SPARC M5-32 and SPARC M6-32 Servers Product Notes
Exit Print View
Updated: March 2016
PCIe Faults Reported Nonserviceable and Cannot Be Repaired (17317884)
Faults that are proxied from Oracle Solaris to Oracle ILOM might get into an unusual state. If Oracle Solaris is shutdown when an attempt is made to repair an Oracle Solaris diagnosed fault from Oracle ILOM, the repair might not complete and I/O related resources might be affected. In this situation, it is not possible to repair the fault from Oracle ILOM.
Suspect faults are identified in the output of the fmadm faulty command as having a FRU Status of repair attempted. For example:
  Suspect 1 of 9
     Fault class  : fault.io.pciex.device-interr
     Certainty    : 14%
     Affects      : /SYS/IOU0/IOB0/PCIE_SWITCH1/PCIE_LINK8
     Status       : OK
     FRU
        Status            : repair attempted
        Manufacturer      : Celestica Holdings PTE LTD
        Name              : M4-32 IO Switch IDT Board
        Part_Number       : 07041871
        Revision          : 06
Workaround: Repair or acquit the fault in Oracle ILOM when Oracle Solaris is up and running. If you are unsuccessful, contact your authorized Oracle Service Provider for support.
