This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Sales Order business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Business Services | The SalesOrderManager web service (JP420000) manages the execution of these sales order-related web service operations:
Real-Time Events | This list includes the real-time events for the Sales Order business object: |
Batch Import | This list includes the batch import programs for the Sales Order business object:
Batch Export Programs | This list includes the batch export programs for the Sales Order business object:
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
The SalesOrderManager web service (JP420000) manages the execution of sales order-related web service operations. This table includes a description of the sales order web service operations:
To access Javadoc for the Sales Order Manager web service and its related operations, review these Javadoc packages:
JP420000 (SalesOrderManager)
J4200010 (processSalesOrder)
J4200010 (processSalesOrderV2)
J4200010 (processSalesOrderV3)
J4200010 (processSalesOrderV5) (Release 9.1 Update)
J4200020 (processSalesPriceAdjustment)
J4200030 (getItemPriceAndAvailability)
J4200030 (getItemPriceAndAvailabilityV2)
J4200040 (getCustomerItemPrice)
J4200040 (getCustomerItemPriceV2)
J4200050 (getSalesOrder)
J4200050 (getSalesOrderV2)
J4200050 (getSalesOrderV3)
J4200050 (getSalesOrderV4)
J4200060 (getItemListPrice)
J4200070 (getSalesOrderPriceHistory)
Before you use the Sales Order Manager web service, or any of the related operations, you must install and set up these JD Edwards EnterpriseOne systems:
Sales Order Management
Inventory Management
Note: Many of these operations managed by the SalesOrderManager web service process pricing information. If you want these operations to process pricing information using advanced pricing functions, you must install and set up the JD Edwards EnterpriseOne Advanced Pricing system. If you do not set up this system, these operations will process, but they will not include advanced pricing calculations. |
See JD Edwards EnterpriseOne Applications Advanced Pricing Implementation Guide.
See JD Edwards EnterpriseOne Applications Sales Order Management Implementation Guide.
See JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
The processSalesOrder web service operation is an inbound transaction operation that enables consumers to add, change, and cancel these order types in the JD Edwards EnterpriseOne Sales Order Management system:
Sales orders
Blanket orders
Credit orders
Direct ship orders
Quote orders
Transfer orders
Transportation orders
If the operation encounters errors during processing, the system returns those errors to the consumer.
Before using this operation, you must be familiar with entering, updating and deleting sales orders in the JD Edwards EnterpriseOne system.
This section discusses the functionality that the processSalesOrder operation supports.
Note: If functionality is not explicitly documented as supported functionality, it is to be understood that the functionality is not supported by the integration solution. |
The processSalesOrder operation supports inventory/stock items, configured items, non-stock items such as miscellaneous, text lines and freight, and direct ship items. An order may contain one or more of these line types.
(Release 9.1 Update) The processSalesOrder operation supports retrieval of the alternate tax rate/area assignment if the functionality is enabled for the entities involved in the transaction.
Though the solution does support the addition, change or cancellation of blanket orders, the solution does not support automatic blanket order release. Additionally, the solution does not support blanket orders for configured items.
The solution supports advanced pricing for line, basket, and order-level pricing. The operation does not support advanced pricing when an override price is passed in by the consumer.
The solution does not support kit items. If the consumer enters a kit item, the system will process the information, but kit processing is not initiated in the JD Edwards EnterpriseOne system. The operation returns a Kit Components Are Not Processed message to the consumer.
If a kit parent item is entered by the consumer, the system processes the parent, but does not initiate kit processing for components. To resolve the issue, the consumer must use the JD Edwards EnterpriseOne Sales Order Entry program (P4210) to choose the kits components.
The solution does support the processing of configured items. The operation provides the consumer with a field structure that enables the specification of configured items and their segments.
Configured items may be pre-evaluated and passed into the JD Edwards EnterpriseOne system as they are, which is known as bypass. Alternatively, consumers can pass items into the JD Edwards EnterpriseOne system and have the item evaluated using JD Edwards EnterpriseOne defined rules and logic.
Configured parent items may contain child items of varying types, such as stock, non-stock and configurable.
