Java Desktop System Email and Calendar User Guide
To Create a New Folder
Perform the following steps:
  1. Choose File -> Folder -> New Folder. Alternatively, right-click in the folder pane, then choose New Folder from the popup menu. A Create New Folder dialog is displayed.
  2. Enter the details of the folder that you want to create in the Create New Folder dialog. The following table describes the elements on the Create New Folder dialog:
    Element
    Description
    Folder name
    Type a name for the folder in the text box.
    Folder type
    Select the type of folder from the drop-down list.
    Specify where to create the folder
    Use the tree to select the location where you want to create the new folder.
  3. Click OK.
