VGA Port
The server has two VGA video ports, one port on the front and one on the rear panel. See
Front Panel Components (Installation) and Rear Panel Components (Installation).
Each video port supports standard VGA and provides a female HD-15 video connector.
Note - Only one of the two ports can be used at a time. The
rear VGA port is disabled by default. To enable the rear port and
disable the front port, you must enable the Oracle ILOM VGA_REAR_PORT policy: -> set /SP/policy VGA_REAR_PORT=enabled.
Note - The cable length used to connect between the monitor
and the VGA port should not be over 6 meters.
1 |
Red Video |
9 |
[KEY] |
2 |
Green Video |
10 |
Sync Ground |
3 |
Blue Video |
11 |
Monitor ID - Bit 1 |
4 |
Monitor ID - Bit 2 |
12 |
VGA 12C Serial Data |
5 |
Ground |
13 |
Horizontal Sync |
6 |
Red Ground |
14 |
Vertical Sync |
7 |
Green Ground |
15 |
VGA 12C Serial Clock |
8 |
Blue Ground |
