Java Desktop System Email and Calendar User Guide
To Move a Folder
Perform the following steps:
  1. Open the folder that you want to move, then choose File -> Folder -> Move. Alternatively, right-click on the folder that you want to move in the folder pane, then choose Move from the popup menu. A Move Folder dialog is displayed.
  2. Use the tree in the Move Folder dialog to select the location where you want to move the folder.
    To create a new folder, click on the New button. A Create New Folder dialog is displayed. For more information, see To Create a New Folder.
  3. Click OK.
