The SP serial management port is labeled SER MGT. Use the SP SER MGT port only for server management. This port is the default connection between the SP and a terminal or a computer.
Caution - Do not attach a modem to this port. |
When connecting a DB-9 cable, use an adapter to perform the crossovers given for each connector.