Configured items are enabled for sales orders and quote orders only at the configured item parent level.
The solution does not support blanket orders for configured items.
When processing configured items, be aware of the following items:
The stocking type for a configured item is hard-coded as C.
The consumer must provide segment answers when adding or changing a configured item.
To utilize the JD Edwards EnterpriseOne rules and logic for evaluation, segment answers and configured components are required when adding or changing a configured item.
To bypass evaluation in the JD Edwards EnterpriseOne system, the consumer must provide the segment answers and all components when adding or changing a configured item.
The solution does not validate segment answers and cross-segment editing rules.
The consumer must sequence the configuration by children before siblings.
For example, configured item A has components A1 and A2. Component A1 has another child component, A11. Using this example, the input to the operation should follow this sequence:
parentItem = null, childItem = A
parentItem = A, childItem = A1
parentItem = A, childItem = A2
parentItem = A1, childItem = A11
The solution does not support the changing or cancellation of individual components of a configured item.
When processing the cancellation of a configured item, the operation also cancels the components from the sales order details.
The solution does not support back orders, transfer orders, direct ship orders, and inter-branch orders for configured items.
The price will be overridden when the isZeroPriceOverride field is set to true, or there is a price (domestic/foreign) in the input document.
The solution does not support:
Dynamic rules validation during configuration.
The limitation of configured selections to include only valid responses.
Calculation of pricing rules based on a user-defined date.
Before using this operation, you can set business service properties to specify how the system processes sales order information. This table includes information about the business service properties that the processSalesOrder web service operation uses:
Group | Key | Description | Default Value |
J4200010 | J4200010_SOE_MBF_VERSION | Use this business service property to specify the version of the Sales Order Entry program (P4210) that the operation uses when processing data. | ZJDE0001 |
J4200010 | J4200010_BYPASS_WARNINGS | Use this business service property to specify whether the operation bypasses warnings that occur during processing.
If you choose to bypass warnings, the operation continues processing to the end, and returns all warnings to the consumer. If you choose not to bypass warnings, change the default value to 2. Using this setting, the operation stops processing when a warning is encountered and the warning is returned to the consumer. |
1: Bypass Warnings |
See JD Edwards EnterpriseOne Tools Business Services Development Methodology Guide.
The following table includes information that can help determine whether the processSalesOrder operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns a confirmation message to the consumer. The message includes all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the EnterpriseOne system.
At a minimum, the system returns non-zero values for these fields:
If I encounter errors while processing a transaction, do I need to reverse the transaction? | This operation uses standard transaction processing. In the event that the operation encounters errors, all JD Edwards EnterpriseOne tables are returned to their original state, and no updates are performed. No manual updates are necessary. |
Does this operation use record reservation? | This operation reserves records in the JD Edwards EnterpriseOne system during the change or cancellation of a sales order. |
Review the information in the processSalesOrder section of this chapter before using the processSalesOrderV2 web service operation. All of the information in the processSalesOrder section also applies to processSalesOrderV2.
processSalesOrderV2 is a new version of the processSalesOrder web service operation. This web service operation is used to add, update, or cancel sales orders with taxed prices when the Sales Taxed Prices constant is selected. This new version executes the processSalesOrder (J4200010) web service operation.
Review the information in the processSalesOrder section of this chapter before using the processSalesOrderV3 web service operation. All of the information in the processSalesOrder section also applies to processSalesOrderV3.
The processSalesOrderV3 operation is a version of the processSalesOrderV2 web service operation. This web service operation is used to add, update, or cancel sales orders along with GLNs. This version executes the processSalesOrder (J4200010) web service operation.
Review the information in the processSalesOrder V1, V2, and V3 sections of this chapter before using the processSalesOrderV5 web service operation. All of the information in the other versions of the processSalesOrder methods also applies to processSalesOrderV5.
The processSalesOrderV3 operation is a version of the processSalesOrder web service operation. This web service operation is used to add, update, or cancel sales orders along with Opportunity IDs. This version executes the processSalesOrder (J4200010) web service operation.
The processSalesPriceAdjustment operation is an inbound transaction operation that enables consumers to process sales price adjustment information within the JD Edwards EnterpriseOne system.
