Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Oracle Solaris Operating System
search filter icon
search icon
Document Information
Using This Documentation
1.  Getting Started
Supported Oracle Solaris Operating Systems
Oracle Solaris Documentation Collection
Installation Considerations
Oracle Solaris 10 and 11 Installation Programs
Installation Task Overview
2.  Installing Oracle Solaris
Installing Oracle Solaris 10 or 11 OS Using Local or Remote Media
Before You Begin
Install Oracle Solaris 10 or 11 OS Using Local or Remote Media
Installing Oracle Solaris 10 or 11 OS Using a PXE Network Environment
Before You Begin
Install Oracle Solaris 10 or 11 OS Using Network PXE Boot
Post Installation Tasks
3.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
Before You Begin
View or Edit BIOS Settings for New Installations
C.  Supported Operating Systems
Index
Firmware and software, such as hardware drivers and tools for the server, are updated periodically. These are made available as a software release. The software release is a set of downloads (patches) that includes all available firmware, hardware drivers, and utilities for the server. All these have been tested together. The ReadMe document that is included with the download explains what has changed and what has not changed from the prior software release.
You should update your server firmware and software as soon as possible after the software release becomes available. Software releases often include bug fixes, and updating ensures that your server software is compatible with the latest server firmware and other component firmware and software.
The ReadMe file in the download package contains information about the updated files in the download package, as well as bugs that are fixed with the current release. The product notes also provide information about which server software versions are supported.
