System Administration Guide: Security Services
Chapter 4 Controlling Access to Devices (Tasks)
This chapter provides step-by-step instructions for protecting devices, in addition to a reference section. The following is a list of the information in this chapter.
For overview information about device protection, see Controlling Access to Devices.
Configuring Devices (Task Map)
The following task map points to tasks for managing access to devices.
Task
For Instructions
Manage device policy
Configuring Device Policy (Task Map)
Manage device allocation
Managing Device Allocation (Task Map)
Use device allocation
Allocating Devices (Task Map)
The following task map points to device configuration procedures that are related to device policy.
Task
Description
For Instructions
View the device policy for the devices on your system
Lists the devices and their device policy.
How to View Device Policy
Require privilege for device use
Uses privileges to protect a device.
How to Change the Device Policy on an Existing Device
Remove privilege requirements from a device
Removes or lessens the privileges that are required to access a device.
Example 4–3
Audit changes in device policy
Records changes in device policy in the audit trail
How to Audit Changes in Device Policy
Access /dev/arp
Gets Solaris IP MIB-II information.
How to Retrieve IP MIB-II Information From a /dev/* Device
Device policy restricts or prevents access to devices that are integral to the system. The policy is enforced in the kernel.
ProcedureHow to View Device Policy
  1. Display the device policy for all devices on your system.
    % getdevpolicy | more
    DEFAULT
            read_priv_set=none
            write_priv_set=none
    ip:*
            read_priv_set=net_rawaccess
            write_priv_set=net_rawaccess
Example 4–1 Viewing the Device Policy for a Specific Device
In this example, the device policy for three devices is displayed.
% getdevpolicy /dev/allkmem /dev/ipsecesp /dev/hme
/dev/allkmem
        read_priv_set=all
        write_priv_set=all
/dev/ipsecesp
        read_priv_set=sys_net_config
        write_priv_set=sys_net_config
/dev/hme
ProcedureHow to Change the Device Policy on an Existing Device
  1. Assume a role that includes the Device Security rights profile, or become superuser.
    The Primary Administrator role includes the Device Security rights profile. You can also assign the Device Security rights profile to a role that you create. To create the role and assign the role to a user, see Example 9–3.
  2. Add policy to a device.
    # update_drv -a -p policy device-driver
    -a
    Specifies a policy for device-driver.
    -p policy
    Is the device policy for device-driver. Device policy specifies two sets of privileges. One set is required to read the device. The other set is required to write to the device.
    device-driver
    Is the device driver.
    For more information, see the update_drv(1M) man page.
Example 4–2 Adding Policy to an Existing Device
In the following example, device policy is added to the ipnat device.
# getdevpolicy /dev/ipnat
/dev/ipnat
        read_priv_set=none
        write_priv_set=none
# update_drv -a \
-p 'read_priv_set=net_rawaccess write_priv_set=net_rawaccess' ipnat
/dev/ipnat
Example 4–3 Removing Policy From a Device
In the following example, the read set of privileges is removed from the device policy for the ipnat device.
/dev/ipnat
# update_drv -a -p write_priv_set=net_rawaccess ipnat
/dev/ipnat
        read_priv_set=none
ProcedureHow to Audit Changes in Device Policy
By default, the as audit class includes the AUE_MODDEVPLCY audit event.
  1. Assume the Primary Administrator role, or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. Preselect the audit class that includes AUE_MODDEVPLCY audit event.
    Add the as class to the flags line of the audit_control file. The file would appear similar to the following:
    # audit_control file
    dir:/var/audit
    flags:lo,as
    minfree:20
    naflags:lo
    For detailed instructions, see How to Modify the audit_control File.
ProcedureHow to Retrieve IP MIB-II Information From a /dev/* Device
Applications that retrieve Solaris IP MIB-II information should open /dev/arp, not /dev/ip.
