Go to main content
oracle home
Sun Network QDR InfiniBand Gateway Switch Product Notes for Firmware Version 2.1
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Network QDR InfiniBand Gateway Switch ...
Hardware Information and Issues
Number of LAGs
Updated: March 2017
Document Information
Using This Documentation
Product Documentation Library
Feedback
Known Problems
General Information and Issues
Jumbo Frames
Subnet Manager
Snapshot Dataset Information
Software Information and Issues
New Functionality for Commands
Main Board, Management Controller, and Chassis Serial Numbers
High Availability in Partitions
Email Alert Rules
Time Zone Support
Firmware Update Guidelines
Host Software and Firmware
Oracle Solaris EoIB Considerations After Upgrading to Firmware 2.1
Ethernet Support
Number of LAGs
Unusable Ports
Documentation Information and Issues
Upgrade and Downgrade Paths Supported
Command Corrections
smpartition Command
Syntax
Description
Options
Example
smsubnetprotection Command
Syntax
Description
Options
Example
VNIC Limits for ETH Ports
VNIC Limits for the createlag Command
Command Output Description Incorrect
Understanding Switch Chip Port to Connector Routing
Switch Chip Port to QSFP Connectors and Link LED Routes
QSFP Connectors and Link LEDs to Switch Chip Port Routes
disablegwport Command Connector Invalid
Features and Functionality Documented
Correct Power Consumption
Node Description Format
Battery Service Sequence
Replace a Gateway
Multiple Subnet Managers in a Single Fabric
Replication Password Information Incomplete
Temperature Sensor Thresholds Incorrect
README File Is Incomplete
Configuring Secure Fabric Management
Acquire the BXOFED Software (Linux)
Acquire the ConnectX-2 Firmware
Upgrading the Gateway Firmware
Acquire the Gateway Firmware Package (CLI)
Upgrade the Gateway Firmware (CLI)
Language:
English
Number of LAGs
The gateway supports a maximum of 16 LAGs.
Previous
Next
