Module Definitions
The module definition indicates which module is to process the parameters in the
action statement. The IPQoS configuration file can include the modules listed in
the following table.
Table 6-5 IPQoS Modules
ipgpc
| IP classifier
dscpmk
| Marker to be used to create DSCPs in IP packets
dlcosmk
| Marker to be used with VLAN devices
tokenmt
| Token bucket meter
tswtclmt
| Time-sliding window meter
flowacct
| Flow-accounting module
