Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
MLDS Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
MLDS Protocol Description
Joining a Multicast Group
MLDS Topology Example
Configuration Guidelines
Default Configurations
Configuring MLDS
Enabling and Disabling MLDS
Enable MLDS Globally
Enable MLDS in a Specific VLAN
Disable MLDS
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configure MLDS Query Interval
Configuring Proxy Reporting
Configure Proxy Reporting
Disable Proxy Reporting
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Enable Fast-Leave Processing
Disable Fast-Leave Processing
Configuring Report Forwarding
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
Enable Query Transmission on Topology Change
Disable Query Transmission on Topology Change
Display MLD Statistics
You can configure an MLDS switch as a querier on a particular VLAN. When you do this, the switch starts sending general queries at regular time intervals. The querier message sent by the switch will not take part in querier election. If the switch receives a query from any other router, the switch will stop acting as a querier.
In this example, VLAN 4 is the VLAN for which the switch is configured as a querier.
  1. Configure the MLDS switch as a querier for a specific VLAN.
    SEFOS# configure terminal
    SEFOS(config)# vlan 4
    SEFOS(config-vlan)# ipv6 mld snooping querier
    SEFOS(config-vlan)# end
    The switch sends general queries on the member ports of VLAN 4 every 125 seconds.
  2. View the configuration.
    SEFOS# show ipv6 mld snooping
    Snooping VLAN Configuration for the VLAN 4
      MLD Snooping enabled
      MLD Operating version is V1
      Fast leave is disabled
      Snooping switch is configured as Querier
      Snooping switch is acting as Non-Querier
      Query interval is 125 seconds
    The MLDS switch stops acting as a querier on reception of general queries and resumes its querier functionality when there are no MLD routers in the network.
    The MLDS switch continues acting as a querier on reception of router control messages (PIM/OSPF). The switch further continues its query when the router port is not operating and there are no router ports in the switch.
