Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common System Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Server Management Downloads and Documentation
2.  Oracle ILOM 3.1 Documentation
Oracle ILOM 3.1 Documentation Collection
3.  Oracle ILOM Features for the SunĀ Server X2-4
Sun Server X2-4 Supported Firmware
Oracle ILOM 3.1 Features Supported on All Servers
Oracle ILOM 3.1 Features Supported on Oracle x86 Servers
Sideband Management
Power Control Policies
Host Power Throttling and Recovery
Low Line AC Override
Local Host Interconnect Management Connection
Diagnostics Using Pc-Check and NMI
Control Next Boot Device
FRU TLI Auto-Update
Switch Serial Port Output to Host Management Console
Administer Open Problems and Clear Server Faults
Determining Faults
Clearing Faults
Oracle ILOM 3.1 Features Not Supported on Sun Server X2-4
4.  Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
The following table identifies the supported Oracle ILOM and BIOS firmware versions supported on the Sun Server X2-4.
Software Release
Oracle ILOM SP Firmware
BIOS Firmware
1.3 r73820
1.2 r70287
1.1 r65661
1.0 r63740
For information about how to update the firmware on your server, refer to the Oracle ILOMĀ 3.1 Documentation Library at:
