify how the system processes supplier catalog price information. This table includes information about the business service properties that the getSupplierCatalogPrice web service operation uses:
J4100005 J4100005_F41061_MAX_GRID_ROWS_RETURNED Use this business service property to define the maximum number of rows that the operation returns when querying the JD Edward EnterpriseOne database. 100
61.2.9.3 Implementation Details
The following table includes information that can help determine whether the getSupplierCatalogPrice operation is functioning correctly:
Question Answer
  • entityIdSupplier
  • itemId
  • itemProduct
  • itemCatalog
  • currencyCode
  • unitOfMeasureCode
The operation may complete successfully without returning rows because the selection criteria did not match any records in the database or an open query was performed and there were no records. This is considered successful and provides valid information.
61.2.10 getSupplierCatalogPriceV2
Review the information in the getSupplierCatalogPrice section of this chapter before using the getSupplierCatalogV2 web service operation. All of the information in the getSupplierCatalogPrice section also applies to the getSupplierCatalogPriceV2 operation.
The getSupplierCatalogPriceV2 operation is a version of the getSupplierCatalogPrice web service operation. This web service operation is used to retrieve supplier catalog price records with associated GLNs. This version executes the getSupplierCatalogPrice (J4100005) web service operation.
61.2.11 getItemAvailability
The getItemAvailability web service operation is a database query operation that enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve item availability information.
The getItemAvailability web service operation calls the InvRealTimeItemAvailability business function (B4101640) to fetch item availability. You must specify itemId, businessUnit, and unitOfMeasure as inputs to the query. If the operation is successful, the system returns item availability data. If the operation fails, the system returns an error message to the consumer.
61.2.11.1 Supported Functionality
This section discusses the functionality that the getItemAvailability operation supports.
The getItemAvailability web service operation enables consumers to query the JD Edwards EnterpriseOne Inventory Management system to retrieve item availability information.
The getItemAvailability operation does not support the wildcard (asterisk (*)) for search criteria.
61.2.11.2 Setup Considerations
Before you use this operation, you can set business service properties to specify how the system processes item availability information. This table includes information about the business service properties that the getItemAvailability web service operation uses:
J4100001 J4100001_ERROR_PREFIX_1 Use this business service property to specify the prefix value the operation uses for error messages. Get Item Availability Sent In:
61.2.11.3 Implementation Details
The following table includes information that can help determine whether the getItemAvailability operation is functioning correctly:
Question Answer
  • businessUnit
  • transactionUnitOfMeasure
  • quantityAvailable
  • itemId
61.2.12 insertInventoryItemStaging
The insertInventoryItemStaging web service operation is a database insert operation that enables consumers to insert one to many inventory item records into the staging table in the JD Edwards EnterpriseOne database.
The insertInventoryItemStaging web service operation uses auto commit transaction processing. Since inventory item records are autonomous, each inventory item staging record is immediately added to the F4101 Item Master Unedited Transaction Table (F4101Z1) and the entire group is not rolled back if an error occurs. If the operation is successful, the system inserts one to many records. You can specify the maximum number of records to insert using the Max Rows business service property.
If the operation fails, the system returns an error message to the consumer. The records that return an error will not be inserted into the database. However, records that do not error are committed to the database even if other records in the same transaction fail.
If all rows passed in were not inserted into the staging table, then the system returns an error message. The Max Rows business service property limits the number of inserted records. The consumer then sends the data in groups less than the Max Rows business service property or changes the Max Rows business service property to 0 (zero) so that all records are inserted.
The data provided for insertion must be in the JD Edwards EnterpriseOne format. No formatting is performed before the insert is made.
61.2.12.1 Supported Functionality
This section discusses the functionality that the insertInventoryItemStaging operation supports.
The operation supports the insert of one to many inventory item records into the staging table in the JD Edwards EnterpriseOne database.
This web service operation does not support changing or deleting inventory item staging records.
61.2.12.2 Setup Considerations
Before you use this operation, you can set business service properties to specify how the system processes inventory item staging records. This table includes information about the business service properties that the insertInventoryItemStaging web service operation uses:
J4100006 J4100006_MAX_ROWS Use this business service property to define the maximum number of rows that the operation inserts in the JD Edward EnterpriseOne database. 999
J4100006 J4100006_ITEM_STOCKING_TYPE_CODE Use this business service property to specify the stocking type code that the operation uses for the insert if the code is not provided. S
The Max Rows business service property limits the number of inserted records. Either send the data in groups less than the Max Rows business service property or change the Max Rows service constant to 0 (zero). If you set this value to 0, the system inserts all records.
61.2.12.3 Implementation Details
The following table includes information that can help determine whether the insertInventoryItemStaging operation is functioning correctly:
Question Answer
How can I tell if the operation completes successfully? If the operation completes successfully, the system returns a confirmation message to the consumer that includes the number of rows that were inserted into the F4101Z1 table.
If I encounter errors while processing a transaction, do I need to reverse the transaction? No, records that return an error are not inserted into the database. Records that do not return an error are committed to the database even if other records in the same transaction fail.
If you encounter errors during processing, review your insertion criteria and business service property settings and try your insert again.
61.2.13 insertInventoryItemStagingV2
Review the information in the insertInventoryItemStaging section of this chapter before using the insertInventoryItemStagingV2 web service operation. All of the information in the insertInventoryItemStaging section also applies to the insertInventoryItemStagingV2 operation.
The insertInventoryItemStagingV2 operation is a version of the insertInventoryItemStaging web service operation. This web service operation is used to insert inventory item staging records, including the country of origin required indicator. This version executes the nsertInventoryItemStaging (J4100006) web service operation.