  1. Determine the device policy on /dev/ip and /dev/arp.
    % getdevpolicy /dev/ip /dev/arp
    /dev/ip
    /dev/arp
            read_priv_set=none
            write_priv_set=none
    Note that the net_rawaccess privilege is required for reading and writing to /dev/ip. No privileges are required for /dev/arp.
  2. Open /dev/arp and push the tcp and udp modules.
    No privileges are required. This method is equivalent to opening /dev/ip and pushing the arp, tcp and udp modules. Because opening /dev/ip now requires a privilege, the /dev/arp method is preferred.
The following task map points to procedures that enable and configure device allocation. Device allocation is not enabled by default. After device allocation is enabled, see Allocating Devices (Task Map).
Task
Description
For Instructions
Make a device allocatable
Enables a device to be allocated to one user at a time.
How to Make a Device Allocatable
Authorize users to allocate a device
Assigns device allocation authorizations to users.
How to Authorize Users to Allocate a Device
View the allocatable devices on your system
Lists the devices that are allocatable, and the state of the device.
How to View Allocation Information About a Device
Forcibly allocate a device
Allocates a device to a user who has an immediate need
Forcibly Allocating a Device
Forcibly deallocate a device
Deallocates a device that is currently allocated to a user
Forcibly Deallocating a Device
Change the allocation properties of a device
Changes the requirements for allocating a device
How to Change Which Devices Can Be Allocated
Create a device-clean script
Purges data from a physical device.
Writing New Device-Clean Scripts
Disable device allocation
Removes allocation restrictions from all devices.
How to Disable the Audit Service
Audit device allocation
Records device allocation in the audit trail
How to Audit Device Allocation
Device allocation restricts or prevents access to peripheral devices. Restrictions are enforced at user allocation time. By default, users must have authorization to access allocatable devices.
ProcedureHow to Make a Device Allocatable
If you have already run the bsmconv command to enable auditing, then device allocation is already enabled on your system. For more information, see the bsmconv(1M) man page.
  1. Assume a role that includes the Audit Control rights profile, or become superuser.
    The Primary Administrator role includes the Audit Control rights profile. You can also assign the Audit Control rights profile to a role that you create. To create the role and assign the role to a user, see Example 9–3.
  2. Enable device allocation.
    # bsmconv
    This script is used to enable the Basic Security Module (BSM).
    Shall we continue with the conversion now? [y/n] y
    bsmconv: INFO: checking startup file.
    bsmconv: INFO: move aside /etc/rc3.d/S81volmgt.
    bsmconv: INFO: turning on audit module.
    bsmconv: INFO: initializing device allocation files.
    The Basic Security Module is ready.
    If there were any errors, please fix them now.
    Configure BSM by editing files located in /etc/security.
    Reboot this system now to come up with BSM enabled.
    Note –
    The Volume Management daemon (/etc/rc3.d/S81volmgt) is disabled by this command.
ProcedureHow to Authorize Users to Allocate a Device
  2. Create a rights profile that contains the appropriate authorization and commands.
    Typically, you would create a rights profile that includes the solaris.device.allocate authorization. Follow the instructions in How to Create or Change a Rights Profile. Give the rights profile appropriate properties, such as the following:
    • Rights profile name: Device Allocation
    • Granted authorizations: solaris.device.allocate
    • Commands with security attributes: mount with the sys_mount privilege, and umount with the sys_mount privilege
  3. Create a role for the rights profile.
    Follow the instructions in How to Create and Assign a Role by Using the GUI. Use the following role properties as a guide:
    • Role name: devicealloc
    • Role full name: Device Allocator
    • Role description: Allocates and mounts allocated devices
    • Rights profile: Device Allocation
      This rights profile must be at the top of the list of profiles that are included in the role.
  4. Assign the role to every user who is permitted to allocate a device.
  5. Teach the users how to use device allocation.
    For examples of allocating removable media, see How to Allocate a Device.
