Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
SEFOS# configure terminal SEFOS(config)# vlan 1 SEFOS(config-vlan)# ports extreme-ethernet 0/1 name vlan 1 SEFOS(config-vlan)# end
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# no lldp tlv-select dot1tlv port-vlan-id protocol-vlan-id all vlan-name all SEFOS(config)# end
SEFOS# show lldp local extreme-ethernet 0/1 ... Enabled Tx Tlvs : Port Description, System Name, System Description, System Capability, Management Address, Mac Phy, Link Aggregation, Max Frame Size ... Extended 802.1 TLV Info -Port VLAN Id : 1 -Port & Protocol VLAN Id Protocol VLAN Id Support Protocol VLAN Status TxStatus ---------------- ------- -------------------- -------- 0 Supported Enabled Disabled -Vlan Name Vlan Id Vlan Name TxStatus ------- --------- -------- 1 vlan1 Disabled --------------------------------------------------------------------
Enabled Tx TLVs do not display any IEEE 802.1 organizationally-specific TLVs. In addition, PPVIDs and VLAN name TLVs are disabled because IEEE 802.1 organizationally-specific TLVs are disabled.
SEFOS# show lldp neighbors extreme-ethernet 0/1 detail ... Extended 802.1 TLV Info -Port VLAN Tlv : Not Advertised -Port & Protocol VLAN Id Protocol Vlan Tlv : Not Advertised -Vlan Name Vlan Name Tlv : Not Advertised ------------------------------------------------------------ Total Entries Displayed : 1
