Skip Navigation Links | |
Exit Print View | |
Oracle Integrated Lights Out Manager (ILOM) 3.1 Supplement for Sun Server X2-4 |
1. Determining Your Server Management Strategy
Common System Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Server Management Downloads and Documentation
2. Oracle ILOM 3.1 Documentation
Oracle ILOM 3.1 Documentation Collection
3. Oracle ILOM Features for the Sun Server X2-4
Sun Server X2-4 Supported Firmware
Oracle ILOM 3.1 Features Supported on All Servers
Oracle ILOM 3.1 Features Supported on Oracle x86 Servers
Local Host Interconnect Management Connection
Diagnostics Using Pc-Check and NMI
Switch Serial Port Output to Host Management Console
Administer Open Problems and Clear Server Faults
Oracle ILOM 3.1 Features Not Supported on Sun Server X2-4
4. Sensors and Indicators Reference Information
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
SNMP and PET Message Reference Information
5. Getting Server Firmware and Software
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Use one of the following options to obtain the latest set of firmware and software for your server:
Oracle Hardware Installation Assistant – Oracle Hardware Installation Assistant is a factory-installed feature for the Sun Server X2-4 that allows you to easily update server firmware and software.
For more information about Oracle Hardware Installation Assistant, refer to the Oracle Hardware Installation Assistant 2.5 User's Guide for x86 Servers at http://www.oracle.com/pls/topic/lookup?ctx=hia.
My Oracle Support – All system firmware and software are available from the My Oracle Support web site.
For more information about what is available on the My Oracle Support web site, see http://support.oracle.com.
For instructions on how to download software releases from My Oracle Support, see Download Firmware and Software Using My Oracle Support.
Physical Media Request (PMR) – You can request a DVD that contains any of the downloads (patches) that are available from My Oracle Support.
For information see, Requesting Physical Media.