The consumer can add this information to the JD Edwards EnterpriseOne Sales Order Management system:
Price adjustment definition records.
Price adjustment detail records.
Price adjustment schedule records.
Consumers are also able to modify existing price adjustment detail records, provided that values for the adjustment name and adjustment ID are passed in.
If the system encounters errors while processing transactions using this operation, error messages are generated and returned to the consumer.
Be aware that this operation updates only the pricing setup records in the JD Edwards EnterpriseOne system. Existing sales orders are not updated with pricing details that are entered into the system using this operation. To reprice existing sales orders using the updated pricing information, you must process the Sales Order Batch Price/Cost Update program (R42950).
Note: To add a price adjustment detail record, you must include a unit of measure (UoM). If you do not include a unit of measure, the system returns a hard error to the consumer.If currency processing is turned on, you must include a currency code. If no currency code is passed in, and currency processing is enabled, the system returns a hard error to the consumer. If no dates are passed in, the system uses the system date as the effective date, and an expiration date that is generated by business function B4000630. |
Before using the processSalesPriceAdjustment operation, you must install and configure the JD Edwards EnterpriseOne Advanced Pricing system.
This section discusses the functionality that the processSalesPriceAdjustment operation supports.
When adding price adjustment definition records:
Item price groups, customer price groups, and order detail groups are not supported.
Basket, order, and volume level adjustments are not supported.
Only line level adjustments are supported.
Weight, amount, and quality level breaks are not supported.
Only quantity level breaks are supported.
These adjustment control codes are supported:
Blank
2: Print on Invoice
4: Accruals
When making changes to price adjustment detail records:
The From Level value always starts at 1.
Basis code 5 (Add on Amount) is supported.
Before you use this operation, you can set a business service property to define which version of the Live Promotions Interface Processing program (R45720Z) to use. This table lists the business service properties that the processSalesPriceAdjustment operation uses:
J4200020 | J4200020_PROM_MBF_VERSION | Use this business service property to specify the version of the Live Promotions Interface Processing program (R45720Z) that this operation uses. | ZJDE0002 |
The following table includes information that can help determine whether the processSalesPriceAdjustment operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns a confirmation message to the consumer. The message includes all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
If I encounter errors while processing a transaction, do I need to reverse the transaction? | This operation uses standard transaction processing. Therefore, if you encounter errors during processing, the system does not update any information in the JD Edwards EnterpriseOne system. No manual update is necessary. |
Does this operation use record reservation? | No. This operation does not reserve records in the JD Edwards EnterpriseOne system during processing. |
You use processing options to set up default values and processing data for a program.
Use this processing option to specify a preference type or a price adjustment hierarchy defined in user-defined code (UDC) table 40/PR. This value gets stored in the Price Adjustment Type table (F4071) in field ATPRFR (Preference) and its associated hierarchy is used for resolving pricing adjustments.
The processing options on this tab are used to define the adjustment definition. One of the input parameters, such as costTypeCode, determines whether the adjustment is a Bill Back or an Off Invoice adjustment. The value sent in becomes part of the adjustment definition record that is stored in the F4071 table. Adjustment types include 1(Bill Back: Adjustment Control Code = 4, Accruals) or 2 (Off Invoice: Adjustment Control Code = 2, Print on Invoice). If no value is passed in for costTypeCode field, Adjustment Control Code, stored in field ATACNT of the F4071 table, is blank.
Use this processing option to specify the trade account that the system uses as the offset when you post invoices or vouchers. This value gets stored in the Price Adjustment Type table (F4071) in field ATGLC (GLClass).
Use this processing option to identify a detailed, auxiliary account within a general ledger account. A subledger can be an equipment item number or an address book number. If you enter a subledger, you must also specify the subledger type.
This value is stored in the Price Adjustment Type table (F4071) in field ATSBIF (SubledgerInformation).
Use this processing option to specify the schedule option. Values are:
1: Single
2: Customer
3: Manual
Use this processing option to specify the name of the schedule.