    Because the Volume Management daemon (vold) is not running, removable media are not automatically mounted. For examples of mounting a device that has been allocated, see How to Mount an Allocated Device.
ProcedureHow to View Allocation Information About a Device
Before You Begin
Device allocation must be enabled for this procedure to succeed. To enable device allocation, see How to Make a Device Allocatable.
  2. Display information about allocatable devices on your system.
    # list_devices device-name
    where device-name is one of the following:
    • audio[n] – Is a microphone and speaker.
    • fd[n] – Is a diskette drive.
    • sr[n] – Is a CD-ROM drive.
    • st[n] – Is a tape drive.
Troubleshooting
If the list_devices command returns an error message similar to the following, then either device allocation is not enabled, or you do not have sufficient permissions to retrieve the information.
list_devices: No device maps file entry for specified device.
For the command to succeed, enable device allocation and assume a role with the solaris.device.revoke authorization.
ProcedureForcibly Allocating a Device
Forcible allocation is used when someone has forgotten to deallocate a device. Forcible allocation can also be used when a user has an immediate need for a device.
Before You Begin
The user or role must have the solaris.device.revoke authorization.
  1. Determine if you have the appropriate authorizations in your role.
    $ auths
    solaris.device.allocate solaris.device.revoke
  2. Forcibly allocate the device to the user who needs the device.
    In this example, the tape drive is forcibly allocated to the user jdoe.
    $ allocate -U jdoe
ProcedureForcibly Deallocating a Device
Devices that a user has allocated are not automatically deallocated when the process terminates or when the user logs out. Forcible deallocation is used when a user has forgotten to deallocate a device.
Before You Begin
    $ auths
  2. Forcibly deallocate the device.
    In this example, the printer is forcibly deallocated. The printer is now available for allocation by another user.
    $ deallocate -f /dev/lp/printer-1
ProcedureHow to Change Which Devices Can Be Allocated
  2. Specify if authorization is required, or specify the solaris.device.allocate authorization.
    Change the fifth field in the device entry in the device_allocate file.
    audio;audio;reserved;reserved;solaris.device.allocate;/etc/security/lib/audio_clean
    fd0;fd;reserved;reserved;solaris.device.allocate;/etc/security/lib/fd_clean
    sr0;sr;reserved;reserved;solaris.device.allocate;/etc/security/lib/sr_clean
    where solaris.device.allocate indicates that a user must have the solaris.device.allocate authorization to use the device.
Example 4–4 Permitting Any User to Allocate a Device
In the following example, any user on the system can allocate any device. The fifth field in every device entry in the device_allocate file has been changed to an at sign (@).
$ whoami
devicesec
$ vi /etc/security/device_allocate
audio;audio;reserved;reserved;@;/etc/security/lib/audio_clean
fd0;fd;reserved;reserved;@;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;@;/etc/security/lib/sr_clean
Example 4–5 Preventing Some Peripheral Devices From Being Used
In the following example, the audio device cannot be used. The fifth field in the audio device entry in the device_allocate file has been changed to an asterisk (*).
$ whoami
devicesec
audio;audio;reserved;reserved;*;/etc/security/lib/audio_clean
fd0;fd;reserved;reserved;solaris device.allocate;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;solaris device.allocate;/etc/security/lib/sr_clean
Example 4–6 Preventing All Peripheral Devices From Being Used
In the following example, no peripheral device can be used. The fifth field in every device entry in the device_allocate file has been changed to an asterisk (*).
$ whoami
devicesec
fd0;fd;reserved;reserved;*;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;*;/etc/security/lib/sr_clean
ProcedureHow to Audit Device Allocation
By default, the device allocation commands are in the other audit class.
  2. Preselect the ot class for auditing.
    Add the ot class to the flags line of the audit_control file. The file would appear similar to the following:
    dir:/var/audit
    flags:lo,ot
    minfree:20
    naflags:lo
The following task map points to procedures that show users how to allocate devices.
