Java Desktop System Email and Calendar User Guide
To Delete a Folder
Open the folder that you want to delete, then choose File -> Folder -> Delete. Alternatively, right-click on the folder that you want to delete in the folder pane, then choose Delete from the popup menu. A confirmation dialog is displayed. Click Delete to delete the folder.
