Skip Navigation Links
Exit Print View
Oracle Java CAPS Master Index Configuration Guide     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
Master Index Configuration Overview
About the Master Index Configuration Files
object.xml
query.xml
mefa.xml
master.xml
update.xml
filter.xml
validation.xml
security.xml
midm.xml
Modifying the Master Index XML Files Directly
Using the Master Index Master Index Configuration Editor
object.xml
query.xml
master.xml
mefa.xml
update.xml
validation.xml
midm.xml
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index Configuration Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure
Adding an Object to the Master Index Object Structure
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure
To Add a Field (Configuration Editor)
To Add a Field (XML Editor)
Deleting a Field from the Master Index Object Structure
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions
Master Index Field Name Restrictions
Master Index Configuration Editor Field Properties
Master Index Field Property Elements
Creating a Master Index Basic Query
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements
Creating Master Index Blocking Queries
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements
Modifying Master Index Queries
Modifying a Master Index Query
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
Deleting a Master Index Query
To Delete a Query (Configuration Editor)
To Delete a Query
Configuring Master Index Processing Options
Specifying Master Index Custom Logic Classes
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Master Index Data Manager
Specifying the Master Index Update Mode
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options
To Set Blocking Query Options
Defining Master Index Transactional Support
To Configure the Master Index for Local Transactions
To Configure the Master Index to Distributed Transactions Across Applications
To Configure the Master Index for Distributed Transactions Within the Master Index Application Only
Configuring Matching Parameters
Specifying the Master Index Decision Maker Class
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs
Specifying the Master Index EUID Generator Class
To Specify the EUID Generator Class
Specifying the Master Index EUID Length
To Specify the EUID Length
Specifying a Master Index Checksum Length
To Specify a Checksum Length
Specifying the Master Index Chunk Size
To Specify the Chunk Size
Adding and Deleting Master Index EUID Generator Parameters
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules
Defining a Master Index Field to be Normalized
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties
Master Index Variants Properties
Modifying a Master Index Normalization Definition
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules
Defining Master Index Fields to be Standardized
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements
Modifying a Master Index Standardization Definition
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index
Defining Master Index Fields for Phonetic Encoding
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements
Modifying a Master Index Phonetic Encoding Definition
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types
Modifying a Master Index Phonetic Encoder
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder
To Delete a Phonetic Encoder (Configuration Editor)
To Delete a Phonetic Encoder (XML Editor)
Defining the Master Index Match String
Creating the Master Index Match String
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed
To Specify the Block Picker
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator
Specifying the Master Index Survivor Helper
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements
Defining the Master Index Single Best Record Structure
To Specify a Candidate Field
Deleting Candidate Fields
Defining a Master Index Survivor Strategy for a Field or Object
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements
Filtering Default Values From Master Index Processes
To Filter Default Values From the SBR, Blocking Query, or Match Process
Filter Definition Elements
Configuring Master Index Update Policies
Defining Master Index Update Policies
To Define Update Policies
Setting the Master Index Update Policy Flag
To Set the Update Policy Flag
Defining Custom Field Validations for the Master Index
To Implement a Validation Rule
Configuring the Match Engine
Specifying a Match Engine for the Master Index
To Configure the Match Engine
Configuring the Comparison Functions for a Master Index Application
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index
Importing Custom Comparison Functions
To Import a Comparison Function
Deleting a Custom Comparison Function
To Delete a Custom Comparison Function
Configuring the Standardization Engine
Specifying a Standardization Engine for the Master Index
To Specify the Standardization Engine
Modifying Master Index Standardization Files
To Modify Standardization Data Configuration Files
Importing Standardization Data Types and Variants
To Import a Data Type or Variant
Deleting a Standardization Variant or Data Type
To Delete a Variant or Data Type
Configuring the Master Index MIDM Appearance
Adding Objects to the MIDM
To Add an Object to the MIDM
Modifying MIDM Objects
To Modify an MIDM Object
Deleting Objects From the MIDM
To Delete an Object
Adding Fields to the MIDM
To Define New Fields
MIDM Field Configuration Elements
Removing Fields From the MIDM
To Remove a Field From the MIDM
Modifying MIDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an MIDM Field
To Specify a Drop-Down List
Specifying an MIDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an MIDM Field's Data Type
To Modify the Data Type
Defining Key Fields for an Object
To Modify the Key Status
Masking Field Values on the MIDM
To Mask Field Values on the MIDM
Defining MIDM Object Relationships
To Define Relationships
Defining MIDM Local ID Labels
To Define Local ID Labels
Configuring the Master Index MIDM Pages
Specifying the Initial View for the MIDM
To Specify the Initial View
Configuring the MIDM Duplicate Records Page
Configuring Duplicate Records Display Options
Configuring Duplicate Records Search Pages