Use this processing option to specify the one-character prefix that is used for the adjustment name. The adjustment name is the prefix plus the next number plus the suffix for Bill Back and Off Invoice adjustment names. For example, if the prefix is S and the suffix is B (Bill Back), the adjustment name might be S123456B.
Use this processing option to specify the one-character suffix that is used for the adjustment name. The adjustment name is the prefix plus the next number plus the suffix for Bill Back and Off Invoice adjustment names. For example, if the prefix is S and the suffix is B (Bill Back), the adjustment name might be S123456B.
Use this processing option to specify the numeric increment for sequence in schedule. If you leave this option blank, the system uses an increment of 1.0.
Use this processing option to specify the beginning value in a range of sequence numbers that are reserved for promotions.
Use this processing option to specify the ending value in a range of sequence numbers that are reserved for promotions.
Use this processing option to specify the adjustment name for Bill Back spending method.
Note: If you leave options 3 and 4 blank, you must enter a value in this processing option and in option 2. |
Use this processing option to specify the adjustment name for Off Invoice spending method.
Note: If you leave options 3 and 4 blank, you must enter a value in this processing option and in option 1. |
Note: If you leave options 1 and 2 blank, you must enter a value in this option and in option 4. |
Note: If you leave options 1 and 2 blank, you must enter a value in this option and in option 3. |
Review the information in the processSalesPriceAdjustment section of this chapter before using the processSalesPriceAdjsutmentV2 web service operation. All of the information in the processSalesPriceAdjustment section also applies to processSalesPriceAdjustmentV2.
The processSalesPriceAdjustmentV2 operation is a version of the processSalesPriceAdjustment web service operation. This web service operation is used to add or update price adjustment details along with GLNs. This version executes the processSalesPriceAdjustment (J4200020) web service operation.
The getItemPriceAndAvailability web service operation is an inbound transaction operation that enables consumers to retrieve pricing, availability, and branch/plant information for items that are stored in the JD Edwards EnterpriseOne Inventory Management system.
Note: There are several operations that return item prices to the consumer. Use this operation if you want to review item availability information in addition to pricing information. |
This operation uses the information that the consumer passes in, along with the Price and Availability Header business function (B4204100), to simulate the creation of a sales order header and sales order detail information. The system then uses this simulated sales order to retrieve pricing information. The price is based on the branch/plant that the consumer passes in. If the consumer does not pass in a branch/plant, the system calculates the price using the branch/plant from the processing options of the P4210. The operation then returns to the consumer the unit price and extended price for the item.
Additionally, the operation uses the Retrieve F41021 Records business function (B4204120) to calculate the availability of the item in the specified branch/plant. The operation then returns to the consumer the availability information, along with the address book number and mailing address of the branch/plant.
If the operation encounters errors or warnings during processing, the system returns those errors and warnings to the consumer.
This section discusses the functionality that the getItemPriceAndAvailability operation supports.
This operation does not support configured items, as configured items typically do not have availability information.
If you are using advanced pricing, the operation applies markups and discounts. The operation does not apply free goods and rebates.
Before you use this operation, you can set business service properties to specify how the system retrieves and calculates price and availability information. This table includes information about the business service properties that the getItemPriceAndAvailability operation uses:
J4200030 | J4200030_SOE_MBF_VERSION | Use this business service property to specify the version of the Sales Order Entry program (P4210) that the operation uses when processing price and availability information. | ZJDE0001 |
J4200030 | J4200030_BYPASS_BSFN_WARNINGS | Use this business service property to specify whether the operation bypasses warnings that occur during processing.
The getItemPriceAndAvailability operation uses the Sales Order Entry program (P4210) to simulate the creation of a sales order for the purposes of retrieving price and availability information. Typically, the version of the Sales Order Entry program that is used to create and process sales orders is set up to include full editing and validations. The getItemPriceAndAvailability operation does not need to complete these processes. Therefore, to improve performance, you might consider using a different version of the Sales Order Entry program when processing this operation.
In addition to using a separate version of the P4210, it is also recommended that you use these guidelines when setting the processing options for the version used by this operation:
Order Holds must be blank.
Activate Availability Checking must be blank.
Blanket or Quote Processing must be blank.
