Powering
On the Host for the First Time
Based on the connection method you selected from Plan Communication With the Server Module During Installation, perform the tasks in
the applicable row of this table.
Method 1 (web interface) –
Through a browser that is on the same network as the CMM, power
on the host using the CMM Oracle ILOM web interface. |
Method 1 (CLI) –
Through a terminal window on a system that is on the same
network as the CMM, power on the host using the CMM Oracle ILOM
CLI. |
Method 2 (CLI) –
Through a terminal device connected to the front panel of
the server module (using the dongle cable), power on the host using
the server module SP Oracle ILOM CLI. |
Method 3 (CLI) –
Through a terminal device connected to the CMM SER MGT port, power
on the host using the CMM Oracle ILOM CLI. |
