Component Sensor Targets
Use the targets from this table to check the switch status. See Check Switch Status (Oracle ILOM).
Some sensors indicate the state of LEDs. See Rear Panel LEDs.
Switch fault |
/SYS/SERVICE |
State of chassis
Attention LED |
Switch locator |
/SYS/LOCATE |
State of chassis Locator LED |
Switch OK |
/SYS/OK |
State of chassis OK LED |
Fan
fault |
/SYS/FMx/SERVICE |
where x is 0 or 1, state of fan Attention LED |
Fan presence |
/SYS/FMx/PRSNT |
where x
is 0 or 1 |
Fan speed |
/SYS/FMx/FANy/TACH |
where x is 0 or 1 and y is 0
or 1 |
Power supply fault |
/SYS/PSy/SERVICE |
where y is 0 or 1, state of power supply
Attention LED |
Power supply presence |
/SYS/PSy/PRSNT |
where y is 0 or 1 |
Power supply OK |
/SYS/PSy/OK |
where y is 0
or 1, state of power supply OK LED |
Related Information