Inventory Commitment Preferences must be blank.
If Preferences are turned on, the following preferences must not be used:
Product Allocation
Grade and Potency
Next Order Status
Sales Commissions
This table includes information that can help determine whether the getItemPriceAndAvailability operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system does not return errors to the consumer. In some instances, the consumer does not receive a return message. For example, if the item in the query does not have price or availability information, the operation does not return data to the consumer, even though it has successfully processed.
If the operation is successful in finding matching data, price and availability information for the items included in the query are returned to the consumer. The records that are returned to the consumer include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system. At a minimum, the system returns non-zero values for these fields:
If I encounter errors while processing a transaction, do I need to reverse the transaction? | This is a query operation. No transactions occur during the processing of this operation. Therefore, no data updates are necessary if errors are encountered. |
Does this operation use record reservation? | No. The operation does not reserve records within the JD Edwards EnterpriseOne system during processing. |
Before you can process this operation successfully, you must enter items into the JD Edwards EnterpriseOne Inventory Management system.
See "Setting Up the Inventory Management System" and "Entering Item Information" in the JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
Review the information in the getItemPriceAndAvailability section of this chapter before using the getItemPriceAndAvailabilityV2 web service operation. All of the information in the getItemPriceAndAvailability section also applies to getItemPriceAndAvailabilityV2.
getItemPriceAndAvailabilityV2 is a new version of the getItemPriceAndAvailability web service operation. This web service operation is used to retrieve the sales price of the item, including taxed prices using the base price or advanced pricing for the specific branch plant and item availability, when the Sales Taxed Prices constant is selected. This new version executes the getItemPriceAndAvailability (J4200030) web service operation.
Review the information in the getItemPriceAndAvailability section of this chapter before using the getItemPriceAndAvailabilityV3 web service operation. All of the information in the getItemPriceAndAvailability section also applies to getItemPriceAndAvailabilityV3.
The getItemPriceAndAvailabilityV3 operation is a version of the getItemPriceAndAvailabilityV2 web service operation. This web service operation is used to retrieve the sales price of the item, including GLNs, using the base price or advanced pricing for the specific branch plant and item availability. This version executes the getItemPriceAndAvailability (J4200030) web service operation.
The getCustomerItemPrice web service operation is an inbound transaction operation that enables consumers to retrieve item pricing information that is based on the base pricing or on advanced pricing with line-level discounts or markups.
Note: There are several operations that return item prices to consumers. Use this operation if you want to review the cost of an item for a particular customer. |
This operation uses the information that the consumer passes in, along with the Price and Availability Header business function (B4204100), to simulate the creation of a sales order header and sales order detail information. The system then uses this simulated sales order to retrieve pricing information for the specified item and customer.
You can include only one item in each request.
This section discusses the functionality that the getCustomerItemPrice operation supports.
The getCustomerItemPrice operation does not include basket or order-level adjustments when calculating the final price of the item.
Consumers can request pricing information for kit and configured items. However, the operation returns prices only for the parent item if one has been specified.
Before you use this operation, you can set business service properties to specify how the system retrieves and calculates price and availability information. This table includes information about the business service properties that the getCustomerItemPrice operation uses:
The getCustomerItemPrice operation uses the Sales Order Entry program (P4210) to simulate the creation of a sales order for the purposes of retrieving price and availability information. Typically, the version of the Sales Order Entry program that is used to create and process sales orders is set up to include full editing and validations. The getCustomerItemPrice operation does not need to complete these processes. Therefore, to improve performance, you might consider using a different version of the Sales Order Entry program when processing this operation.
Product Allocation
Grade and Potency
Next Order Status
Sales Commissions
This table includes information that can help determine whether the getCustomerItemPrice operation is functioning correctly:
Question | Answer |
Review the information in the getCustomerItemPrice section of this chapter before using the getCustomerItemPriceV2 web service operation. All of the information in the getCustomerItemPrice section also applies to getCustomerItemPriceV2.
getCustomerItemPriceV2 is a new version of the getCustomerItemPrice web service operation. This web service operation is used to retrieve the sales price of the item, including the taxed prices and taxed amounts with line level discounts and/or markups using the base price or advanced pricing, when the Sales Taxed Prices constant is selected. This new version executes the getCustomerItemPrice (J4200040) web service operation.
