To select more than one item group, press and hold CTRL while selecting.
Oracle Hospitality recommends adding by item group whenever possible as it enables you to add multiple items at a time, rather than only one item at a time.
Apply to all items: Select this option to apply the change to all items in the order.
Apply only on selected items: Select this option to apply the change only to the selected item.
Apply only on suggested qty: Select this option to apply the change to only items that have a suggested quantity.
Parent topic: Ordering