Task
Description
For Instructions
Allocate a device
Enables a user to use a device, while preventing any other user from using the device.
Mount an allocated device
Enables a user to view a device that requires mounting, such as a CD-ROM or a diskette.
Deallocate a device
Makes an allocatable device available for use by another user.
How to Deallocate a Device
Allocating Devices
Device allocation reserves the use of a device to one user at a time. Devices that require a mount point must be mounted.
ProcedureHow to Allocate a Device
Before You Begin
Device allocation must be enabled, as described in How to Make a Device Allocatable. If authorization is required, the user must have the authorization.
  1. Allocate the device.
    Specify the device by device name.
    % allocate device-name
  2. Verify that the device is allocated.
    Run the identical command.
    allocate. Device already allocated.
Example 4–7 Allocating a Microphone
In this example, the user jdoe allocates a microphone, audio.
% whoami
jdoe
% allocate audio
Example 4–8 Allocating a Printer
In this example, a user allocates a printer. No one else can print to printer-1 until the user deallocates it, or until the printer is forcibly allocated to another user.
% allocate /dev/lp/printer-1
For an example of forcible deallocation, see Forcibly Deallocating a Device.
Example 4–9 Allocating a Tape Drive
In this example, the user jdoe allocates a tape drive, st0.
% whoami
jdoe
% allocate st0
Troubleshooting
If the allocate command cannot allocate the device, an error message is displayed in the console window. For a list of allocation error messages, see the allocate(1) man page.
ProcedureHow to Mount an Allocated Device
Before You Begin
The user or role has allocated the device. To mount a device, the user or role must have the privileges that are required for mounting the device. To give the required privileges, see How to Authorize Users to Allocate a Device.
  1. Assume a role that can allocate and mount a device.
    % su - role-name
    Password: <Type role-name password>
  2. Create and protect a mount point in the role's home directory.
    You only need to do this step the first time you need a mount point.
    $ mkdir mount-point ; chmod 700 mount-point
  3. List the allocatable devices.
    $ list_devices -l
    List of allocatable devices
  4. Allocate the device.
    $ allocate device-name
  5. Mount the device.
    $ mount -o ro -F filesystem-type device-path mount-point
    where
    -o ro
    Indicates that the device is to be mounted read-only. Use-o rw to indicate that you should be able to write to the device.
    -F filesystem-type
    Indicates the file system format of the device. Typically, a CD-ROM is formatted with an HSFS file system. A diskette is typically formatted with a PCFS file system.
    device-path
    Indicates the path to the device. The output of the list_devices -l command includes the device-path.
    mount-point
    Indicates the mount point that you created in Step 2.
Example 4–10 Allocating a Diskette Drive
In this example, a user assumes a role that can allocate and mount a diskette drive, fd0. The diskette is formatted with a PCFS file system.
% roles
devicealloc
% su - devicealloc
Password: <Type devicealloc password>
$ mkdir /home/devicealloc/mymnt
$ chmod 700 /home/devicealloc/mymnt
$ list_devices -l
device: fd0 type: fd files: /dev/diskette /dev/rdiskette /dev/fd0a
$ allocate fd0
$ mount -o ro -F pcfs /dev/diskette /home/devicealloc/mymnt
$ ls /home/devicealloc/mymnt
List of the contents of diskette
Example 4–11 Allocating a CD-ROM Drive
In this example, a user assumes a role that can allocate and mount a CD-ROM drive, sr0. The drive is formatted as an HSFS file system.
% roles
devicealloc
% su - devicealloc
$ list_devices -l
device: sr0 type: sr files: /dev/sr0 /dev/rsr0 /dev/dsk/c0t2d0s0 ...
