Go to main content
Sun Rack II Product Notes
Exit Print View
Updated: July 2018
Access a Metering Unit on the Network (Original PDU)
The Original PDU supports both, 10/100 Full Duplex and 10/100 Half Duplex but not auto-negotiation as defined in IEEE802.3u. The Original PDU uses "auto detection" which means it configures itself to match the switch port. If a specific mode of operation is needed the switch port need to be configured to the specific mode of operation.
