Skip Navigation Links | |
Exit Print View | |
Oracle Java CAPS HTTP Binding Component User's Guide Java CAPS Documentation |
Using the HTTP Binding Component
About the HTTP Binding Component
HTTP/SOAP Binding Architecture
HTTP Binding Component Features
HTTP Binding Component Example Scenario
SOAP 1.1 WSDL Extensibility Elements
SOAP 1.1 header and headerfault Elements
SOAP 1.2 WSDL Extensibility Elements
SOAP 1.2 header and headerfault Elements
HTTP WSDL Extensibility Elements
Configuring the HTTP Binding Component for HTTP Get Interactions
Using the HTTP Binding Component with the HTTP POST Method
HTTP POST Treatment of http:urlEncoded and http:urlReplacement
HTTP Binding Component Runtime Properties
HTTP Binding Component Client Endpoint Properties
Accessing the HTTP Binding Component Client Endpoint Properties
HTTP BC Client Endpoint Configuration Properties
Using Normalized Message Properties to Propagate Binding Context Information
Using Normalized Message Properties in a BPEL Process
Using Predefined Normalized Message Properties in a BPEL Process
To use predefined normalized message properties in a BPEL process
Adding Additional Normalized Message Properties to a BPEL Process
To add a Normalized Message Property Shortcut to a BPEL process
To edit an NM Property Shortcut
To delete an NM Property Shortcut
To add a Normalized Message Property to a BPEL process
BPEL Code Generation Using NM Properties
SOAP HTTP Binding Component Specific Normalized Message Properties
Quality of Service (QOS) Features
Configuring the Quality of Service Properties
Message Throttling: Configuring and Using
Configuring the HTTP Binding Component Endpoint for Throttling
Redelivery: Configuring and Using
Using the Tango Web Service Features with the HTTP Binding Component
Configuring Reliable Message Delivery
Installing the Synchronous BPEL Process sample
Configuring Web Services for a Project from the CASA Editor
Configuring the Tango Web Services Attributes exposed by the HTTP Binding Component
Accessing the Tango (WSIT) Web Service Attribute Configuration
Accessing the WS-Policy Attachment Editor for a Specific Endpoint
Server Configuration--Web Service Attributes
Client Configuration -- Web Service Attributes
HTTP Binding Component Security
Using Basic Authentication with the HTTP Binding Component
Basic Authentication Supported Features
Authentication Mechanisms for Consumer Endpoints
WssTokenCompare Username/Password Authentication
Using the Access Manager for Authentication and Authorization
Installing the Access Manager Add-on
Installing Access Manager with Java Application Platform SDK
Configure the HTTP Binding Component to use Access Manager
Using the OpenSSO Web Services Security (WSS) Agent for Authentication and Authorization
Install OpenSSO Enterprise Server
Configure the HTTP Binding Component to use OpenSSO Web Service Security
Using the GlassFish Realm Security to Authenticate the HTTP Client Credentials
Configuring Security Mechanisms
Username Authentication with Symmetric Key
Message Authentication over SSL
SAML Sender Vouches with Certificates
STS Issued Token with Service Certificate
Using Application Variables to Define Name/Value Pairs
Using Application Variables for password protection
Creating a password Application Variable
Using Application Configuration to Configure Connectivity Parameters
To apply a named Config Extension to the Application Configuration
Clustering Support for the HTTP Binding Component
Configuring the HTTP Binding Component for Clustering
Understanding the ${HttpDefaultPort} Token
Validating HTTP Extensibility Elements from the WSDL Editor
Adding a SOAP Template to a WSDL Document
Adding an HTTP Template to a WSDL Document
Web Service Client Calling an Operation Using HTTP Basic Authentication
Web Service Implementing an Operation Protected by HTTP Basic Authentication
Web Service Client Calling an Operation Using SSL Authentication
Web Service Implements an Operation Protected by SSL Authentication
The HTTP Binding Component records and maintains statistics for 19 different component activities including exchanges, errors, requests, replies, and so forth. These statistics are recorded during the lifecycle of an endpoint, and accessed from the HTTP Binding Component Properties Editor. For example: statistics for the number of times that a send request has been completed are available in the application's HTTP Binding Component properties as the current value for Statistics -> Sent Requests.