$ allocate sr0
$ mount -o ro -F hsfs /dev/sr0 /home/devicealloc/mymnt
$ cd /home/devicealloc/mymnt ; ls
List of the contents of CD-ROM
Troubleshooting
If the mount command cannot mount the device, an error message is displayed: mount: insufficient privileges. Check the following:
Contact your administrator if you still cannot mount the allocated device.
ProcedureHow to Deallocate a Device
Deallocation enables other users to allocate and use the device when you are finished.
Before You Begin
You must have allocated the device.
  1. If the device is mounted, unmount the device.
    $ cd $HOME
    $ umount mount-point
  2. Deallocate the device.
    $ deallocate device-name
Example 4–12 Deallocating a Microphone
In this example, the user jdoe deallocates the microphone, audio.
% whoami
jdoe
% deallocate audio
Example 4–13 Deallocating a CD-ROM Drive
In this example, the Device Allocator role deallocates a CD-ROM drive. After the message is printed, the CD-ROM is ejected.
$ whoami
devicealloc
$ umount /home/devicealloc/mymnt
$ deallocate sr0
/dev/sr0:      326o
/dev/rsr0:     326o
sr_clean: Media in sr0 is ready.  Please, label and store safely.
Device Protection (Reference)
Devices in the Solaris OS are protected by device policy. Peripheral devices can be protected by device allocation. Device policy is enforced by the kernel. Device allocation is optionally enabled, and is enforced at the user level.
Device Policy Commands
Device management commands administer the device policy on local files. Device policy can include privilege requirements. Only superuser or a role of equivalent capabilities can manage devices.
The following table lists the device management commands.
Table 4–1 Device Management Commands
Command
Purpose
Man Page
devfsadm
Administers devices and device drivers on a running system. Also loads device policy.
The devfsadm command enables the cleanup of dangling /dev links to disk, tape, port, audio, and pseudo devices. Devices for a named driver can also be reconfigured.
devfsadm(1M)
getdevpolicy
Displays the policy associated with one or more devices. This command can be run by any user.
getdevpolicy(1M)
add_drv
Adds a new device driver to a running system. Contains options to add device policy to the new device. Typically, this command is called in a script when a device driver is being installed.
add_drv(1M)
update_drv
Updates the attributes of an existing device driver. Contains options to update the device policy for the device. Typically, this command is called in a script when a device driver is being installed.
update_drv(1M)
rem_drv
Removes a device or device driver.
rem_drv(1M)
Device Allocation
Device allocation can protect your site from loss of data, computer viruses, and other security breaches. Unlike device policy, device allocation is optional. Devices are not allocatable until the bsmconv script is run. Device allocation uses authorizations to limit access to allocatable devices.
Components of Device Allocation
The components of the device allocation mechanism are as follows:
These commands and scripts use the following local files to implement device allocation:
Note –
The /etc/security/dev directory might not be supported in future releases of the Solaris OS.
Device Allocation Commands
With uppercase options, the allocate, deallocate, and list_devices commands are administrative commands. Otherwise, these commands are user commands. The following table lists the device allocation commands.
Table 4–2 Device Allocation Commands
Command
Purpose
Man Page
bsmconv
Creates databases to handle device allocation. Also enables the auditing service. You must be superuser or in the Primary Administrator role.
bsmconv(1M)
dminfo
Searches for an allocatable device by device type, by device name, and by full path name.
dminfo(1M)
list_devices
Lists the status of allocatable devices.
Lists all the device-special files that are associated with any device that is listed in the device_maps file.
list_devices(1)
list_devices -U
Lists the devices that are allocatable or allocated to the specified user ID. This option allows you to check which devices are allocatable or allocated to another user. You must have the solaris.device.revoke authorization.
allocate
Reserves an allocatable device for use by one user.
By default, a user must have the solaris.device.allocate authorization to allocate a device. You can modify the device_allocate file to not require user authorization. Then, any user on the system can request the device to be allocated for use.
allocate(1)
deallocate
Removes the allocation reservation from a device.
deallocate(1)
Authorizations for the Allocation Commands
By default, users must have the solaris.device.allocate authorization to reserve an allocatable device. To create a rights profile to include the solaris.device.allocate authorization, see How to Authorize Users to Allocate a Device.
