You use action statements to invoke the various IPQoS modules that are described in IPQoS Architecture and the Diffserv Model.
When you create the IPQoS configuration file, you must always begin with the version number. Then, you must add the following action statement to invoke the classifier:
fmt_version 1.0 action { module ipgpc name ipgpc.classify }
Follow the classifier action statement with a params clause or a class clause.
Use the following syntax for all other action statements:
action { name action-name module module-name params-clause | "" cf-clauses }
Assigns a name to the action.
Identifies the IPQoS module to be invoked, which must be one of the modules in Table 6–5.
Can be parameters for the classifier to process, such as global statistics or the next action to process.
A set of zero or more class clauses or filter clauses
