Java Desktop System Email and Calendar User Guide
To Rename a Folder
Perform the following steps:
  1. Open the folder that you want to rename, then choose File -> Folder -> Rename. Alternatively, right-click on the folder that you want to rename in the folder pane, then choose Rename from the popup menu. A Rename Folder dialog is displayed.
  2. Type a new name for the folder in the dialog, then click OK.
