Contents
Title and Copyright Information
Preface
1 Understanding JD Edwards EnterpriseOne
2 Before You Begin the Upgrade
3 Working with the Deployment Server
4 Working with the Platform Pack
5 Working with the Installation Planner for an Upgrade
6 Working With Installation Workbench
7 Working With the Enterprise Server
8 Installing the Development Clients for Developers and System Administrators
9 Performing Merges
10 Understanding Media Object Queues
11 Performing Post Upgrade Tasks
12 Working With Signon Security
13 Manual Table Conversions
14 Building and Testing Packages
15 Upgrading the Production Environment
16 Retrofitting Custom Modifications
17 Troubleshooting
18 Performing a Data-Only Upgrade
19 Adding a Server to an Existing Configuration
20 Creating a Language-Only Installation Plan
21 Creating a Remote Installation Plan
22 Understanding JD Edwards EnterpriseOne Directory Structures
23 Understanding Data Source Charts
24 Major Technical Tables
25 Working with Reports
26 Deinstalling the Software
A Understanding SQL Server Databases
