Exit Print View
After you have connected these cables, see Powering On the Server for the First Time before connecting the AC power cords.
Connect the SER MGT Cable
Connect the NET MGT Cable
Connect Ethernet Network Cables
Connect Other Data Cables
Front Panel Components (Installation)
Rear Panel Components (Installation)
Cabling Requirements
Identifying Ports
