Java Desktop System Email and Calendar User Guide
Introduction to Email and Calendar
Email and Calendar is an advanced personal information management system that integrates with email servers and calendar servers. Email and Calendar contains the following component applications:
Calendar
You can use Calendar to schedule appointments, meetings, and tasks.
Contacts
You can use Contacts to create an address book of your contacts.
Email
You can use Email and Calendar to compose, send, receive, and manage email messages.
Summary
Summary gives you an overview of your day. Summary displays an overview of your email messages, and your appointments, meetings, and tasks.
Tasks
You can use Tasks to manage the work tasks that you perform.
Connectors
You can use connectors to connect to other email and calendar servers.
Email and Calendar is based on the Evolution 1.4 application, developed by Novell, Inc.
To start Email and Calendar, click Launch, then choose Email and Calendar.
Figure 1–1 shows an Email and Calendar window that displays Summary.
Figure 1–1 Email and Calendar Summary Window
Email and Calendar Summary window. Callouts: Menubar, Toolbar, Shortcuts bar, Folder pane.
The Email and Calendar window contains the following items:
Menubar
Contains menus that you use to perform tasks in Email and Calendar. Different menu items are available, depending which application you use.
Toolbar
Contains buttons that you use to perform tasks in Email and Calendar. Different toolbar buttons are available, depending which application you use.
Shortcuts bar
Displays your shortcuts. Shortcuts are icons that provide quick access to your folders. The shortcuts bar is located at the extreme left side of the Email and Calendar window.
To display the shortcuts bar, choose View -> Shortcut Bar so that the Shortcut Bar menu item is selected.
To hide the shortcuts bar, choose View -> Shortcut Bar again, so that the Shortcut Bar menu item is deselected.
Folder pane
Displays a list of your folders. The folder pane is located at the left side of the Email and Calendar window.
To display the folder pane, choose View -> Folder Bar so that the Folder Bar menu item is selected. Alternatively, click on the name of the current folder at the top of the message list.
To hide the folder pane, choose View -> Folder Bar again, so that the Folder Bar menu item is deselected. Alternatively, click on the Close button at the top of the folder pane.
Most Email and Calendar components also contain a searchbar. You can use the searchbar to perform simple searches. For example, you can search an email folder such as Inbox for a message that contains a particular text string.