The getSalesOrder web service operation is a database query operation that enables consumers to review sales orders that exist in the JD Edwards EnterpriseOne Sales Order Management system.
The getSalesOrder operation uses the Sales Order Inquiry business view (V4211XBP) to select records from the JD Edwards EnterpriseOne Sales Order Management system based on the information that the consumer enters. If no errors are encountered, the operation searches the database for records that match the consumer's query, adding those records to the result set.
The operation returns one or more sales order header records to the consumer, based on the information that was passed in. In addition, the operation returns all sales order detail lines associated with those sales order header records.
If the operation encounters errors while querying the database, it stops processing and returns the errors to the consumer.
Note: The consumer must enter search criteria in order for the operation to process successfully. If the consumer attempts to query the database without specifying any search criteria, the operation returns an error to the consumer. |
Before you use this operation, you can set business service properties to specify how many records the system returns when you query the JD Edwards EnterpriseOne database. This table includes information about the business service properties that the getSalesOrder operation uses:
J4200050 | J4200050_MAX_ROWS | Use this business service property to specify the maximum number of rows that the query will return.
Note: The number of rows includes both sales order header records and sales order detail records. |
0: Return all records. |
Note: If you leave this constant set to 0, the system returns all records that match the specified search criteria. To improve processing time, it is recommended that you set the default value for this business service property to a value other than 0. |
This table includes information that can help you determine whether the getSalesOrder operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns records that match your search criteria. The records include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
At a minimum, if the query finds matching records, the system returns non-zero values for these fields:
If I encounter errors while processing the operation, do I need to reverse the transaction? | This is a query operation. No transactions occur during the processing of this operation. Therefore, no data updates are necessary if errors are encountered. |
Does this operation use record reservation. | No. The operation does not reserve records that are returned in the query. |
Before you can use this operation, sales orders must exist in the JD Edwards EnterpriseOne database.
See "Entering Sales Orders" and "Entering Sales Orders for Customer Service Representatives" in the JD Edwards EnterpriseOne Applications Sales Order Management Implementation Guide.
Review the information in the getSalesOrder section of this chapter before using the getSalesOrderV2 web service operation. All of the information in the getSalesOrder section also applies to getSalesOrderV2.
getSalesOrderV2 is a new version of the getSalesOrder web service operation. This web service operation is used to retrieve the sales order information in real-time, including taxed prices and taxed amounts. This new version executes the getSalesOrder (J4200050) web service operation.
Review the information in the getSalesOrder section of this chapter before using the getSalesOrderV3 web service operation. All of the information in the getSalesOrder section also applies to getSalesOrderV3.
The getSalesOrderV3 operation is a version of the getSalesOrderV2 web service operation. This web service operation is used to retrieve the sales order information in real-time, including GLNs. This version executes the getSalesOrder (J4200050) web service operation.
Review the information in the getSalesOrder section, and all additional versions of the getSalesOrder method, before using the getSalesOrderV4 web service operation. All of the information in the previous versions of getSalesOrder also apply to getSalesOrderV4. Additionally, the getSalesOrderV4 web service has been modified to search by opportunity ID, and to include opportunity information.
The getSalesOrderV4 operation is a version of the getSalesOrder web service operation.
The getItemListPrice web service operation is a database query operation that enables consumers to view a list of base prices for a specified item. Consumers can also specify the business unit in order to view a list of base prices for an item by business unit.
Before you use this operation, you can set business service properties to specify how many records the system returns for a query. This table includes information about the business service properties that the getItemListPrice operation uses:
J4200060 | J4200060_MAX_ROWS | Use this business service property to specify the maximum number of records that the system returns for a query. | 0: Return All Records |
This table includes information that can help determine whether the getItemListPrice operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns a list of prices for the item and or business unit specified by the consumer. The records that are returned to the consumer include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
At a minimum, the system returns non-zero values for the priceList field. |
Before using this operation, you must enter items and base pricing information in the JD Edwards EnterpriseOne Inventory Management system.
