Prepare the Modular System and Server
Module
You must install and configure the Sun Blade
6000 modular system (chassis) before installing the server module.
- Ensure
that the modular system is installed and functional.
Satisfying the following conditions ensures a straightforward
installation of the server module:
- Install the modular
system into its intended rack before installing server modules.
- If you plan to manage the server
modules through the modular system CMM, configure the CMM to run
in your network.
- Ensure that the modular system
chassis is powered on and running.
is running the latest version of CMM Oracle ILOM firmware.
Note - For more information about preparing the modular system
and CMM Oracle ILOM, refer to the Sun
Blade 6000 Modular System Installation Guide.
- Unpackage the server module.
Be ready to insert the server module within 60 seconds of
removing the filler panel.
- Install any optional components.
See Install Optional Components.