Administrators must have the solaris.device.revoke authorization to change the allocation state of any device. For example, the -U option to the allocate and list_devices commands, and the -F option to the deallocate command require the solaris.device.revoke authorization.
For more information, see Commands That Require Authorizations.
Allocate Error State
A device is put in an allocate error state when the deallocate command fails to deallocate, or when the allocate command fails to allocate. When an allocatable device is in an allocate error state, then the device must be forcibly deallocated. Only superuser or a role with the Device Management rights profile or the Device Security rights profile can handle an allocate error state.
The deallocate command with the -F option forces deallocation. Or, you can use allocate -U to assign the device to a user. Once the device is allocated, you can investigate any error messages that appear. After any problems with the device are corrected, you can forcibly deallocate it.
device_maps File
Device maps are created when you set up device allocation. A default /etc/security/device_maps file is created by the bsmconv command when the auditing service is enabled. This initial device_maps file can be customized for your site. The device_maps file includes the device names, device types, and device-special files that are associated with each allocatable device.
The device_maps file defines the device-special file mappings for each device, which in many cases is not intuitive. This file allows programs to discover which device-special files map to which devices. You can use the dminfo command, for example, to retrieve the device name, the device type, and the device-special files to specify when you set up an allocatable device. The dminfo command uses the device_maps file to report this information.
Each device is represented by a one-line entry of the form:
device-name:device-type:device-list
Example 4–14 Sample device_maps Entry
The following is an example of an entry in a device_maps file for a diskette drive, fd0:
fd0:\
        fd:\
        /dev/diskette /dev/rdiskette /dev/fd0a /dev/rfd0a \
/dev/fd0b /dev/rfd0b /dev/fd0c /dev/fd0 /dev/rfd0c /dev/rfd0:\
Lines in the device_maps file can end with a backslash (\) to continue an entry on the next line. Comments can also be included. A pound sign (#) comments all subsequent text until the next newline that is not immediately preceded by a backslash. Leading and trailing blanks are allowed in any field. The fields are defined as follows:
device-name
Specifies the name of the device. For a list of current device names, see How to View Allocation Information About a Device.
device-type
Specifies the generic device type. The generic name is the name for the class of devices, such as st, fd, or audio. The device-type field logically groups related devices.
device-list
Lists the device-special files that are associated with the physical device. The device-list must contain all of the special files that allow access to a particular device. If the list is incomplete, a malevolent user can still obtain or modify private information. Valid entries for the device-list field reflect the device files that are located in the /dev directory.
device_allocate File
An initial /etc/security/device_allocate file is created by the bsmconv command when the auditing service is enabled. This initial device_allocate file can be used as a starting point. You can modify the device_allocate file to change devices from allocatable to nonallocatable, or to add new devices. A sample device_allocate file follows.
st0;st;;;;/etc/security/lib/st_clean
fd0;fd;;;;/etc/security/lib/fd_clean
sr0;sr;;;;/etc/security/lib/sr_clean
audio;audio;;;*;/etc/security/lib/audio_clean
An entry in the device_allocate file does not mean that the device is allocatable, unless the entry specifically states that the device is allocatable. In the sample device_allocate file, note the asterisk (*) in the fifth field of the audio device entry. An asterisk in the fifth field indicates to the system that the device is not allocatable. Therefore, the device cannot be used. Other values or no value in this field indicates that the device can be used.