See "Entering Item Master Information" and "Entering Sales Price Information" in the JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
The getSalesOrderPriceHistory web service operation is a database query operation that enables consumers to inquire on price history information that resides in the JD Edwards EnterpriseOne Price Adjustment Ledger table (F4074). The consumer can search for price history by passing in any combination of these fields:
Order Number
Order Type
Order Company
Line Number
Note: You must pass in at least one of these fields when entering a query. If you enter a blank query, the system returns an error message. |
Before you use this operation, you can set business service properties to specify how many records the system returns for a query. This table includes information about the business service properties that the getSalesOrderPriceHistory operation uses:
J4200070 | J4200070_MAX_ROWS | Use this business service property to specify the maximum number of records that the system returns for a query. | 0: Return all matching records. |
Note: If you enter a default value of 0 for this business service property, the system does not limit the number of rows returned during a query. To improve processing time, it is recommended that you set the default value for this business service property to a value other than 0. |
This table includes information that can help determine whether the getSalesOrderPriceHistory operation is functioning correctly:
Question | Answer |
How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns a list of price history records to the consumer. The records that are returned to the consumer include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system.
If I encounter errors while processing a transaction, do I need to reverse the transaction? | If you encounter errors while processing this operation, verify your business service properties and selection criteria. Then perform your query again.
If the system does not return any matching records, verify that matching records exist in the JD Edwards EnterpriseOne database. |
This section discusses the real-time events generated by Sales Order Management system. See Setting Up Real-Time Event Filtering in the JD Edwards EnterpriseOne Applications Sales Order Management Implementation Guide.
This list describes the available real-time events associated with the Sales Order business object, which include:
RTSOOUT, which is a container event for these single events:
RTSOOUT2, which is a container event for these single events:
RTSOOUT3, which is a container event for these single events:
The RTSOOUT event is used by the JD Edwards EnterpriseOne system to publish sales order header and detail information.
Event Type | Event Description | Event Category | Event Aggregate | Product Code |
RTSOOUT | Sales Order | RTE | Container
Contains events for:
H42 |
Conceptual Approach
When a user creates, modifies, or cancels a sales order, the system triggers a notification event. This notification event, RTSOOUT, contains two separate events: RTSOHDR and RTSODTL. The RTSOHDR event contains all information pertinent to the sales order header. The RTSODTL event contains all information pertinent to each sales order detail line.
Objects that Can Initiate the Event
These objects can initiate the RTSOOUT event, and the single events contained within the event:
B3104430 - F4211 Update Miscellaneous Fields for KIT Items
B3201180 - WO Update Configured Item Costs to F4211 and F3215
B3201400 - Update Conig. Driven F4211 Fields
B4003000 - XPI Publish Events From Cache
B4003020 - XPI Publish Events From Cache 2
B4200310 - F4211 FS End Doc
B4201220 - Update F4211 Sales Detail and F42199 S.O. Ledger
B4208060 - XPI Work Flow Post Commit For TP
B4300250 - Release Held Order
N3200840 - F4211 Update Configured Item Costs
N4600455 - Change F4211 SO Detail File
RTSOHDR is used by the JD Edwards EnterpriseOne system to publish sales order header information.
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
RTSOHDR | Sales Order Header | RTE | Single | H42 | D4202310A: Sales Order Header | Included in container event RTSOOUT. |
Conceptual Approach
RTSODTL event is used by the JD Edwards EnterpriseOne system to publish sales order detail line information.
RTSODTL | Sales Order Detail | RTE | Single | H42 | D4202310B:Sales Order Detail | Included in container event RTSOOUT. |
Conceptual Approach
The RTSOOUT2 event is a new version of the RTSOOUT event. The RTSOOUT2 event is used by the JD Edwards EnterpriseOne system to publish sales order header and detail information with taxed prices information.
There are no changes to the RTSOOUT event.
RTSOOUT2 | Sales Order Version 2 | RTE | Container
H42 |
All of the objects that can initiate the RTSOOUT event can also initiate the RTSOOUT2 event, with the addition of the B4202420 - Sales Order Real-Time Event Notify Function 2 object.
