Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System MLDS Administration Guide |
Enable MLDS in a Specific VLAN
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Enable Query Transmission on Topology Change
The snooping switch is configured to send MLD general queries on all the nonrouter ports, when spanning tree topology changes occur in a network. If the spanning tree mode is RSTP, MLD general queries are sent on all the non router ports, which are the VLANs member ports present in the switch. If the spanning tree mode is MSTP, MLD general queries are sent on all the nonrouter ports of the VLAN mapped for the MSTP instance. Once you enable this command, the switch generates MLD general query messages when a topology change occurs in the network.