In the device_allocate file, each device is represented by a one-line entry of the form:
device-name;device-type;reserved;reserved;auths;device-exec
Lines in the device_allocate file can end with a backslash (\) to continue an entry on the next line. Comments can also be included. A pound sign (#) comments all subsequent text until the next newline that is not immediately preceded by a backslash. Leading and trailing blanks are allowed in any field. The fields are defined as follows:
device-name
device-type
Specifies the generic device type. The generic name is the name for the class of devices, such as st, fd, and sr. The device-type field logically groups related devices. When you make a device allocatable, retrieve the device name from the device-type field in the device_maps file.
reserved
Sun reserves the two fields that are marked reserved for future use.
auths
Specifies whether the device is allocatable. An asterisk (*) in this field indicates that the device is not allocatable. An authorization string, or an empty field, indicates that the device is allocatable. For example, the string solaris.device.allocate in the auths field indicates that the solaris.device.allocate authorization is required to allocate the device. An at sign (@) in this file indicates that the device is allocatable by any user.
device-exec
Supplies the path name of a script to be invoked for special handling, such as cleanup and object-reuse protection during the allocation process. The device-exec script is run any time that the device is acted on by the deallocate command.
For example, the following entry for the sr0 device indicates that the CD-ROM drive is allocatable by a user with the solaris.device.allocate authorization:
You can decide to accept the default devices and their defined characteristics. After you install a new device, you can modify the entries. Any device that needs to be allocated before use must be defined in the device_allocate and device_maps files for that device's system. Currently, cartridge tape drives, diskette drives, CD-ROM drives, and audio chips are considered allocatable. These device types have device-clean scripts.
Note –
Xylogics tape drives or Archive tape drives also use the st_clean script that is supplied for SCSI devices. You need to create your own device-clean scripts for other devices, such as modems, terminals, graphics tablets, and other allocatable devices. The script must fulfill object-reuse requirements for that type of device.
Device allocation satisfies part of what is called the object reuse requirement. The device-clean scripts address the security requirement that all usable data be purged from a physical device before reuse. The data is cleared before the device is allocatable by another user. By default, cartridge tape drives, diskette drives, CD-ROM drives, and audio devices require device-clean scripts. The Solaris OS provides the scripts. This section describes what device-clean scripts do.
Device-Clean Script for Tapes
The st_clean device-clean script supports three tape devices:
The st_clean script uses the rewoffl option to the mt command to clean up the device. For more information, see the mt(1) man page. If the script runs during system boot, the script queries the device to determine if the device is online. If the device is online, the script determines if the device has media in it. The ¼-inch tape devices that have media in them are placed in the allocate error state. The allocate error state forces the administrator to manually clean up the device.
During normal system operation, when the deallocate command is executed in interactive mode, the user is prompted to remove the media. Deallocation is delayed until the media is removed from the device.
Device-Clean Scripts for Diskettes and CD-ROM Drives
The following device-clean scripts are provided for diskettes and CD-ROM drives:
The scripts use the eject command to remove the media from the drive. If the eject command fails, the device is placed in the allocate error state. For more information, see the eject(1) man page.
Device-Clean Script for Audio
Audio devices are cleaned up with an audio_clean script. The script performs an AUDIO_GETINFO ioctl system call to read the device. The script then performs an AUDIO_SETINFO ioctl system call to reset the device configuration to the default.
If you add more allocatable devices to the system, you might need to create your own device-clean scripts. The deallocate command passes a parameter to the device-clean scripts. The parameter, which is shown here, is a string that contains the device name. For more information, see the device_allocate(4) man page.
clean-script -[I|i|f|S] device-name
Device-clean scripts must return “0” for success and greater than “0” for failure. The options -I, -f, and -S determine the running mode of the script:
-I
Is needed during system boot only. All output must go to the system console. Failure or inability to forcibly eject the media must put the device in the allocate error state.
-i
Similar to the -I option, except that output is suppressed.
-f
Is for forced cleanup. The option is interactive and assumes that the user is available to respond to prompts. A script with this option must attempt to complete the cleanup if one part of the cleanup fails.
-S
Is for standard cleanup. The option is interactive and assumes that the user is available to respond to prompts.