Configuring the Duplicate Records Results List
Duplicate Records Page Configuration Elements
Duplicate Records Search Page Elements
Duplicate Records Search Results List Elements
Configuring the MIDM Record Details Page
To Configure Record Details Display Options
Creating Search Pages on the Record Details Page
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
Record Details Search Page Definition Elements
Record Details Search Field Definition Elements
Record Details Search Option Elements
Modifying a Search Page on the Record Details Page
Modifying a Search Page Definition
Modifying Search Fields
Modifying Record Details Search Page Options
Configuring the MIDM Assumed Matches Page
To Configure the Assumed Matches Page
Configuring the MIDM Transactions Page
To Configure the Transactions Page
Configuring the MIDM Reports Page
Configuring the Reports Page Definition
Configuring Production Reports
Configuring Activity Reports
Production Reports Definition Elements
Activity Reports Definition Elements
Activity Reports Page Definition Elements
Activity Reports Search Elements
Activity Reports Results Elements
Configuring the MIDM Source Record Page
Configuring the Source Record Page Definition
Configuring the Tabbed Pages on the Source Record Page
Configuring the MIDM Audit Log Page
To Configure the Audit Log Page
Configuring Master Index MIDM Implementation Information
Specifying the Master Controller JNDI Class
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services
To Specify the Validation Service
Setting Master Index Debug Options
To Set Debug Options
Specifying a Master Index Field Masking Class
To Specify a Field Masking Class
Once you create the object structure of the master index application, you can customize several properties for each field, such as whether the field is required, will include a drop-down menu on the MIDM, will be used in a blocking query, and so on. There are also some restrictions for how fields can be named and how the properties are defined on the Configuration Editor and in the configuration files.
The following topics provide information about the naming restrictions and about the field properties of the wizard.
When you name the fields in your object structure, be sure to keep the following guidelines in mind to avoid errors when compiling or running the master index application.
The following table lists and describes the properties you can define on the Field Properties page of the Configuration Editor.
Property
Description
Name
A name for the field. See Master Index Field Name Restrictions for information on valid field names.
Data Type
The data type for each field. Possible data types are:
  • string - Fields of this type contain a string of characters.
  • date - Fields of this type contain a date value.
  • float - Fields of this type contain a floating point integer.
  • int - Fields of this type contain an integer.
  • char - Fields of this type contain a single character.
  • boolean - Fields of this type can contain either true or false.
Match Type
The type of matching to be performed against the field, if the field is to be used for match weight generation. You must define at least one field for matching or no weights will be generated.
Note - The match types you specify here define the structure of mefa.xml, including the match string. The match types in mefa.xml might differ from the match types specified here. See Appendix A, Match Types and Field Names, in Oracle Java CAPS Master Index Processing Reference for information about the available options for this field.
Blocking
An indicator of whether the field will be used in the blocking query. Select this option to add the field to the blocking query; deselect this option to omit the field from the blocking query.
Key Type
An indicator of whether the field is used to identify unique objects. For example, a business index might store several addresses for each business. Each address is assigned an address type and each business can only have one address of each type. Select this option if the field is a unique record identifier; otherwise, deselect it.
Key type fields should also be required fields unless a combination of fields are specified as key types for an object.
Note - It is recommended that each child object contain a key type field, but this is not required. If child objects do not contain one or more key type fields, each enterprise object might accumulate a very large number of child objects depending on the survivor strategy used.
Updateable
An indicator of whether the field can be updated from the MIDM and external system messages. Select this option if the field can be updated; otherwise deselect it.
Required
An indicator of whether the field is required in order to save an enterprise object to the database. Select this option if the field is required; otherwise, deselect it.
Field Size
The number of characters allowed in each field. This determines the number of characters allowed in the database columns and defines the maximum number of characters that can be entered into each field on the MIDM.
Pattern
The required data pattern for the field. For more information about possible values and using Java patterns, see “Patterns” in the class list for java.util.regex in the Javadocs provided with the Java EE Platform. You might want to define patterns for date, telephone, or SSN fields. Note that for the MIDM, the pattern is further restricted by the value entered for the input mask described later in this table. If no input mask is specified, all regex patterns are supported.
Code Module
The identification code for the drop-down list that appears for this field in the MIDM.
Note - This must match an entry in the code column of the sbyn_common_header database table and, by default, an entry for the code you enter is created in the Code List database script. You can further customize code lists directly in the Code List script.
User Code
The processing code for the drop-down list that appears on the MIDM for the fields defined by the constraint–by property, described below. These codes are used for non-unique IDs, such as account numbers, insurance policies, credit cards, and so on.
