Skip Navigation Links
Exit Print View
Oracle ZFS Storage ZS3-ES
Service Manual
search filter icon
search icon
Document Information
Using This Documentation
About This Documentation
Related Documentation
Feedback
Support and Accessibility
About the Oracle ZFS Storage ZS3-ES
Product Description
About Controls and Connectors
Front Panel Controls and Indicators
Server Back Panel View
About Server and Component Status Indicators
Server General Status Indicators
Server Fan Status Indicators
Storage Drive Status Indicators
Power Supply Status Indicators
Motherboard Status Indicators
About System Components
Illustrated Parts Breakdown
Customer-Replaceable Units
Field-Replaceable Units
Troubleshooting the Server
Service Troubleshooting Task List
Diagnostic Tools
Gather Service Information
Locate the Server Serial Number
Inspecting the System
Troubleshoot Power Problems
Inspect the Server Externally
Inspect Internal Server Components
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
Required Tools
Preparing the Server for Component Replacement
Powering Down the Server
Disconnect Cables From the Server
Extend the Server to the Maintenance Position
Remove the Server From the Rack
Take Antistatic Measures
Open the Server Fan Door
Remove the Server Top Cover
Servicing CRUs That Do Not Require Server Power Off
Servicing Storage Drives (CRU)
Storage Drives Hot-Plug Conditions
Remove a Storage Drive
Install a Storage Drive
Servicing Fan Modules (CRU)
Remove a Fan Module
Install a Fan Module
Servicing Power Supplies (CRU)
Remove a Power Supply
Install a Power Supply
Servicing CRUs That Require Server Power Off
CRU Locations
Servicing the DIMMs (CRU)
DIMM and Processor Physical Layout
Inconsistencies Between DIMM Fault LEDs and the BIOS Isolation of Faulty DIMMs
Using the Fault Remind Button
Identify and Remove Faulty DIMMs
Install a DIMM
Servicing PCIe Risers (CRU)
PCIe Riser Location and Differences
Remove a PCIe Riser From PCIe Slot 1 or 2
Install a PCIe Riser Into PCIe Slot 1 or 2
Remove a PCIe Riser From PCIe Slots 3 and 4
Install a PCIe Riser Into PCIe Slots 3 and 4
Servicing PCIe Cards (CRU)
PCIe Slot Characteristics
Identify a Faulty PCIe Card in the BUI
Remove a PCIe Card From PCIe Slot 1 or 2
Install a PCIe Card in PCIe Slot 1 or 2
Remove a PCIe Card From PCIe Slot 3
Install a PCIe Card in the PCIe Riser in Slot 3
Remove the Internal HBA Card
Install the Internal HBA Card in the PCIe Riser
Servicing the Internal USB Flash Drive (CRU)
Remove an Internal USB Flash Drive
Install an Internal USB Flash Drive
Servicing the Battery (CRU)
Remove the Battery
Install the Battery
Servicing FRUs
FRU Locations
Servicing Processors (FRU)
Remove a Processor
Install a Processor
Servicing the Disk Backplane (FRU)
Disk Backplane Configuration
Remove the Disk Backplane
Install the Disk Backplane
Servicing the Front Indicator Module (FRU)
Remove the Front Indicator Module
Install the Front Indicator Module
Servicing the Motherboard (FRU)
Remove the Motherboard
Install the Motherboard
Servicing the SAS Cables (FRUs)
Remove Storage Drive SAS Cables
Install Storage Drive SAS Cables
Removing and Installing Server Filler Panels
Remove and Install Filler Panels
Install the Top Cover
Remove Antistatic Measures
Reinstall the Server Chassis Into the Rack
Return the Server to the Normal Rack Position
Install the Cable Management Arm
Reconnect Data Cables and Power Cords
Power On the Server
Identifying the Server Ports
Gigabit Ethernet Ports
Network Management Port
Serial Management Port
Video Connector
USB Ports
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Download Firmware and Software Using My Oracle Support
Index
These sections describe how to remove and install storage drives:
Related Information
