Optional components that you order as part of the server module's initial configuration are installed in the server module before it is shipped. These optional components are identified on the customer information sheet included with the server module's packaging.
However, if you ordered optional components separately, you must install them in the server module before you install the server module in the modular system chassis.
To install any optional components, refer to the Server Module Service Manual and to the documentation for the optional component.