Note - This must match an entry in the code_list column of the sbyn_user_code database table.
Constrained By
The name of the field that contains the corresponding User Code value (described above) to use to validate the current field. The User Code and Constrained By properties are used in conjunction to define non-unique ID types, such as credit card numbers or account numbers. The first purpose is to define a drop-down list for the field that contains the User Code value. The second purpose is to validate the field that contains the Constrained By value against definitions for the field with the user code value.
For example, if you store non-unique IDs such as credit card numbers or insurance policy numbers, you could create a field named ID Type with a User Code of CREDCARD (CREDCARD also needs to be defined as a code in the sbyn_user_code table). This gives the ID Type field a drop-down list based on the definitions for CREDCARD in the sbyn_user_code table. Definitions would be VISA, MASTERCARD, AMEX, and so on. You could then create a field named ID that would be constrained by the formats defined for the ID Type field. Any credit card numbers you enter would be validated against the format defined for the type of credit card you selected in ID Type.
Display Name
The name of the field as it will appear on the MIDM.
Input Mask
A mask used by the GUI to add punctuation to a field. For example, if users enter the date in the format MMDDYYYY, you can add an input mask to display the dates as MM/DD/YYYY. Use the value mask (described below) to strip the punctuation from the value before storing it in the database.
To define an input mask, type a character type for each character in the field and place any necessary punctuation between the character types. For example, the input mask for the above date format is DD/DD/DDDD.
Note that the value you enter can further restrict the data pattern for the field (this is the Pattern property). The following character types can be used.
  • D – indicates a numeric character.
  • L – indicates an alphabetic character.
  • A – indicates an alphanumeric character.
Value Mask
A mask used by the index to strip any extra characters that were added by the input mask (see above). This mask ensures that data is stored in the database in the correct format.
To specify a value mask, type the same value as is entered for the input mask, but type an “x” in place of each punctuation mark. For example, if an SSN field has an input mask of DDD-DD-DDDD, specify a value mask of DDDxDDxDDDD to strip the dashes before storing the SSN. A value mask is not required for date fields.
The following table lists and describes the properties you can define for each field inobject.xml.
Element
Description
field-name
The name of the field. Follow the guidelines under Master Index Field Name Restrictions when naming fields.
field-type
The data type of the field. Possible values are:
  • boolean - Fields of this type can contain either “true” or “false”.
size
The number of characters allowed in each field. If you modify this element, be sure to modify the length of the corresponding database column accordingly.
updateable
An indicator of whether the field can be updated from the MIDM or by back-end messages. Specify true if the field can be updated, or specify false if it cannot.
required
An indicator of whether the field is required in order to save an enterprise object in the database. Specify true if the field is required, or specify false if it is not.
code-module
The identification code for the menu list that appears for this field in the MIDM. This must match a value in the code column of the sbyn_comment_header database table. This element is optional.
maximum-value
The maximum value allowed in the field. To specify a value for a date field, use the format YYYY-MM-DD. This element is optional.
minimum-value
The minimum value allowed in the field. To specify a value for a date field, use the format YYYY-MM-DD. This element is optional.
pattern
The required pattern for the field. For more information about possible values and using Java patterns, see “Patterns” in the class list for java.util.regex in the Javadocs provided with J2SE Platform. You might want to define patterns for date, telephone, or SSN fields. Note that for the MIDM, the pattern is further restricted by the value entered for the input mask. If no input mask is specified, all regex patterns are supported.
user-code
constraint-by
The name of the field that contains the corresponding user–code value (described above) to use to validate the current field. The user–code and constraint-by properties are used in conjunction to define non-unique ID types, such as credit card numbers or account numbers. The first purpose is to define a drop-down list for the field that contains the user code value. The second purpose is to validate the field that contains the constraint value against definitions for the field with the user code value.
For example, if you store non-unique IDs such as credit card numbers or insurance policy numbers, you could create a field named ID Type with a user–code of CREDCARD (CREDCARD also needs to be defined as a code in the sbyn_user_code table). This gives the ID Type field a drop-down list based on the definitions for CREDCARD in the sbyn_user_code table. Definitions would be VISA, MASTERCARD, AMEX, and so on. You could then create a field named ID that would be constrained by the formats defined for the ID Type field. Any credit card numbers you enter would be validated against the format defined for the type of credit card you selected in ID Type.
key-type
An indicator of whether the field is used to identify unique objects. Specify true if the element is a unique object identifier; specify false if it is not. Key type fields should also be required fields unless a combination of fields are specified as key types for an object. This element is optional.
Note - Each child object should contain at least one field that is a unique object identifier, but this is not required. If two or more fields are unique identifiers, the combined value of these fields must be unique in a given enterprise record.
