Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Oracle Solaris Operating System |
Supported Oracle Solaris Operating Systems
Oracle Solaris Documentation Collection
Oracle Solaris 10 and 11 Installation Programs
Installing Oracle Solaris 10 or 11 OS Using Local or Remote Media
Install Oracle Solaris 10 or 11 OS Using Local or Remote Media
Installing Oracle Solaris 10 or 11 OS Using a PXE Network Environment
Install Oracle Solaris 10 or 11 OS Using Network PXE Boot
3. Getting Server Firmware and Software
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Installing Hardware Drivers and OS Tools
A. Supported Installation Methods
B. BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
View or Edit BIOS Settings for New Installations
Use one of the following options to obtain the latest set of firmware and software for your server:
Oracle Hardware Installation Assistant – Oracle Hardware Installation Assistant is a factory-installed feature for the Sun Server X2-4 that allows you to easily update server firmware and software.
For more information about Oracle Hardware Installation Assistant, refer to the Oracle Hardware Installation Assistant 2.5 User's Guide for x86 Servers at http://www.oracle.com/pls/topic/lookup?ctx=hia.
My Oracle Support – All system firmware and software are available from the My Oracle Support web site.
For more information about what is available on the My Oracle Support web site, see http://support.oracle.com.
For instructions on how to download software releases from My Oracle Support, see Download Firmware and Software Using My Oracle Support.
Physical Media Request (PMR) – You can request a DVD that contains any of the downloads (patches) that are available from My Oracle Support.
For information see, Requesting Physical Media.