The RTSOHDR2 event is a new version of the RTSOHDR event. The RTSOHDR2 is used by the JD Edwards EnterpriseOne system to publish sales order header information with taxed prices.
RTSOHDR2 | Sales Order Header Version 2 | RTE | Single | H42 | D4202410A: Sales Order Header2 | Included in container event RTSOOUT2. |
The RTSODTL2 event is a new version of the RTSODTL event. The RTSODTL2 is used by the JD Edwards EnterpriseOne system to publish sales order detail line information with taxed prices.
RTSODTL2 | Sales Order Detail Version 2 | RTE | Single | H42 | D4202410B:Sales Order Detail2 | Included in container event RTSOOUT2. |
The RTSOOUT3 event is used by the JD Edwards EnterpriseOne system to publish sales order header and detail information.
RTSOOUT3 | Sales Order Version 3 | RTE | Container
H42 |
Conceptual Approach
When a user creates, modifies, or cancels a sales order, the system triggers a notification event. This notification event, RTSOOUT3, contains two separate events: RTSOHDR3 and RTSODTL3. The RTSOHDR3 event contains all information pertinent to the sales order header. The RTSODT3L event contains all information pertinent to each sales order detail line.
These objects can initiate the RTSOOUT3 event, and the single events contained within the event:
B4202320 - Sales Order Real Time Event Notification
RTSOHDR3 is used by the JD Edwards EnterpriseOne system to publish sales order header information.
RTSOHDR3 | Sales Order Header Version 3 | RTE | Single | H42 | D4202440A: Sales Order Header | Included in container event RTSOOUT. |
Conceptual Approach
When a user creates, modifies, or cancels a sales order, the system triggers a notification event. This notification event, RTSOOUT3, contains two separate events: RTSOHDR3 and RTSODT3L. The RTSOHDR3 event contains all information pertinent to the sales order header. The RTSODTL3 event contains all information pertinent to each sales order detail line.
RTSODTL3 event is used by the JD Edwards EnterpriseOne system to publish sales order detail line information.
RTSODTL3 | Sales Order Detail Version 3 | RTE | Single | H42 | D4202440B: Sales Order Detail | Included in container event RTSOOUT. |
Conceptual Approach
When a user creates, modifies, or cancels a sales order, the system triggers a notification event. This notification event, RTSOOUT3, contains two separate events: RTSOHDR3 and RTSODTL3. The RTSOHDR3 event contains all information pertinent to the sales order header. The RTSODTL3 event contains all information pertinent to each sales order detail line.
You use batch import programs to import data into the JD Edwards EnterpriseOne database from an external software system.
This table lists and describes the available batch import programs that are associated with the Sales Order business object:
Program and Program Type | Description | Additional Information |
Recurring Orders Edited Creation Report (R40211Z) | If you use taxed prices and access the Recurring Orders Edited Creation report (R40211Z), the system edits the information from the Recurring Order Header Tax (F4001ZTX) and Recurring Order Detail Tax (F4011ZTX) tables and updates the records in the Sales Order Header Tax (F4201TX) and Sales Order Detail Tax (F4211TX) tables. | See this topic: |
EDI Inbound Purchase Order Edit/Create (R47011)
EDI Inbound Purchase Order Change (R47131) These are EDI programs. |
The system supports creating and updating sales orders through electronic data interchange (EDI) using these programs. | See this topic: |
EDI Request for Quote Edit/Create program (R47091)
This is an EDI program. |
The EDI Request for Quote Edit/Create program (R47091) access report features that are specific to each EDI Standard document supported by the JD Edwards EnterpriseOne system. The edit/update programs use the data in the EDI inbound interface tables to update applicable application tables. For example, when you receive a purchase order from a trading partner, the Inbound Edit/Update program for customer orders updates the sales application and creates a sales order, based on the data that it received. | See this topic: |
You use batch export programs to retrieve and format data from the JD Edwards EnterpriseOne database so that it can be used by an external software system.
This table lists and describes the available batch export programs that are associated with the Sales Order business object:
